- Jan 31, 2009
- 25 (0.00/day)
- Northeast Ohio
System Name | HTPC / NKOST PC |
Processor | AMD Athlon 64 4800+ X2 Toledo Rev JH-E6 / AMD Phenom II X6 1100T |
Motherboard | MSI K8N-NEO2 Platinum (MS-7025) , Award bios 6.00pg v1.D / MSI 790FX-GD70 MS-7577 BIOS 1.16 |
Cooling | Thermaltake CL-P0200 w/fan A1357 / Thermalright Ultra 120 xtreme (air) Gentle typhoon 1850 rpm fans |
Memory | 2 x 1GB OCZ4001024ELPE (PC3200 2.8v) 2-3-2-7 / G.SKILL F3-12800CL6 7-8-7-23 1T |
Video Card(s) | HIS HD4670, AGP 1024MB GDDR3 - Cat 10.7 agp hot fix/ R6950 TFIII PE - Cat 11.12 |
Storage | WD1500ADFD (150GB SATA I), WD1001FALS (1TB) / OCZ Vertex3 120GB, WD7501AALS (750GB) |
Display(s) | Acer V223W 1680x1050, Sony WEGA KV-36XBR450 CRT 1920 x 1080i / ACER V223W (crappy) |
Case | Antec Performance One P-182 / Corsair Obsidian 650B |
Audio Device(s) | None (but I have SB X-FI Elite if I need it) / None - using mobo sound. |
Power Supply | PC Power & Cooling ATX-510 (510watt -650watt peak) + APC BACK-UPS XS800 / Corsair AX850 |
Software | WinXP PRO SP3, CCC 10.7 AGP Hotfix, NF3 ver 5.10/ Win7 PRO SP1 64bit, CCC 11.12,AMD790fx-sb750 |
Benchmark Scores | nothing worth mentioning. |
I just loaded v.26 but I don't see any temp settings...
I'm guessing the the AIW 9800 pro does not have sensors?
Heres the log..
2009-01-31 09:14:44 D Successfully connected to driver, version 130
2009-01-31 09:14:44 D Scanning for ATI VGA Cards...
2009-01-31 09:14:44 D Found ATI device: 0x1002 0x4E48 bus 1 dev 0
2009-01-31 09:14:44 D fbPhy: 0xE8000000, mmrPhy: 0xFDFF0000.
2009-01-31 09:14:44 D mmapped mmr to 0x8E70000
2009-01-31 09:14:44 D BIOS at 0xC0000
2009-01-31 09:14:44 D mmapped bios to 0x8E80000
2009-01-31 09:14:44 D LM63 temp chip detection: failed (0x0)
2009-01-31 09:14:44 D F75373 temp chip detection: failed (I2C)
2009-01-31 09:14:44 D Temperature monitoring: Not detected
2009-01-31 09:14:44 D Device initialized successfully
2009-01-31 09:14:44 D Scanning for NVIDIA VGA Cards...
2009-01-31 09:14:44 D Could not read driver's clock table: 2
2009-01-31 09:15:24 I Scan for Artifacts started... Core: 378.00 MHz Memory: 337.50 MHz
2009-01-31 09:15:24 I Scan for Artifacts running for: 0:00:00
2009-01-31 09:19:59 D Successfully connected to driver, version 130
2009-01-31 09:19:59 D Scanning for ATI VGA Cards...
2009-01-31 09:19:59 D Found ATI device: 0x1002 0x4E48 bus 1 dev 0
2009-01-31 09:19:59 D fbPhy: 0xE8000000, mmrPhy: 0xFDFF0000.
2009-01-31 09:19:59 D mmapped mmr to 0x8E70000
2009-01-31 09:19:59 D BIOS at 0xC0000
2009-01-31 09:19:59 D mmapped bios to 0x8E80000
2009-01-31 09:19:59 D LM63 temp chip detection: failed (0x0)
2009-01-31 09:19:59 D F75373 temp chip detection: failed (I2C)
2009-01-31 09:19:59 D Temperature monitoring: Not detected
2009-01-31 09:19:59 D Device initialized successfully
2009-01-31 09:19:59 D Scanning for NVIDIA VGA Cards...
2009-01-31 09:19:59 D Could not read driver's clock table: 2
2009-01-31 09:21:34 I Application terminated.
2009-01-31 09:22:51 D Successfully connected to driver, version 130
2009-01-31 09:22:51 D Scanning for ATI VGA Cards...
2009-01-31 09:22:51 D Found ATI device: 0x1002 0x4E48 bus 1 dev 0
2009-01-31 09:22:51 D fbPhy: 0xE8000000, mmrPhy: 0xFDFF0000.
2009-01-31 09:22:51 D mmapped mmr to 0x8E70000
2009-01-31 09:22:51 D BIOS at 0xC0000
2009-01-31 09:22:51 D mmapped bios to 0x8E80000
2009-01-31 09:22:52 D LM63 temp chip detection: failed (0x0)
2009-01-31 09:22:52 D F75373 temp chip detection: failed (I2C)
2009-01-31 09:22:52 D Temperature monitoring: Not detected
2009-01-31 09:22:52 D Device initialized successfully
2009-01-31 09:22:52 D Scanning for NVIDIA VGA Cards...
2009-01-31 09:22:52 D Could not read driver's clock table: 2
Can anyone offer a noob some help?
Ok, just scoured thru the forum and found a thread that talks about an
LM63 chip being required for temp readings with the ATITools... :-(
Looks like I'm out of luck here....
Is there anybody out there who can suggest some safe OC settings?
(it would be nice if I could safely boost its performance a little)
The card has a R350 core.
Core clock / mem clock 380 / 340
AGP Freq set to 67hz in bios
Voltage is 1.5v
MEM_TRCDRD 3
MEM_TRCDWR 3
MEM_TRP 3
MEM_TRAS 8
MEM_TRRD 4
MEM_TWR 2
MEM_TR2W CL+3
MEM_TW2R_SAME_BANK Use TWR Rule
MEM_TR2R 2
MEM_WR_LATENCY 1.0
MEM_MODE_REG 0x42
MEM_CAS LATENCY 4
MEM_CMD_LATENCY 0
MEM_STR_LATENCY WR Latency
MEM_REFRESH_RATE 0x29
MEM_TRFC 17
Heres the log..
Voltage is 1.5v
MEM_TRCDRD 3
MEM_TRCDWR 3
MEM_TRP 3
MEM_TRAS 8
MEM_TRRD 4
MEM_TWR 2
MEM_TR2W CL+3
MEM_TR2R 2
MEM_WR_LATENCY 1.0
MEM_MODE_REG 0x42
MEM_CAS LATENCY 4
MEM_CMD_LATENCY 0
MEM_TRFC 17
