NVIDIA GPU with freesync premium pro
9,828 (3.40/day)
System Name Best AMD Computer
Processor AMD 7900X3D
Cooling In Win SR36
Display(s) GIGABYTE FV43U
Case Corsair 7000D Airflow
Power Supply Deepcool 1000M
Keyboard Logitech G510
It will work
562 (0.27/day)
Processor i9-9900K @ 5.1GHz (H2O Cooled)
Motherboard Gigabyte Z390 Aorus Master
Cooling CPU = EK Velocity / GPU = EK Vector
Memory 32GB - G-Skill Trident Z RGB @ 3200MHz
Video Card(s) AMD RX 6900 XT (H2O Cooled)
Storage Samsung 860 EVO - 970 EVO - 870 QVO
Display(s) Samsung QN90A 50" 4K TV & LG 20" 1600x900
Case Lian Li O11-D
Audio Device(s) Presonus Studio 192
Power Supply Seasonic Prime Ultra Titanium 850W
Mouse Logitech MX Anywhere 2S
Keyboard Matias RGB Backlit Keyboard
Software Windows 10 & macOS (Hackintosh)
I genuinely don't know why folks don't just type "*insert product here* review" in goggle and be done with it. the info is out there. get it yourself
9,828 (3.40/day)
Cooling In Win SR36
Freesync is the standard for VRR. Premium Pro is Freesync from 40 to 144 HZ (165 on some).
Gsync is an actual chip on the PCB of the monitor that is not cheap and therefore expensive. Having an Nvidia GPU is the only way to get Gsync to work fully but the question is do you want to spend for that feature?
169 (0.10/day)
I think to buy that screen https://www.gigabyte.com/il/Monitor/M27Q/sp#sp and he got freesync premium/pro i am no sure.
if I buy rtx3080 for example ill get all features of freesync on that screen? It work well? or I must buy G-sync screen?
and if i want buy screen that both work he should get Gsync+freesync?
If it so hard for you to help I don't need your comments..
1,980 (0.39/day)
Mainland Britain
System Name H2o Box
Processor Intel(R) Xeon e5-2690 v2 Stock 3.300 GHz stock
Motherboard MSI X79A-G43 Plus (MS-7760) v3
Cooling CPU EK & Phobya G-Changer 360 V2.0 RAD H2o VGA "AlphaCool M18" Hybrid [pump replaced 18/8/21]
Memory G.Skill TridentX 16Gb 11-12-12-32 2T @ 1866Mhz [locked]
Video Card(s) Zotac GTX 1080ti AMP EXTREME
Storage HyperX Fury 120GB & Savage 480GB SSD, Seagate 250GB,250GB 7200rpm Kingston 64GB SSD
Display(s) Asus TUF Gaming VG32VQR 2560*1440 165Hz VA Panel
Case Corsair O-800D
Power Supply Be Quiet! [Dark Power Pro 11] 1200W CM replaced [7-4-2017]
Mouse Zelotes T-90
Keyboard K66 Mechanical US Layout
Software Win 10 Pro 64Bit v 20H2 / OS [build 19043.1237] WFEP 120.2212.3530.0
9,828 (3.40/day)
Cooling In Win SR36
It is a Freesync only monitor. As I said Freesync is basically an open source VRR so it will work with all GPUs. It is something that you enable in your monitor's settings. Gsync monitors have a chip that controls the way the monitor interacts with the GPU to basically allow the GPU to control the refresh rate. It is very similar to Freesync in every way. With the advent of HDMI 2.1 and DP 1.4 the refresh rate support for VRR has advanced to 4K 120Hz and 1440P 165Hz. With new 240Hz and even 360Hz monitors available it will be interesting to see where VRR goes. What your question raises though is that Freesync and Gsync can represent the way the 2 Companies are run. In fact because of that sentiment without Gsync "Compatible" Gsync would be like PhysX. If you want my opinion save your money buy the monitor and enjoy it. Gigabyte actually makes decent monitors and that is a feature rich IPS screen with KVM. I have a 32QC and totally enjoy it.
