phillyman777
- Nov 9, 2022
- 3 (0.00/day)
Hello everyone. I want to build a new pc and need some advice. This pc will be used for
Gaming (I have a 240hz 1440p monitor)
Watching several twitch streams here and there.
Some dvd encoding and burning. I use software like Handbrake, Convertxtodvd, Bandicam.
I am going the Intel route. I will eventually get a rtx 4080 to use with this build. Wanted to know
1) What cpu should I get a 13700k or go 13900k? Is a 13900k overkill and a waste for my use case?
2) What case would be good for a intel 13th gen combined with a rtx 4080. I was thinking about a Fractal torrent(if i use an air cooler) or a Corsair 5000d airflow(if i use a 360 aio) but depends on my cooler choice I guess. The rtx 4000 series are huge and I don't want to vertical mount the gpu so i would like to have enough space for the gpu power cable with having too much a bend but also dont want a 7 foot tall case lol
3) What cpu cooler? Is a Noctua d15 good for either or do I need a 360 aio? I don't overclock. I just set xmp and let it run at stock (if you say aio which one?)
Thanks for any suggestions and help.
