.net framework 3.5 sp1 not installing
Cold Storm
Battosai
15,010 (2.34/day)
In a library somewhere on this earth
System Name Haro
Processor AMD 1700x
Motherboard AsRork x370 Taichi
Cooling EK Custom Loop - CPU only
Memory 32gb G-Skill Trident Z
Video Card(s) EVGA 1080 Superclock 2
Storage Too Many
Display(s) Viewsonic VX2450WM-LED 24" & LG 32 IPS
Case Cooler Master Cosmos II
Mouse SteelSeries Rival 500
Software Win10 Pro
Benchmark Scores i5 750 4.62ghz pi runs // Evga FTW p55
I got an issue with my HP laptop. It's a HP touchsmart tm2t tablet pc.
Whenever I install .net framework 3.5 sp1 on my laptop it never installs fully. I have a .net framework 3.5 sp1 indificiation program but it still says, no matter what, that it's not installed.
I've went threw and played with :programs and features: and "chcek marked" for it to be on.
I have also downloaded it from microsoft website.
I had it working before I reformatted my hdd. I didn't think it would be a hassle like it is now.
Cold Storm
Battosai
15,010 (2.34/day)
System Name Haro
Processor AMD 1700x
Storage Too Many
Software Win10 Pro
I'll look threw the logs when I get home. This win 7 is a fresh install of Win 7 pro. Before, I had hp's win 7 pro in and all I did was:
  1. download from microsoft
  2. check mark the stuff in program & features
  3. install
  4. Run a Dos Netfx35_detect_error program
  5. Validate that it was installed via Microsoft's validator
Then from that I could run my companies programs..
::I did it the same way as I did before, but for some reason, it didn't install correctly. But, I will look at the logs and see since I was trying to do it at midnight and right when I got to work today.
95Viper
Super Moderator
13,309 (2.20/day)
Try un-checking the two options under the .net 3.5.1, re-boot and install/run the program you are trying to use.
Edit: Does sound counter to logic, but, I think this way.;)
Cold Storm
Battosai
15,010 (2.34/day)
System Name Haro
Processor AMD 1700x
Storage Too Many
Software Win10 Pro
I've done that as well.. To which windows then asks me to go into programs features and make sure it's enabled.. I can ss that error I get when I get home and do it.. around 5pm est
INSTG8R
Vanguard Beta Tester
8,150 (1.09/day)
Canuck in Norway
Case TT Kandalf L.C.S.
Mouse G502 Hero
Keyboard G19s
VR HMD Oculus Quest 3
Software Win 11 Pro x64
Dunno why your worrying about it in Win7. .NET 4 is installed with Win7 and contains all the previous .NET libraries.
974 (0.17/day)
System Name Grond
Processor Ryen 5 3600x PBO ~ 4.4GHz / fabric at 1900
Motherboard MSI b550 Tomahawk
Cooling XSPC Raystorm CPU w/ am4 mounting bracket+ 2 RX360 radiator + xspc Razor R9-290 w/ backplate
Memory 32gb Crucial Ballistix @ 3800
Video Card(s) XFX R9 290 w/ XSPC Razor full cover block and backplate
Storage WD SN850 1tb-OS, SN750 1tb, Samsung 860 Evo 1tb, WD blue hdd 4tb
Display(s) Samsung 23" 120hz 3d LCD w/ 3d glasses, using 'lightboost' trick
Case NZXT H630 white watercooling case
Audio Device(s) Onboard realtek ALC 1200+ Sennheiser HD 598
Power Supply XFX Pro 850 XXX semi-modular
Mouse Logitech G703 Wireless
Keyboard Steelseries 6 v2
Software Windows 10 Pro (Had some mystery error on Win7 and decided to go W10)
Temporarily disable your firewall and anti-virus programs. I had the same problem, turned ot to be overzealous anti-malware protection.
Cold Storm
Battosai
15,010 (2.34/day)
System Name Haro
Processor AMD 1700x
Storage Too Many
Software Win10 Pro
Yes, I know that .net 4 is installed. But, for some reason the company I work for, their system doesn't work without it running via microsoft's installed program.
I'll try that
Cold Storm
Battosai
15,010 (2.34/day)
System Name Haro
Processor AMD 1700x
Storage Too Many
Software Win10 Pro
attched is the file I get when I try to install after "unchecking" all the 3.5 sp1 from the :programs & Features:
If I have them "checked" I just get a blank "set-up error" that doesn't have anything but a "close" button at the bottom right.
  • dd_dotnetfx35error.txt
95Viper
Super Moderator
13,309 (2.20/day)
Try turning off DEP and, then, try installing .net.
Also, do you have Visual studio or anything like that installed?
Cold Storm
Battosai
15,010 (2.34/day)
System Name Haro
Processor AMD 1700x
Storage Too Many
Software Win10 Pro
i dont have any of the visual studios installed. i tryed turning off dep threw command prompt and it gave me error message on which to say that wasnt installed. but i did uncheck it in iE
the only thing that i can see different is that now i am using win 7pro, to where before it was win 7 home....
FordGT90Concept
"I go fast!1!11!1!"
26,263 (4.35/day)
IA, USA
System Name BY-2021
Cooling Scythe Mugen (rev 5)
Mouse Nixeus REVEL-X
Keyboard Tesoro Excalibur
What's the error code in Windows Update (Review your update history)? E.g. 800706BA, 8024000B, or 643
...except 1.1 (VS2003 and VS2002).
