NVidia Control Panel problem..
30,531 (7.07/day)
Is anyone else having problems with the current(546.33) drivers failing to install the control panel in Windows 10/11? Been having issues for a few weeks now.
18,584 (2.63/day)
System Name AlderLake
I'm still running 536.67, no issues..
Try 536.67 or any older driver if you don't need to use a game specific driver.
1,710 (0.52/day)
System Name The Blind Grim Reaper
Processor Xeon X5675 Westmere-EP B1 SLBYL 4.20ghz @ 1.256v
Motherboard Asus P6X58D-E
Cooling Noctua CP12 SE14, Redux Noctua 1500rpm fan Arctic F14 x3 for intake and exhaust
Memory Corsair XMS3 CMX4GX3M2A1600C9 x6
Video Card(s) EVGA GTX 1060 6GB SC Single Fan Model
Storage Crucial mx300 750gb main system + 1TB mx500 for games and music
Display(s) 22 inch samsung curved
Case NZXT Phantom 530 black
Audio Device(s) Nvidia HDMI through HDMI adaptor for output sound for turtlebeach x12 headset
Power Supply Antec HCG 850 watt
Mouse no brand
Keyboard normal usb keyboard
Software Windows 10 22H2 v1 (main is) and Windows 11 22H2 v2 on WD 250gb 7200rpm (testing purposes os)
Benchmark Scores Cinebench R20 = 2046cb
Don't forget that you see there is two version of the nvidia control panel one is dch version and one is the regular you have download the NVIDIA control panel using windows store app if you are using the dch version.
Since I haven't had any issues using the dch version a few months ago
2,003 (0.55/day)
Seattle, WA
Just did a fresh install of 546.33 on a fresh Win10 22H2 and it failed to install the control panel, told me it failed in the log, and on restart it popped up a notification to grab it from Win Update. Also getting some pretty nasty crashes on Baldur's Gate 3 with the newest driver, so going to just roll back.
30,531 (7.07/day)
That's exactly what it's been doing here. What version did you go back to?
2,003 (0.55/day)
Seattle, WA
Well I tried 537.58 but upon installing the driver it has now destroyed the Start menu, and NVIDIA Control Panel is still absent. Seemingly since 526 the control panel is no longer included in the install. Not sure why this broke the Start menu but that may be unrelated? Was working fine before I rolled back with a clean install.
30,531 (7.07/day)
?!? Weird! I did not experience that one.
WTH?!? Are they doing that "force everyone to the store" crap again?
It could also be a serious glitch.
EDIT:
I'm trying a fresh install again with 537.58. Will try 526.98 after that.
EDIT2:
Both of the above versions failed but 532.03 seems to work fine. So maybe 532.03 was a cut-off?
8,311 (5.24/day)
São Paulo, Brazil
Cooling Pichau Lunara ARGB 360 + Honeywell PTM7950
Memory 32 GB G.Skill Trident Z5 RGB @ 7600 MT/s
Video Card(s) Palit GameRock GeForce RTX 5090 32 GB
Storage 500 GB WD Black SN750 + 4x 300 GB WD VelociRaptor WD3000HLFS HDDs
Display(s) 55-inch LG G3 OLED
Case Cooler Master MasterFrame 700 benchtable
Mouse Microsoft Classic IntelliMouse
Software Windows 10 Pro 22H2
Works on my machine™, I wonder what happened to you?
Just a heads up, this is no longer applicable. Standard model drivers are no longer released. They stopped them with the r470 branch alongside Kepler and Windows 7 support. All driver releases since that have been exclusively of the DCH type.
Oddly enough this can occur because of GPU drivers, I've had this before with the AMD driver. At the time I also found a "fix" for it (until it happened again), and that was to do a full restart through the command prompt by shutdown -r -t 0, this being valid even if you have fast startup disabled. Something about using shutdown and normally restarting must differ because by doing the latter, the problem persisted.
