rebirth
- Aug 5, 2013
- 12 (0.00/day)
System Name | LOL |
Processor | Intel I7 2600k @ 4.5ghz |
Motherboard | Asus P67 Pro |
Cooling | Corsair closedloop water cooler |
Memory | 16 GB (4x4) Corsair 1600mhz |
Video Card(s) | GTX 470 |
Storage | SSD's and standard HDDs (RAID) |
Display(s) | 2 x 24 inch + 42 inch HDTV (only use one monitor for games though) |
Case | Akasa Mirage (a good few years old) |
Audio Device(s) | Asus Xonar D1 |
Power Supply | Corsair 850 watt |
Software | Win 7 64bit Ultimate |
Benchmark Scores | It boots up faster than the time it takes to even put the kettle on. :( |
Hi. Today after turning on my PC I started to crash after about 5 minutes even when idle. I tracked it down to my GFX suddenly overheating to 139 degrees with no GPU load!
I took the card apart, cleaned the fan (including fins), took off the heatsink, cleaned off all the dried up and brittle compound and replaced it with a generous helping of Arctic Silver.
When I power it up all has worked fine and haven't crashed since. After I powered up i was getting a reading of between 38-45 degrees, which is good for this particular card (it has always been hot).
I have now noticed that my temperature is fluctuating between 176 and 48 degrees. This reading appears to be changing between these temps on every update, so cannot possibly be valid.
I just had a moment when the card's fan kicked in full speed for a second and then go back to normal.
I have tried three programs to monitor the temp and they all report this fluctuation.
Is the sensor malfunctioning? Is it time to invest in something new?
Screenshots taken less than a second apart:
Note the GPU temp readings.
