NVIDIA 940MX Fps Drop Problem
loranay47
10 (0.00/day)
I have fps drops in my lenovo ideapad 510 15isk laptop. Because GPU TEMP TARGET value in nvidia 940mx 4gb in all games. Frequency is dropping from 1006 mhz to 405 mhz so fps value is dropping 100-90 to 5-10 fps . Sorry for my english. I have 12gb ram , intel i5 6200U 2.70GHZ , 1tb hdd , nvidia 940mx 4gb.
43,629 (6.36/day)
Memory 64GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD/Samsung m.2's
Display(s) LG C2 Evo OLED 42"
Case Fractal Design North
Mouse Razer Basilisk V3 Pro
Keyboard Epomaker 84 key
It's overheating and needs to be serviced/maintained.
loranay47
10 (0.00/day)
No , I sent two times to the service. This is software problem. because GPU TEMP TARGET value. When Nvidia gpu in 61 degress , I have this problem and All ideapad 510 15isk users are have this problem. I think maybe we will fix with a new bios or vbios . For you how we will fix ?
44,274 (6.80/day)
Your card is weak through and through and a bios update will just break your card, so get that thought out of your head if you know what's good for you.
Lower your game details and resolutions or buy a true laptop for gaming, that thing won't cut the mustard.
loranay47
10 (0.00/day)
Your card is weak through and through and a bios update will just brick your card. Lower your game details and resolutions.
We said lenovo for a new bios update but Lenovo does not update . How we will make bios mod or a different thing ?
44,274 (6.80/day)
On a laptop you don't, as they are proprietary and are meshed with the laptop motherboard bios.
Stop asking for a bios update, it wont change your frames per second on an already weak Mobility Graphics Processing Unit. There is your answer.
dorsetknob
9,106 (1.24/day)
Means nothing I have worked in Service Shop and Believe me some will just go thru the motions and get the item out the door as fast as possable as long as it passes a Cursory QC check
Please Run GPUz so the temps can be verified.
9,781 (2.14/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
Mouse Logitech G502 spectrum
5,731 (1.04/day)
West Midlands. UK.
System Name Ryzen Reynolds
Cooling Raijintek Leto Pro
Power Supply Corsair VS 550w
Mouse Zalman ZM-M401R
Keyboard Razor Lycosa
Your core clock didn't throttle on that gpu-z screenshot, run a game and leave gpu-z running in the background and exit the game, take a screenshot of the gpy-z values so we can see what's going on
loranay47
10 (0.00/day)
I checked. After 15 minutes . gpu temp was 61 degress. and I have frequency drop. 1006 mhz to 405 mhz .
9,781 (2.14/day)
Massachusetts
Processor i7-11700K
just post a screenshot of your sensors tab with around 10 minutes of activity so everyone can see the readings
287 (0.06/day)
Chisinau, Moldova
System Name Winter Heater
Processor Intel Core I7 5820k@4250 Mhz
Motherboard ASUS x99 Deluxe
Cooling Cryorig H5
Memory 2x4GB Corsair Vengeance DDR4 + 2x4GB Kingston HyperX DDR4 @ 3000Mhz
Video Card(s) OEM GTX 970
Storage Seagate ST4000VN000, Hitachi 2TB, Crucial CX500 1TB
Display(s) LG 23EA63
Case Thermaltake Versa N21
Power Supply EVGA 650 GQ
I think what he means is the default thermal throttle temp target is 90 degrees but his is set to 61 and he is looking for some way to increase it.
5,731 (1.04/day)
West Midlands. UK.
Afterburner will allow you to increase the temperature limit afaik
9,781 (2.14/day)
Massachusetts
Processor i7-11700K
yeah, thats what i was just working on posting.
@loranay47
here with 79c limit
then slide the limit up in Afterburner, and , 91C temp limit. but that lappy likely wont love that change
loranay47
10 (0.00/day)
I'm understanded. But I can't change this value with a overclocking program because not allowed
5,731 (1.04/day)
West Midlands. UK.
Not allowed by who/what? Are you not able to run afterburner?
541 (0.17/day)
System Name Gaming PC / I7 XEON
Processor I7 4790K @stock / XEON W3680 @ stock
Motherboard Asus Z97 MAXIMUS VII FORMULA / GIGABYTE X58 UD7
Cooling X61 Kraken / X61 Kraken
Memory 32gb Vengeance 2133 Mhz / 24b Corsair XMS3 1600 Mhz
Video Card(s) Gainward GLH 1080 / MSI Gaming X Radeon RX480 8 GB
Storage Samsung EVO 850 500gb ,3 tb seagate, 2 samsung 1tb in raid 0 / Kingdian 240 gb, megaraid SAS 9341-8
Display(s) 2 BENQ 27" GL2706PQ / Dell UP2716D LCD Monitor 27 "
Case Corsair Graphite Series 780T / Corsair Obsidian 750 D
Audio Device(s) ON BOARD / ON BOARD
Power Supply Sapphire Pure 950w / Corsair RMI 750w
Mouse Steelseries Sesnsei / Steelseries Sensei raw
Keyboard Razer BlackWidow Chroma / Razer BlackWidow Chroma
Software Windows 1064bit PRO / Windows 1064bit PRO
try to cool down your laptop with some fans to put on bottom
5,731 (1.04/day)
West Midlands. UK.
5,731 (1.04/day)
West Midlands. UK.
I'm sure you need to unlock overclocking, voltage/temp in settings?
loranay47
10 (0.00/day)
Yes . I said lenovo but lenovo is don't make new bios update or vbios update.
23,888 (6.16/day)
No, you can check your Precision X settings to see if you can tick a box to 'unlock' these sliders. You are not in the BIOS when you use Precision X.
My guess however is that while it may be possible, it is unlikely to even have an effect and is locked down within BIOS entirely. Here is how it looks in MSI Afterburner (if you cant find it in precision, delete the application and google for MSI Afterburner instead, its much easier to use).
Specifically: tick Enable Hardware control and monitoring, low-level IO Driver, low-level hardware access interface.
Bottom line: what @eidairaman1 said. Don't bother. Get a proper GPU
loranay47
10 (0.00/day)
I selected but don't allow retry.
23,888 (6.16/day)
Yeah then its a lost case. If your GPU doesn't work as advertised and you have warranty, try that route, other than that, no dice
I will say this, I have had midrange 'gaming' laptops on a budget before and each and every one of them has shown similar behaviour. Its just throttling heavily, crappy cooling + badly balanced GPU + even the CPU may throttle as well.
