- Apr 15, 2021
- 938 (0.63/day)
For starters, I have basic knowledge when it comes to computers in general, and even less when it comes to buying parts.
PURPOSE: The system I have in mind will be used for both gaming in 1440p(FPS/MMO), rendering(Iray using Daz3D), and productivity(Adobe Photoshop, Substance Painter, etc.). No manual overclocking CPU/GPU wanted, and no exotic liquid cooling.
?CASE: Corsair Obsidian Series 750 D Airflow Edition Full Tower ATX Case. SKU: cc-9011078-ww or something very similar of decent quality that doesn't weigh 50+lbs empty.
CASE FANS: x2 Noctua P14s redux-1500 PWM 78.69 CFM 140mm Fan (Front Intake), x1 Noctua P14s redux-1200 PWM 64.92 CFM 140mm Fan (Rear Exhaust)
GPUs: 1x RTX 3090(for primary display) + 1x Quadro RTX A6000 *when necessary, both cards will be used together to render a scene faster if scene size requires < or = to 24Gb VRAM total since it must fit on both cards individually.
?CPU: Intel Core i9 - 10900K 3.7 GHz 10-Core CPU
?CPU COOLER: ?bequiet! Silent Loop 280mm 94.2 CFM Liquid CPU Cooler (Top Exhaust)(garbage pump, need alternative reliable brand)
?MOTHERBOARD: ??? Need one that will fit both aforementioned GPUs without proximity/thermal issues & doesn't block other slots. Preferably a Z590 with PCIe 4.0.
RAM: G.Skill Trident Z Royal DDR4-3200MHz CL16-18-18-38 1.35V 128GB (4x32GB) OR G.Skill Trident Z Royal DDR4-3200MHz CL14-14-14-34 1.35V 128GB (8x16GB) -Motherboard dependent.
OS DRIVE: Seagate Firecuda 520 2TB Performance Internal Solid State Drive SSD PCIe Gen4.
STORAGE: Western Digital Black 6TB 3.5" 7200 RPM Internal Mechanical HD. May add two more later on down the road for more storage.
?PSU: No clue! I've been told that 2x RTX 3090s require at least a 1600-watt PS to maintain system stability, so I don't know about my choice of GPUs. Seems like the few calculators I tried are not acurrate.
PERIPHERALS:
-ASUS ROG Swift PG278QR 27" 2560x1440 165 Hz Monitor
-Corsair K95 RGB Platinum Wired Mechanical Gaming Keyboard with Cherry MX BROWN Switches
-Corsair Harpoon RGB Wireless Optical Mouse
-Klipsch ProMedia 2.1 THX Cert. Computer Speaker System(2 satellite + subwoofer)
*NEED a APC UPS sufficient enough to power down system when power goes out.
That's about it. Right now I'm stuck on the motherboard. Any ideas or see anything else I might have screwed up? Thanks!
PERIPHERALS:
