Ntldr Missing Repair
FLYINHIGH
21 (0.00/day)
Processor AMD 165 oc'd to 2.5 (crap stepping)
Motherboard MSI K8N NEO4-F
Cooling Freezer 64 pro
Memory 2 gig of g skill
Video Card(s) DIAMOND X800GT0 256
Storage 200 maxtor/200 western digital
Display(s) sceptre 19 inch
Case MODDED ICUTE CASE
Audio Device(s) ONBOARD
Power Supply HYPER 580/630
a friend of mine has a 200 gig hd that gets the message ntldr missing on boot up. he says he will give it to me for free if i can fix it. I dont want to boot from it i just want it for a 2nd hd.when i hook it up i get the same message.
flyinhigh
check your bios boot order and make sure the bios will not try to boot off it
disconnect all your hdd's and reformat it mine did it to. to make it boot i had to restore the mbr. to stop it i had to reformat.
Hmm, plugged it in and made sure all the pins are right. when i hook it up the bios doesn't even see it. when its on the same cable as my main hd as slave the comp wants to boot from cd
Hook it up as the primary master with nothing else on the cable, and format it with a windows 98 boot disk.
http://bootdisk.com/bootdisk.htm/
Boot off the floppy, and once you get to the command prompt type "format c: /s"
If the bios wont see it as primary master, try a different cable. Some hard drives can be picky.
format drive
format the drive using the NTFS file system if you are loading win xp or 2000 pr as a blank drive
Sometimes software cant see a drive at all if its file system is severely fucked up. You have to format and start from scratch.
If your motherboard has a built in raid controller, see if you can do a low level format from that.
cool, i'll try that tonight after the poker game
is he overclocking? mine loses ntloader if i take the ram too high!
just an update, absolutly nothing worked on this HD, so i took it in to one of the com weanies at the base and told them it was a test of thier skill! lol. well even they couldn't get it to do anything so i went to the bx (where this was bought but we didn't have the dang reciept!) bought another one, waited an hour and returned the old one on the new receipt. now i have a new wd 200 gig that is running quite fine in my new system. thanks for all the help guys!
flyin
