- Jun 20, 2007
- 3,942 (0.60/day)
System Name | Widow |
Processor | Ryzen 7600x |
Motherboard | AsRock B650 HDVM.2 |
Cooling | CPU : Corsair Hydro XC7 }{ GPU: EK FC 1080 via Magicool 360 III PRO > Photon 170 (D5) |
Memory | 32GB Gskill Flare X5 |
Video Card(s) | GTX 1080 TI |
Storage | Samsung 9series NVM 2TB and Rust |
Display(s) | Predator X34P/Tempest X270OC @ 120hz / LG W3000h |
Case | Fractal Define S [Antec Skeleton hanging in hall of fame] |
Audio Device(s) | Asus Xonar Xense with AKG K612 cans on Monacor SA-100 |
Power Supply | Seasonic X-850 |
Mouse | Razer Naga 2014 |
Software | Windows 11 Pro |
Benchmark Scores | FFXIV ARR Benchmark 12,883 on i7 2600k 15,098 on AM5 7600x |
My game is crashing after the story arc ending/slides for Lonesome Road. It will spin the wheel for about ten seconds with some disk activity then CTD.
I've come to the conclusion that the only way around this(if wanting to keep my progress within Lonesome Road) is to find a way back to Mohave, then use commands to trigger the quest completion.
I have a save file right at the door (after death of Ulysses), where upon the current objective for The Apocalypse is to "Read the Canyon Wreckage"
This is accomplished by simply accessing the door out of Ulysses' temple - it then triggers the cutscene/ending.
What I can do is COC command movement back to the actual Canyon Wreckage cell, however unsure about proper completion for "The End" and "The Apocalypse"
I checked the stage of The Apocalypse before and after COC moving and it's stage 10.00
If I CompleteAllObjectives it works for the current objective however I do not see the nuclear explosions in the distance.
I believe there is a stage or trigger I am missing.
Please advise if you are familiar with script/stages for quests and what I may be missing.
