nooby problems
jimbo
20 (0.00/day)
System Name Intel
Processor Intel Duo 2 Core E8500 @3.16mhz
Motherboard Gigabyte P45-DS4P
Cooling front, rear, side fans
Memory 2x2 gb Kingston DDR2
Video Card(s) Nvidia GTX260 896mb
Storage W.D 500 gb
Power Supply seasonic 650watt
Software Windows XP 32bit sp3
Gday, hope every1 had a good chrismas. I got a problem with the new system. Its only been a month and i already got a bluescreen error then auto reboot... i browse around, did some system checks havent specifically got an insight in what the problem is. I also notice under device manager that the
6to4 network adapter is not working(exclaimation mark).
Ran GPU-Z, core temp and rivatuner for temp check and notice the temps are much higher than when i first put the system together with XP (im now using vista).
before the gpu-z was running in the mid 30*C ,now its at high 40s for the GPU temp. The PCB temp use to be around 30s, now mid 40s.
are these teperatures normal?
Also, i tried to run atitool which i did could before but not anymore. I get an error that says "the kernel mode does not seem to be running".
Sorry bout the long rant, im a noob so any advise would be helpfull. Thanks all for reading.
1Kurgan1
The Knife in your Back
10,421 (1.74/day)
Duluth, Minnesota
System Name My Comp | Fiancees Comp
Processor i7 5820k @ 4.6Ghz 1.285v| i5 2500k
Motherboard MSI x99 SLI Plus | AsRock Z77 Pro 3
Cooling Watercooled
Memory 16GB DDR4 2400 @ 2666 | 12GB DDR3 1600
Video Card(s) AMD R9 290x | MSI 5850 OC
Storage 128gb SSD + 2x 2TB | 2TB
Display(s) Asus 27" LCD | 25" Hanns G
Case CM Storm | CM Elite 430
Audio Device(s) Creative Recon 3D PCIe
Power Supply Enermax Galaxy 1250W | Rosewill 630w
Mouse Logitech G700s | Logitech G100s
Keyboard Logitech G901 | Logitech G105
Software Win 8.1 Ultimate x64 | Win 8.1 Ultimate x64
Benchmark Scores 3D Mark - Fire Strike Extreme - 4403
53C at idle is fine for a videocard temp. But what the temp under load is what really matters.
Don't know what to say about the network adapter, update the drivers, I had some issues with mine dropping every now and then and that fixed it.
jimbo
20 (0.00/day)
System Name Intel
Storage W.D 500 gb
in addition ..i wanted to check the mobo temp so i ran easytune6 and speedfan and below is the screenshot...
On easytune, what is the system temp?
On speedfan, what are temp 1, 2, and 3?
Where do i find the mobo temp?..can some1 please suggest a tool i can use?
J-Man
2,248 (0.34/day)
Oakham, UK
System Name Watercooled beast
Processor Intel Core 2 Quad Q9550 @ 4.02GHz
Motherboard ASUS Rampage Formula X48
Cooling Swiftech Apogee GTZ, Black Ice GTX Xtreme 480, EK 250 Rev 2, EK 4870 X2, MCP655, 1/2" Tygon Tubing
Memory 4GB DDR2 OCZ @ 1066MHz 2.1V
Video Card(s) HIS ATI Radeon HD 4870 X2 800 on core, 1000 on memory (overclocked in CCC)
Storage 500GB Maxtor Diamondmax 22 SATA II 32MB Cache
Display(s) Samsung 24" SM245B
Case SilverStone TJ07 black/windowed version
Audio Device(s) Creative X-Fi Xtreme Gamer Fatal1ty + Logitech Z-5500
Power Supply Thermaltake Toughpower 1200W Modular
Software Windows Vista Ultimate 64-bit Retail
I idle at 48c with my 4870 x2 :rockout:
jimbo
20 (0.00/day)
System Name Intel
Storage W.D 500 gb
serious? on speedfan its got fire symbol next to it..when loaded i see more fire , im kinda panicing here..
