No sound from SPDIF
800 (0.13/day)
Processor Ryzen 7 5700X3D
Motherboard Asrock B550 PG Velocita
Cooling Thermalright Silver Arrow 130
Memory G.Skill 4000 MHz DDR4 32 GB
Video Card(s) XFX Radeon RX 7800XT 16 GB
Storage Plextor PX-512M9PEGN 512 GB
Display(s) 1920x1200; 100 Hz
Case Fractal Design North XL
Audio Device(s) SSL2
Software Windows 10 Pro 22H2
Benchmark Scores i've got a shitload of them in 15 years of TPU membership
Motherboard GA-890GPA-UD3H has a "SPDIF OUT". Whatever. What matters is that it is a digital output, so i connected it with a digital optical cable into the Logitech Z-5500 digital optical input and there is no sound...
Feeling quite stupid, what did i miss?
Does not the SPDIF OUT recognize an optical connection between the mobo and speakers? Perhaps the SPDIF OUT only works with coaxial cables?
You have to make sure output is set to "Spdif out" and not the regular green audio-out. SPDIF has no audio processing involved, its just a clean signal.
I was going to say "stick the cable in your ear" to check for sound :laugh:
But I digress! I will be trying the SPDIF on my PC to a dloby digital decoder and Klipsch 5.1 system, so that's good to know.
I forgot to reply.
The answer was simple:
All you have to do is disable some of the icons here and enable others.
