New monitor Acer 26" VGA panel
836 (0.13/day)
Canadia
System Name Blood
Processor Intel Core 2 Quad Q6600 @ 2.4Ghz
Motherboard ASUS P5Q PRO @ stock settings
Cooling Antec Case fans (max) OCZ Vandetta 2 CPU cooler with a Kaze Jyuni 120mm fan 1200RPM+-100RPM 67.5CFM
Memory Patriot Viper Series 4GB 2x2GB DDR2 800Mhz 5-5-5-15
Video Card(s) BFG NVIDIA GeForce GTX 260 OC MAXCORE 896MB PCIe 2.0 Core 216 @ stock settings
Storage Seagate Barracuda 500GB SATA 3.0Gb/s
Display(s) Acer AL2616Wd 25.5" 1920x1200 800:1 178degrees viewing angle 5ms S-IPS Panel
Case Antec Nine Hundred
Audio Device(s) Auzentech X-Plosion 7.1 with a coaxial cable connected to a Logitech z5500
Power Supply BFG ES-800 800W
Software Windows Vista (soon to be Windows Xp, Vista, and Windows 7 triple boot)
My new Acer 26" VGA panel monitor arrived yesterday, and I have to admit it is awesome using it, you can see it from any angle, and the colors are the same. The 1900x1280 resolution is amazing, I can do work and browse the internet at the same time. This monitor has a VGA panel and not a TN panel. The TN monitors can only display 6-bit color, and although have faster response times and contrast ratios, they have a bad view angle. On a TN panel you would get this shadow going across the screen when you look from a different angle. A VGA panel has true 8-bit color and no shadows come across the screen when lookd upon from a different angle.
here are some pics
I got this monitor for $500, really good deal at http://canadacomputers.com/main.php?do=ShowProduct&cmd=pd&pid=016452&cid=MT.863
just if you wanted to know
Availability: Out of Stock
This product is currently out of stock. Order it today and we will ship it as soon as possible. Usually ships within 1-5 business days.
Tease...:p
I was lucky enough to get the last one in the online store, they should be getting more of them I presume.