462 (0.10/day)
France
Processor i7 12700K
Motherboard MSI PRO Z690-A WIFI DDR4
Cooling Noctua NH-U14S
Memory G.Skill Ripjaws V 32GB 4400Mhz CL19 1T
Video Card(s) AMD Radeon 6700 XT
Storage 970 EVO 250GB|Crucial m4 128GB|MX300 525GB|MX500 1TB|PNY XLR8 2TB|Kingston NV2 2TB|14TB HDD|4TB HDD
Display(s) Acer XG270HU 27" 1440p 144Hz
Case Fractal Design DEFINE R4 Black Pearl Window
Mouse Razer Naga Trinity
Keyboard EVGA Z15 RGB Mechanical Gaming Keyboard
Software Windows 11 Pro 64bit
DCH version on my laptop and the control panel works fine on Windows 11 here.
Maybe try a clean install (the driver's option, not any third party thing like DDU) then use the Microsoft Store to install the control panel ?
If it doesn't work or if you've put to much "personal security" in your Windows settings you can try :
CMD admin : SFC /scannow
THEN
DISM /Online /Cleanup-Image /CheckHealth
DISM /Online /Cleanup-Image /ScanHealth
DISM /Online /Cleanup-Image /RestoreHealth
Reboot and see, if it's still broken, reinstall with the clean install ticked and get the control panel again from the Store.
196 (0.19/day)
My bet is on a piece of background software halting/screwing the installation.
As one of many examples:
FanControl does not play nice if it gets auto-started whilst installing NVIDIA drivers
889 (0.25/day)
System Name Harm's Rig's
Processor 5950X /2700x / AMD 8370e 4500
Motherboard ASUS DARK HERO / ASRock B550 Phantom Gaming 4
Cooling Arctic Liquid Freezer III 420 Push/Pull -6 Noctua NF-A14 i and 6 Noctua NF-A14 i Meshify 2 XL
Memory CORSAIR Vengeance RGB RT 32GB (4x16GB) DDR4 4266cl16 - Patriot Viper Steel DDR4 16GB (4x 8GB)
Video Card(s) ZOTAC AMP EXTREME AIRO 4090 / 1080 Ti /290X CFX
Storage SAMSUNG 980 PRO SSD 1TB/ WD DARK 770 2TB , Sabrent NVMe 512GB / 1 SSD 250GB / 1 HHD 3 TB
Display(s) Thermal Grizzly WireView / TCL 646 55 TV / 50 Xfinity Hisense A6 XUMO TV
Case Meshify 2 XL- TT 37 VIEW 200MM'S-ARTIC P14MAX
Audio Device(s) Sharp Aquos
Power Supply Seasonic Prime TX-1600 ATX3.1 | Fully FSP Hydro PTM PRO 1200W ATX 3.0 PCI-E GEN-5 80 Plus Platinum -
Mouse G502 - PS5 DualSense
Keyboard G413-PS5 DualSense
No issues with 11.
30,531 (7.07/day)
Fresh install, nothing else is installed.
The ms store is not accessible and installing from the store is not an option. The NVidia control panel should be included with the drivers.
So as stated above in an edit, 532.03 installed without issue. Nothing later worked.
@ Nvidia
WTAF?!? Try to remember, some systems do NOT have access to the microsoft store and in some cases, the internet. The control panel is a required part of the drivers for your products. It needs to ALWAYS be included with the drivers to account for such use-case-scenarios. You can not assume internet access or access to the ms store will always be available or allowed.
2,336 (4.40/day)
Nowhere
Processor 14700K
Motherboard Asus TUF Z790
Cooling Air/water/DryIce
Video Card(s) RTX 4070 Super
Storage 980 Pro
Display(s) 1080P 144hz
Case Open bench
Keyboard Logitech G910
VR HMD Quest 2
Software Windows
Control panel?? For what? Don't even install it.
Use NVidia Inspector for OC.
Use NVidia Profile Inspector for your graphics adjustments.
Thank me later :)
8,311 (5.24/day)
São Paulo, Brazil
It is included and is extracted at C:\NVIDIA\DisplayDriver\546.33\Win11_Win10-DCH_64\International\Display.Driver\NVCPL\1b860afc09e945aea8b23a02423446e6.appx
But if you disabled appx support entirely on your machine then it will not work
3,277 (6.30/day)
System Name The Workhorse
Processor AMD Ryzen R9 5900X
Storage Adata SX8200Pro
Display(s) LG 32GK850G
Software Windows 11 Pro (24H2)
Then your best bet is to create a package of a desired driver version via NVCleanstall. That should work just fine. Unless, as noted above, you completely killed UWP support somehow, which seems unnecessary.
