- Mar 15, 2017
- 198 (0.07/day)
Hi, guys.
I've got this PC, it's a bunch of my old parts thrown together, my parents use it. The bottleneck of the system is an old IDE HDD, it really slows down the entire PC to a crawl sometimes. I'm currently thinking about buying a cheap 60 GB chinese brand SSD from AliExpress to speed things up and breathe some life into the system.
The box in a nutshell:
Motherboard: EPoX EP-MF4 Ultra-3 - socket AM2, nForce4 Ultra chipset, SATA 3Gbps
CPU: Athlon 64 X2 5600+ (Brisbane)
RAM: 3 GB of DDR2 667
GPU: Radeon 4350 256 MB
HDD: WD 250 GB IDE
PSU: Seasonic 430W
Clearly not a speed demon by modern standards, but enough to get some browsing (my old man is a tab monster sometimes) and some office work done.
I poked around the BIOS and the SATA controller only works in Normal/RAID mode, no AHCI setting. I suddenly thought that I should abort the mission since stuff like NCQ and TRIM wouldn't work, but after doing some research I found out that TRIM should still be operational if enabled in the OS and I would very much like that to work. NCQ should still be a non-operational, but no one really notice the performance penalty.
My question goes out to people having done similar stuff: have you been successful, should I be expecting potential incompatibilities, pitfalls, problems? I looked around the net, but found nothing concrete or detailed enough to make up my mind.
Thanks in advance
HDD: WD 250 GB IDE
PSU: Seasonic 430W
Thanks in advance
