- Nov 27, 2023
- 3,274 (6.31/day)
System Name | The Workhorse |
Processor | AMD Ryzen R9 5900X |
Motherboard | Gigabyte Aorus B550 Pro |
Cooling | CPU - Noctua NH-D15S Case - 3 Noctua NF-A14 PWM at the bottom, 2 Fractal Design 180mm at the front |
Memory | GSkill Trident Z 3200CL14 |
Video Card(s) | NVidia GTX 1070 MSI QuickSilver |
Storage | Adata SX8200Pro |
Display(s) | LG 32GK850G |
Case | Fractal Design Torrent (Solid) |
Audio Device(s) | FiiO E-10K DAC/Amp, Samson Meteorite USB Microphone |
Power Supply | Corsair RMx850 (2018) |
Mouse | Razer Viper (Original) on a X-Raypad Equate Plus V2 |
Keyboard | Cooler Master QuickFire Rapid TKL keyboard (Cherry MX Black) |
Software | Windows 11 Pro (24H2) |
Hello, TPU community! After being an avid reader for more than a decade I finally decided to make a forum account now that I have run into an issue that, frankly, stumps me.
A day ago, I decided to update the driver for my venerable 1070 from the 528 branch (still waiting for a decent upgrade option that doesn't cost a kidney) and went through my usual process - NVcleanstall, latest driver, just the GPU driver+PhysX and no complex tweaks apart from no ads and telemetry in installer and MSI mode. Clean install in the NVidia setup itself. All went well. No issues with the update. The interesting thing started to happen when I rebooted and went into the NVCP itself. All settings (resolution, GSync, 3D settings) applied and saved just fine. However, the setting in color management which I make quite a lot of use of "Override to Reference mode" applies in the OS just fine... but when I shut down my PC and then couple of hours later booted up again and checked on a whim (a little OCD of me, but oh well) the setting reset. Only this setting, nothing else. I started digging. On the reset from OS the setting DID remain applied. However, on a cold boot (so after shut down) it reset again.
Alright, I thought, maybe the driver is messed up a bit. Went to the thread for the latest release on Reddit and sure enough, 546.17 and overall the entire 545 branch is plagued with issues and most people consider that 537.58 is the latest "stable" version. Fair enough. I decided to do a clean install. Usual steps were applied, so NVCleanstall to download and create a package of 537.58 with the same parameters and tweaks as described above, remove the Ethernet cable, boot into Safe Mode, DDU to clean up, boot into normal Windows 11, setup the driver from the package, done. Again, all is fine... but the color settings still reset. Moreover, now the behaviour changed slightly and it resets on EVERY boot, even on reset from OS, not just from shut down.
I tried both of the potential solutions floating around the web:
1. Turning off the Windows Color Management from Task Scheduler. That did not solve it.
2. Turning off Windows Calibration in Color Management System Defaults. It was already off and so re-checking it and un-checking did not do anything.
Frankly, I am at a loss. I have no idea what can cause this behaviour. The setting in the old driver worked just fine, but it should be noted that I have turned it on when I installed it (early summer, I believe) and never switched it back and forth again. Since then, 23H2 update rolled out and I have my suspicion that it may have something to do with it. After all, MS allegedly added the ACM (Automatic Color Management) to the OS with it. It isn't active on my system, there is no toggle for it in the Advanced Display settings, so I am not sure if that's the case, but I would not put it past MS to somehow still override other color controls even when ACM is not in play.
Anyway, I would love to hear any suggestions on how it may be fixed and to hear from other NV users on 23H2 if their system displays similar behaviour just to compare notes. My specs are in the profile and the Win11 is on the latest stable branch build 22631.2715.
