System Name | PCGOD |
Processor | AMD FX 8350@ 5.0GHz |
Motherboard | Asus TUF 990FX Sabertooth R2 2901 Bios |
Cooling | Scythe Ashura, 2×BitFenix 230mm Spectre Pro LED (Blue,Green), 2x BitFenix 140mm Spectre Pro LED |
Memory | 16 GB Gskill Ripjaws X 2133 (2400 OC, 10-10-12-20-20, 1T, 1.65V) |
Video Card(s) | AMD Radeon 290 Sapphire Vapor-X |
Storage | Samsung 840 Pro 256GB, WD Velociraptor 1TB |
Display(s) | NEC Multisync LCD 1700V (Display Port Adapter) |
Case | AeroCool Xpredator Evil Blue Edition |
Audio Device(s) | Creative Labs Sound Blaster ZxR |
Power Supply | Seasonic 1250 XM2 Series (XP3) |
Mouse | Roccat Kone XTD |
Keyboard | Roccat Ryos MK Pro |
Software | Windows 7 Pro 64 |
is there a way to force flash bricked bios?
System Name | Americas cure is the death of Social Justice & Political Correctness |
Processor | i7-11700K |
Motherboard | Asrock Z590 Extreme wifi 6E |
Cooling | Noctua NH-U12A |
Memory | 32GB Corsair RGB fancy boi 5000 |
Video Card(s) | RTX 3090 Reference |
Storage | Samsung 970 Evo 1Tb + Samsung 970 Evo 500Gb |
Display(s) | Dell - 27" LED QHD G-SYNC x2 |
Case | Fractal Design Meshify-C |
Audio Device(s) | on board |
Power Supply | Seasonic Focus+ Gold 1000 Watt |
Mouse | Logitech G502 spectrum |
Keyboard | AZIO MGK-1 RGB (Kaith Blue) |
Software | Win 10 Professional 64 bit |
Benchmark Scores | the MLGeesiest |
hey man try help us find a solution instead of pushinig for my ban( show us your 19 years tweaking .perhaps u know something about the groundind pin method ??
By the way when I tweak its the motherboard, I don't mess with gpu bios flashes unless if I modify the original and cross verify it.
Processor | Intel Core i9 11900KF @ -.080mV PL max @220w |
Motherboard | MSI MAG Z490 TOMAHAWK |
Cooling | DeepCool LS520SE Liquid + 3 Phanteks 140mm case fans |
Memory | 32GB (4 x 8GB SR) Patriot Viper Steel Bdie @ 3600Mhz CL14 1.45v Gear 1 |
Video Card(s) | Asus Dual RTX 4070 OC + 8% PL |
Storage | WD Blue SN550 1TB M.2 NVME//Crucial MX500 500GB SSD (OS) |
Display(s) | AOC Q2781PQ 27 inch Ultra Slim 2560 x 1440 IPS |
Case | Phanteks Enthoo Pro M Windowed - Gunmetal |
Audio Device(s) | Onboard Realtek ALC1200/SPDIF to Sony AVR @ 5.1 |
Power Supply | Seasonic CORE GM650w Gold Semi modular |
Software | Win 11 Home x64 |
You see, you continue to derail this thread which is now about you and not the Op's issue so I will re-open your thread and get rid of your posts here, one thread is enough.no please tatty one, let it open , i need maximum visibility to get some information , i am really stuck
Too lateId lock him from this thread if possible
Hello, I spent all the afternoon trying to fix a wrong flash with a bad bios, tried dos command at boot, always appeared "no nvidia display adapter found"
My solution was to run nvflash in Windows safe mode, worked perfectly, if anyone may need this information, good luck.
