super_ismail
- Jun 30, 2025
- 3 (0.17/day)
What do I mean by "Freeze"?
Basically everything in the screen stops moving all of a sudden, the mouse doesn't move, the keyboard doesn't work, but the Fans and RGBs are still running and the fans speed stabilize, so if I was in a game they immediately go back to base speed at idle
The only thing I can do is to hold down the shutdown/turn on button to force the PC to shutdown
PC Specs:
Long story short, after finishing building the PC I booted into windows and it freezes not immediately but at completely random conditions (Idle, gaming, checking temps, adjusting fan curves, running Youtube, installing software, windows setting...).
For 2 weeks I was trying to figure out the reason for this completely random freezing that happens
Some of the things I tried:
they ran games for 16+ hours with no issues, BUT the moment I got it home it froze immediately again.
Things I tried that made the PC more stable and I don't know why! :
I have to mention that the power supply I have was making a ticking noise at random intervals that sound electrical not mechanical (not fans) in both my old and new pc
Pleas if I'm being completely dump and the problem is obvious pleas tell what you think the issue is, it's getting supper frustrating and exhausting to deal with.
PC Specs:
- CPU: Ryzen 7 9800X3D
- GPU: ASUS ROG Astral RTX 5080
- RAM: G.Skill Ripjaws M5 Neo 6000MHz DDR5 64GB
- Motherboard: Gigabyte X870 Aorus Elite
- SSD: Samsung 990 Pro 2TB NVMe
- AIO: Arctic Liquid Freezer III 420
- PSU: Corsair RMe 1000e
- Fans: Eleven 140mm fans (AIO included)
- Case: HAVN HS 420
- Tried different Bios versions with different motherboards
- The classic "One RAM stick" trick
- Replaced the RAMs
- Replaced the SSD
- I even replaced the damn motherboard from Asus TUF B850 to Gigabyte Aorus X870 and still freezes!
- Tried windows 10, 11 home and 11 pro
- For each windows version I had tried looking at event viewer and liability viewer and none of them showed any event or error related to freezing
- run with and without HWinfo running
- running with and without fan curves
- AMD's Expo was never enabled
- installed all necessary drivers (AMD chipset, Nvidia, LAN, Bluetooth, Wifi, Audio, USB, SSD...)
- Ran the PC without a GPU and connected the monitor to my IGPU and it was stable for a while
- Left the GPU connected to the motherboard but not connected to a monitor and was also a bit stable
- I forced the motherboard to choose PCIe Gen4 instead of auto from Bios and was stable for a whole day but froze again next day
- I simply swapped my DP cable that allowed my PC to run at 155Hz (my monitor's native refresh rate) with an HDMI cable that limited my PC to 100Hz only. So far this was the best solution I've reached since I replaced DP cable that was running perfectly fine with the same GPU, PSU and monitor for 3 months with an HDMI cable that limited the performance to 100Hz.