Cold Storm
Battosai
15,010 (2.34/day)
System Name Haro
Processor AMD 1700x
Storage Too Many
Software Win10 Pro
I didn't see anything in the windows update that show error. All the updates that have been done have shown sucessfull.. Even the security update for 3.5 sp1 was sucessfull
FordGT90Concept
"I go fast!1!11!1!"
26,263 (4.35/day)
IA, USA
System Name BY-2021
Have you tried running a .NET 3.5 application? FYI, 3.5.1 is current--3.5 is old.
Edit: I'm going to throw a .NET 3.5 application together that tells you all .NET frameworks installed...
Cold Storm
Battosai
15,010 (2.34/day)
System Name Haro
Processor AMD 1700x
Storage Too Many
Software Win10 Pro
The only thing that I've ran is a .net setup verifier system. there is a 3.5 sp1 app that lets me know if 3.5 sp1 is installed via my company's System..
FordGT90Concept
"I go fast!1!11!1!"
26,263 (4.35/day)
IA, USA
System Name BY-2021
I'm not done with my entire application but this will tell you if .NET 3.5 is installed and working. Download the zip, extract it somewhere, and run test35.bat. It should say:
.NET Framework 3.5 is installed and working.
Press any key to continue . . .
If it says anything other than that, .NET 3.5 install is FUBAR. You might have to try manual uninstall and failing that, it can probably only be fixed via reinstalling Windows.
Oh, did you check under "Optional Updates" in Windows Update? 3.5 SP1 might appear under there if Windows detects that it is needed.
The finished app, if I can get it done, will give version numbers, installed service packs, and test it for 2.0-4.0 and maybe 1.1 too.
  • test35.zip
Cold Storm
Battosai
15,010 (2.34/day)
System Name Haro
Processor AMD 1700x
Storage Too Many
Software Win10 Pro
Thanks a ton on this. I've downloaded it and it does state that 3.5 is installed.
as for the options i only have seen, as i checked when you asked, there was a security update for .net 4... installing it now
edit::
This is what i get when i run it in troubleshoot compatability
FordGT90Concept
"I go fast!1!11!1!"
26,263 (4.35/day)
IA, USA
System Name BY-2021
If Windows update doesn't say 3.5 SP1 update is needed (it is a security update and therefore important/required), whatever program is telling you otherwise is BS'ing you. If my application worked, there should be no problem with .NET 3.5 software working on that computer.
Cold Storm
Battosai
15,010 (2.34/day)
System Name Haro
Processor AMD 1700x
Storage Too Many
Software Win10 Pro
If sp1 is working, then I can go straight into the program with no issues. But, that doesn't seem to be the case with it now. Since .net 3.5 sp1 all ways has a error.. I'm almost thinking of doing..
uninstalling .net 4 and trying to do that first. That's the only thing that was different now that I think about it..
Worst case.. I can all ways swap the hdd every other Friday when I have to do that one task at home...
FordGT90Concept
"I go fast!1!11!1!"
26,263 (4.35/day)
IA, USA
System Name BY-2021
Windows 7 ships with 3.5 SP1. If it doesn't work, something damaged it (and likely, the OS at large).
What error does this program you're using present?
Cold Storm
Battosai
15,010 (2.34/day)
System Name Haro
Processor AMD 1700x
Storage Too Many
Software Win10 Pro
Here is what is shown when I look a the reg. It does state that it is installed..
Yeah, I know win 7 has it installed.. What I am thinking, and I'll try this in a min.. is that since my company want's something working with .net 3.5 sp1, I think it needs to be stand-alone to have it working.. meaning, that it needs to have no view of 4.0 installed..
Now when you ask for error, do you ask when I try to "install 3.5 sp1? or when I try to access the program that needs 3.5 sp1?
because, if it's the program, all I get is the "please wait while ..... is loading". In which it just hangs there and never loads..
11,119 (1.60/day)
System Name Apple Bite
Processor Intel I5
Motherboard Apple
Memory 40gb of DDR 4 2700
Video Card(s) ATI Radeon 500
Storage Fusion Drive 1 TB
Display(s) 27 Inch IMac late 2017
Cold I had the same trouble with Vista Ultimate and that update and I even did a re-installed pissed me off so much I bought a student version of Windows7 Ultimate and installed it. From what I read you have to uninstall all the net frame software and reinstall them (every update). That's the fix but it didn't work for me you can also email Microsoft for help. That update is a known problem.
Cold Storm
Battosai
15,010 (2.34/day)
System Name Haro
Processor AMD 1700x
Storage Too Many
Software Win10 Pro
All right.. this is the funny a$$ part.. So.. TRT, I did what you said.. then did something I should of did WAY before starting this.. Reg cleaner.. lol..
So.. my steps..
  1. Uninstall everything to which it's just .net framework 2.0
  2. Restart
  3. Install 3.5 sp1 via :program and Features: Turn off....
  4. Restart
  5. Reg clean threw CCleaner 4 times, every time had a issue.
  6. Verify that all .net up to 3.5 sp1 was installed and been verified to be working
  7. went to website
  8. saw a action to "run test" to see if system is compatible.
  9. Allowed Firewall/ windows defender to run said program (says it's a low grade trojan
  10. Went to issued program and opened..
  11. Worked..
lol... oh, how stupid I was.. I all ways run reg cleaner on new os's... My mind is losing myself... :roll:
