Hello. I have recently found out about this tool and decided to use it. I used DDU to fully uninstall my NVIDIA graphics card driver to install a customized one created with this tool.
The graphics card is NVIDIA GeForce GT 740M and the latest driver (which I had previously downloaded and saved it somewhere and it was the driver I installed before finding out about this tool) for it is 425.31-notebook-win10-64bit-international-whql.
I used the recommended preset after choosing the aforementioned previously saved driver package without the PhysX installer bundled with it. I also used express installation, automatic reboot, message signaled interrupts, disable telemetry, automatically accept unsigned warning and the HD audio power timeout patch, none of which seem to have been applied.
The unable to verify driver publisher pop-up isn't accepted automatically despite the fact that I enabled the option for it.
The installer exits near the end with the error "Changing HD audio power timeout failed" but the main driver seems to be installed properly as I can use the NVIDIA control panel. It also doesn't automatically reboot.
I have tried to install through both the packaged and unpackaged setup files and the results were identical.
I would appreciate any help on this matter.
Regards, Staz.
Regards, Staz.
