- Aug 19, 2017
- 3,044 (1.08/day)
Netac, a Chinese maker of memory and storage devices, has developed DDR5 memory modules with impressive speeds. The company has used SK Hynix A-type dies to create DDR5 memory with up to 8000 MT/s rates. With incredible speeds comes significant latency, whereas the DDR5-8000 memory kit comes with a CAS latency of 38-48-48-128. Netac has determined that these DRAM modules require as much as 1.5 Volts to power it. The base kit starts at 6000 MT/s, with 6200/6600/7200/7600 and 8000 MT/s variations mentioned above. Available in silver and black, these memory modules are equipped with an ARGB strip at the top that works with every RGB control software of motherboard makers.
You can check out the images and specification table below.
