new KVM switch wouldn't display on monitor
498 (0.13/day)
Lagos, Nigeria
System Name purplekaycee
Processor Core i7 6700
Motherboard Msi z270 titanium
Cooling Cooler Master hyper 212 EVO
Memory 16gb (2x8gb) corsair LPX vengeance
Video Card(s) Gigabyte gtx 1080ti
Storage 1tb Samsung SSD, 4tb Seagate HDD, 8tb Seagate HDD
Display(s) Dell 23" ST 2310 60hz 1080p monitor
Case Cooler Master H500M
Audio Device(s) Astro A40 headphone
Power Supply Seasonic Focus GX 850. 850W
Mouse Regular mouse
Keyboard Regular keyboard
Software Windows 10 64 bit
Just got a new kvm switch to connect my two cpus but it won't bring out displays...
Would put up a pic of the monitor interface in the morning.
Suggest ions please...
1,618 (0.27/day)
dvi or vga? the displays work normally using the same individual cables otherwise?
498 (0.13/day)
Lagos, Nigeria
Mouse Regular mouse
Not sure about the cables ,but the switch is new .
Its a vga connect ed
91 (0.02/day)
System Name Isabella
Processor Intel i7-4790K OC
Motherboard Asus Sabertooth Z97 Mark I
Cooling NZXT Kraken X61, 2x Corsair SP PWM, 2x Noctua iPPC 3K PWM
Memory Corsair Vengeance Pro 16GB 1866
Video Card(s) Zotac GTX 980Ti AMP! Extreme
Storage Samsung 850 EVO 250GB & 500GB, 2xPatriot Blaze 240GB, WD Green 6TB
Display(s) Dell U2410f, Viewsonic VP720b, Sony Bravia 40"
Case NZXT H440 Blue
Audio Device(s) FiiO K3
Power Supply Corsair AX760i
Mouse Logitech G700
Keyboard Corsair K70 RGB
Shouldn't you plug your monitor to the one on the bottom? The one not saying PCx. So PC1 for inputing signal from 1st PC and PC2 for 2nd PC and so on, then your single monitor is on the VGA output.
Aquinus
Resident Wat-man
13,199 (2.73/day)
Concord, NH, USA
System Name Apollo
Processor Intel Core i9 9880H
Memory 64GB DDR4-2667
Case MacBook Pro (16", 2019)
Software MacOS 15.3.1
Plug the external display into the end where is say: USB 2.0 KVM switch then plug the keyboard/mouse into the opposite end.
Read the directions. :)
FordGT90Concept
"I go fast!1!11!1!"
26,263 (4.35/day)
IA, USA
System Name BY-2021
Cooling Scythe Mugen (rev 5)
Mouse Nixeus REVEL-X
Keyboard Tesoro Excalibur
The picture you took doesn't have any USB cables plugged into it. It may require the USB plugged in to the matching VGA to power it if it doesn't have a wall wart.
Minimum should be:
1 x monitor into the monitor logo D-Sub 15 port.
1 x computer VGA cable into D-Sub 15 port marked PC1.
1 x computer USB cable into USB port marked USB1.
1 x keyboard into console USB port.
1 x mouse into console USB port.
Use PC2/USB2 before plugging anything into PC3/USB3.
When everything is plugged in and turned on, try pressing scroll lock -> scroll lock -> 1 (above the letter Q on QWERTY keyboards) on the console USB keyboard and it should switch to PC1/USB1. If it does not, press the button, wait a few seconds for the display to come on and if it doesn't, press it again. Rinse and repeat until it shows up or you've gone through them all.
If at least one of the PC1-PC4 lights aren't on, there's still a power problem.
498 (0.13/day)
Lagos, Nigeria
Mouse Regular mouse
Minimum should be:
Got it working now but the picture quality on my monitor is niw tilted/slanted.
FordGT90Concept
"I go fast!1!11!1!"
26,263 (4.35/day)
IA, USA
System Name BY-2021
Make sure you're using a resolution and refresh rate the KVM supports (check manual/tech specs). If there's an auto-adjust function on the monitor, use it.
498 (0.13/day)
Lagos, Nigeria
Mouse Regular mouse
Looks a bit better now adjusted my nvidia resolution on its panel