Thank me later :)
It’s kinda necessary if one wants to use GSync/GSync compatibility properly or wants access to stuff like DLDSR or NVidias decent frame limiter without a hassle. Running an NVidia GPU without the CP is inane. The Inspector is an additional useful tool, not a replacement.
2,336 (4.40/day)
Nowhere
Processor 14700K
Storage 980 Pro
Case Open bench
VR HMD Quest 2
Software Windows
That should all be in profile inspector. As well as forcing SLI and so forth.
3,277 (6.30/day)
It is, but it’s clunky and I am not sure if it properly integrates with VRR optimizations that MS added in 10 and especially 11. Again, this is jumping through hoops for absolutely no reason. The Inspector should be used if you want to do something specific to a specific app, not as an overall control interface for GPU features. It was never made to be one. But if you want to tinker and micromanage everything - be my guest.
487 (0.20/day)
Jakarta, Indonesia
System Name PC-GX1
Processor i9 10900 non K (stock) TDP 65w
Motherboard asrock b560 steel legend | Realtek ALC897
Cooling cooler master hyper 2x12 LED turbo argb | 5x12cm fan rgb intake | 3x12cm fan rgb exhaust
Memory corsair vengeance LPX 2x32gb ddr4 3600mhz
Video Card(s) MSI RTX 3080 10GB Gaming Z Trio LHR TDP 370w| 572.16 WHQL | MSI AB v4.65 | RTSS v7.36
Storage NVME 2+2TB gen3| SSD 4TB sata3 | 1+2TB 7200rpm sata3| 4+4+5TB USB3 (optional)
Display(s) AOC U34P2C (IPS panel, 3440x1440 75hz) + speaker 5W*2 | APC BX1100CI MS (660w)
Case lianli lancool 2 mesh RGB windows - white edition | 1x dvd-RW usb 3.0 (optional)
Audio Device(s) Nakamichi soundstation8w 2.1 100W RMS | Simbadda CST 9000N+ 2.1 88W RMS
Power Supply seasonic focus gx-850w 80+ gold - white edition 2021 | APC BX2200MI MS (1200w)
Mouse steelseries sensei ten | logitech g440
Keyboard steelseries apex 5 | steelseries QCK prism cloth XL | steelseries arctis 5
VR HMD -
Software dvd win 10 home 64bit oem + full update 22H2
Benchmark Scores -
double check your anti virus/firewall/internet security when installing new nvidia driver.
9,340 (4.93/day)
Louisiana
Keyboard G710+x3
Still on 546.17 on 11 so thanks for the warning :cool:
I used nvclean and got it just using recommended.
30,531 (7.07/day)
Tried that, it refused to install.
Support is still present, but access to the internet isn't.
There isn't one. Again, fresh install.
The process is:
1. Install Windows
2. Install hardware drivers
Nothing else is done.
3,277 (6.30/day)
Okay, then the NVCleanstall method will definitely work, you just need to create a package on a machine with internet access and take it to the one you’re trying to install on. I just recently installed my drivers in this way and it just worked. The internet cable was unplugged during the whole thing.
If you don’t have a spare PC with connection to the net, then this is a bit trickier.
9,340 (4.93/day)
Louisiana
Keyboard G710+x3
The process is:
1. Install Windows
You might need to get the package with nvclean then seeing you're installing without internet.
2,336 (4.40/day)
Nowhere
Processor 14700K
Storage 980 Pro
Case Open bench
VR HMD Quest 2
Software Windows
Of course. That's what it's designed for.
Though I'm sure if clunky I'd a good description. I've never had an issue optimizing with profile inspector. There are older versions that won't work well with newer cards, so that matters too.
Just trying to give alternatives.
@lexluthermiester, have you updated your fresh installation? W11 right?
30,531 (7.07/day)
Let me try that. I'll chime back in momentarily.
Again, no internet for the systems in question. However, it is the 23H2 version of 11, but as this was also happening on Windows 10 it's very unlikely to be a Windows problem.
