NTLDR is missing
sucka-free-sunday!
2 (0.00/day)
sc
First of all I can't tell you how many things I've tried getting my computer at least to install windows. Let me start by saying that COMP-USA doesn't help for crap unless you give them your life (and 100$ to cover if your life isn't covered by a money back guarentee). The first problem I have and willl probably have is the HARD ERROR: C0000221 problem before windows installs. Its been said that its most likely a RAM problem. Not in this case. I've tried 4 different brands of ram and thus far I've been told to stick with CORSAIR 512MB. The next thing is the NTLDR is missing - Press CTRL+ALT+DEL to continue. I'm using the overpraised Lanparty Sli-d. On startup the memory controller's IRQ is N/A?? BTW I put two 512's in my other Gateway and it's running sweeter than ever :). Whats the dillio?
The NTLDR is usually because windows is not installed, try setting the boot choice so that the comp boots from CD first, it has "usually" been this in my experience.
Gerry.
Yeah, also the hard drive may not be set up properly in the BIOS, if you set a hard drive to "no device" or equivalent in the BIOS you would think it would be like you didn't even connect it, but XP's installer will find the drive and install onto it, but when you do that first restart the BIOS won't boot from that drive because it's turned off.
Since you're getting the "NTLDR is missing" error I would guess you have 2 hard drives, one of them has a working master boot record and the other one has windows on it and is not set up in the BIOS.
Also, don't give up, DFI motherboards are awesome, I went ASUS because I wanted a fanless chipset but man I sure miss my Lanparty B
windows not installed
Changed the motherboard to a BFG nForce4 Ultra so I could get a few bucks off of my credit card :D. But i'm getting the same messages as before during windows install. (i only have one hdd, and this is first attempt to install xp pro sp2)
HARD ERROR: C0000221 when trying to install and error code 0x0000008e...:banghead:
have u tried a fresh reinstall as in did u wipe the drive or try to copy over the old files?
