(NVFLASH) Need Help Mismatch at Offset Error
Lionheart318
6 (0.01/day)
0mhz mem rate when using GPUz --- basically it has a custom vbios it appears and it has messed everything up on it (not my laptop originally). I need to flash it back to the original bios. I was able to copy the original from another exact same model but I am getting the following error in this pic after it goes to 100% on the flash and then says nothing changed! If it is important it is a Razer rtx 3080 laptop.
Error: Mismatch at offset 0x0000000000 - Expected value: 0X4E - Read back: 0xFF
Anyone have any insights on how to actually be able to finish the vbios update? Need a pro's help here getting that final step on letting it fully ignore that mismatch error at the end of the flash.
Are you sure the GPU is separate from the motherboard?
Most laptops have the GPU integrated to the motherboard, which means there is only one BIOS, Laptop/GPU BIOS in one, in that case you can only use BIOS'es from the laptop manufacturer.
This is the correct answer. You are going to have reflash the laptop BIOS.
Okay how do I force a reflash on a razer laptop bios? I downloaded the bios updated tool from Razer and it says its up to date.
Do you know of a way to force the bios to downgrade or reflash? I used the Razer bios updater tool and it says its already up to date.
Better ask Razer:
