NVIDIA GeForce RTX 3060 Ti with GDDR6X to Replace Standard Model with GDDR6
47,657 (7.43/day)
NVIDIA recently updated its product stack with an 8 GB 128-bit GDDR6 variant of the GeForce RTX 3060 (originally 12 GB 192-bit GDDR6), and the RTX 3060 Ti with faster 19 Gbps 256-bit GDDR6X memory (originally 14 Gbps 256-bit GDDR6). We're getting to learn that the new RTX 3060 Ti GDDR6X variant is designed to replace the older GDDR6 variant. NVIDIA's add-in card (AIC) partners are reportedly winding down orders of the original RTX 3060 Ti in favor of the newer GDDR6X variant. Perhaps the most striking aspect of the GDDR6X variant isn't that its memory bandwidth is 35% higher than that of the original RTX 3060 Ti; but that it sells at the same price.
The new GeForce RTX 3060 Ti GDDR6X is based on the 8 nm "GA104" silicon, and has the same core-configuration as the original RTX 3060 Ti, with 4,864 CUDA cores, 152 Tensor cores, 38 RT cores, 152 TMUs, and 80 ROPs; the same GPU boost frequency of 1665 MHz, and interestingly, the same typical board power of 200 W. What's changed is the switch to 19 Gbps GDDR6X memory compared to the original's 14 Gbps GDDR6, which results in a memory bandwidth of 608 GB/s, compared to the original's 448 GB/s.
63 (0.07/day)
Processor Ryzen 5 5500
Motherboard ASUS Prime B450-Plus
Cooling 3x Inwin Saturn AS120 + 1x Aerocool Standard
Memory 2x8 GB XPG D50 3200 MHz - CL15
Video Card(s) Gigabyte Gaming OC RX 6600 XT
Storage WD Blue SATA SSD 1TB + 500GB Hitachi HDD
Display(s) GAMEON 144hz IPS 1080p
Case Aerocool Rift Tempered Glass
Power Supply MSI MAG A550BN
So now all benchmarks of the 3060 Ti are invalid?? How do I know if the 3060 ti i get is gddr6 or gddr6x when the retailer most certainly wont tell me?? NVIDIA makes a 4080 12GB, says it must be removed due to its confusing name, then releases a 3060 Ti GDDR6X thats faster than the vanilla 3060 Ti? At this point call it a 3060 Super..
554 (0.34/day)
Processor Ryzen 5 7600X
Motherboard ASRock B650M PG Riptide
Memory DDR5 6000Mhz CL28 32GB
Video Card(s) Nvidia Geforce RTX 3070 Palit GamingPro OC
Storage Corsair MP600 Force Series Gen.4 1TB
Dont worry, it won't perform better, just the power consumption will be higher ;)
2,451 (1.17/day)
LV-426
System Name Custom
Processor i9 9900k
Cooling corsair h150i
Memory 4x8 3200mhz corsair
Display(s) MSi MAG341CQ
Case Lian Li Pc-011 Dynamic
Mouse Logitech G403
Keyboard Logitech G110
makes me wonder if theres gonna be a 4060 for the 40 series
5,814 (0.98/day)
System Name Cyberline
Mouse Elecom EX-G
Keyboard Rapoo V700
But....why?
2,201 (0.49/day)
Deez Nutz, bozo!
System Name Rainbow Puke Machine Reborn :D
Video Card(s) ASRock ARC B580 Challenger 12GB (Stock)
Software Tweaked Windows 11 Professional x64 (Update 24H2) OS
just... why? ==
2,305 (1.20/day)
System Name GrandadsBadAss
Display(s) Acer XG270HU
Keyboard Roccat Vulcan Aimo
Software Win 10/11pro
Next it'll get pulled altogether cuz memory supply dries up...
1,814 (0.98/day)
Over the Hill UK
System Name AMDWeapon
Case Montech 903 MAX AIR
VR HMD -
Software Windows 11 Pro 24H2
Is this a good thing or not? Faster=better, yes? Then they should be commended for doing something good. But then again, they've just alienated all the 3060 Ti non-GDDR6X owners. And why now, of all times?
311 (0.20/day)
System Name Office,Home and Game PC
Processor Intel Core i5 12600k Up to 4.9 GHz
Motherboard Z690 Gaming X Gigabyte DDR4 Version
Cooling Fuma 2 Air Cooler
Memory 32GB DDR4 2x16 3600 MHz Patriot Viper Steel RAM
Video Card(s) NVIDIA GeForce GTX 1080 and RTX 3070
Storage 512 GB M2 PCI Ex 3.0 NVMe SX6000 Pro, 1TB NV2 Kingston M2 PCI Ex 4.0 and 4TB WD Blue SATA 3.0 HDD
Display(s) 27 inç 75 Hz LG
Case Cooler Master MB511
Audio Device(s) Creative 2+1
Power Supply 750W 80+ Bronze PSU High Power Element
Mouse Logitech Wireless
Keyboard Microsoft
VR HMD N/A
Software Windows 10-11
With a good overclock, it can reach the RTX 3070 level. But what happens to the power consumption is important.
Fourstaff
10,091 (1.79/day)
Home
Processor 3570K // 10400F
Cooling Stock // Stock
But....why?
They probably have an oversupply of 3060Ti chips, but signed a contract to buy lots of GDDR6X? Hazarding a guess here.
3,842 (2.66/day)
Processor Ryzen 5 5700x
Motherboard B550 Elite
Power Supply MSI 750w
Mouse G502
they will, it will be on the box and the specs, i can guarantee you that because i owned one 1060 gddr5x. This has happened in the past already with the 1060 gddr5x and all the boxes mentioned it.
You either don't know or care and get whatever and be happy, or you do know and care and just pick the better one.
302 (0.29/day)
Germany
System Name Galaxy Tab S8+
Processor Snapdragon 8 gen 1 SOC
Cooling passive
Memory 8 GB
Storage 256 GB + 512 GB SD
Display(s) 2.800 x 1.752 Super AMOLED
Power Supply 10.090 mAh
Software Android 12
In memory reliant benchmarks you should be able to see measurable differences. :) And not to forget: You get a free of charge "X".
214 (0.14/day)
This, also it was done more recently with the GTX 1650 GDDR6.
Actually the GTX 1650 became more genuinely confusing when they released models based on cut down TU106/116 chips, which featured the Turing encoder instead of the Volta one used in TU117, you had to check this bit in the specs sheet, it wasn't mentioned on the box.
3,842 (2.66/day)
Mouse G502
that is easy to see why:
more performance/features: clearly visible mention in the box
less performance/features: forget to put it visible in the box
mistakes happen :D
214 (0.14/day)
mistakes happen :D
But the Turing encoder offers better performance compared to Volta, maybe it's just that less people care about it.
3,842 (2.66/day)
Mouse G502
yep, now that i think of it they also mentioned the 3Gb on the 1060. I guess it's random.
184 (0.05/day)
5-10% faster depending on the game for a massive increase in power consumption if the 3070 Ti is anything to go by. And it is, since it's the same GPU. If anything you'd expect the cut-down version in the 3060 Ti to benefit even less, given it has far less CUDA cores to feed. Personally, I'd prefer to keep the far better power efficiency.
64K
6,773 (1.67/day)
Processor i7 7700k
Motherboard MSI Z270 SLI Plus
Cooling CM Hyper 212 EVO
Keyboard Logitech G105
Don't buy the Turdings. It's a just a Nvidia way to lose less money with the Ada on the stack waiting.
3,842 (2.66/day)
Mouse G502
Who cares about that, all it matters is if the price performance is any good.
532 (0.26/day)
IMHO they know they are going to be hurting in the low end of video cards in the near future.
IMHO this is very telling of what their marketing and product strategy and with that you are not going to see any FANTASTIC video cards coming from them. Just refreshes and expensive video cards.
Let me put it to you this way.... DOES THE 4090 @$2400 (S/H) does 8 times the performance in 1080p and 1440p of my 5700XT which I bought NEW for $300.00??? HELL NO! The majority of the world runs on 1080/1440p. And those are the facts.
The Ngreedia Greenie Meenies will buy them. Smart people won't and I hope the investors start shaking Leather God Lord Gonzo's tree for this failure of managing a corporation at this time period.
That's all that I see. Expensive Video cards that are way overpriced for what you get
4,899 (2.75/day)
System Name Mean machine
Processor AMD 6900HS
Memory 2x16 GB 4800C40
Does your 5700xt offer 3 times the performance of the rx580 that i bought for 100$ new? HELL NO. Amd redie meenies bought the 5700xt,smart people didn't.
694 (0.41/day)
Greece
System Name Office / HP Prodesk 490 G3 MT (ex-office)
Processor Intel 13700 (90° limit) / Intel i7-6700
Motherboard Asus TUF Gaming H770 Pro / HP 805F H170
Cooling Noctua NH-U14S / Stock
Memory G. Skill Trident XMP 2x16gb DDR5 6400MHz cl32 / Samsung 2x8gb 2133MHz DDR4
Video Card(s) Asus RTX 3060 Ti Dual OC GDDR6X / Zotac GTX 1650 GDDR6 OC
Storage Samsung 2tb 980 PRO MZ / Samsung SSD 1TB 860 EVO + WD blue HDD 1TB (WD10EZEX)
Display(s) Eizo FlexScan EV2455 - 1920x1200 / Panasonic TX-32LS490E 32'' LED 1920x1080
Case Nanoxia Deep Silence 8 Pro / HP microtower
Audio Device(s) On board
Power Supply Seasonic Prime PX750 / OEM 300W bronze
Mouse MS cheap wired / Logitech cheap wired m90
Keyboard MS cheap wired / HP cheap wired
Software W11 / W7 Pro ->10 Pro
1)Early benchmarks show a 7+% performance uplift.
2)If we invoke a recent example, 1650 gddr6 non-S comes with slightly lower clocks compared to the initial gddr5 version (probably to retain the same consumption) and the memory type is usually obvious on the box.
5,814 (0.98/day)
Mouse Elecom EX-G
Keyboard Rapoo V700
Where the hell did you get a rx580 for 100 dollars?!?
632 (0.17/day)
Processor AMD Ryzen 3800X / AMD 8350
Motherboard ASRock X570 Phantom Gaming X / Gigabyte 990FXA-UD5 Revision 3.0
Cooling Stock / Corsair H100
Memory 32GB / 24GB
Video Card(s) Sapphire RX 6800 / AMD Radeon 290X (Toggling until 6950XT)
Storage C:\ 1TB SSD, D:\ RAID-1 1TB SSD, 2x4TB-RAID-1
Display(s) Samsung U32E850R
Case be quiet! Dark Base Pro 900 Black rev. 2 / Fractal Design
Audio Device(s) Creative Sound Blaster X-Fi
Power Supply EVGA Supernova 1300G2 / EVGA Supernova 850G+
Mouse Logitech M-U0007
Keyboard Logitech G110 / Logitech G110
Sniper Elite 5 was using as much as 15.7GB of the 16GB on my RX 6800 at 1440p maxed. You don't need faster memory, you need MORE memory! All the issues with m 4GB 290X just stopped when I got this card. A lot of games can get away with 8GB and even 6GB but not all. Unless of course you want to turn down the quality if you're just not getting performance.
AliExpress :nutkick:
Yeah, Sapphire RX 6800XT for $478 on Ali Express and $660 on Amazon. However it's a month shipping from China from Ali Express and I didn't look at how much the shipping would cost. I'm happy with my Sapphire RX 6800, 4GB on my 290X was just pathetic in 2022 with my browser alone easily using 3.5GB+.
