Nvidia mx230 Unknown Problem and "code 43"
B6G.K!LLER
1 (0.02/day)
hello everyone I have a Dell Inspiron 3593 laptop with double gpu "intel uhd g1" and "nvidia mx230" the problem is my gpu showing code 43 in device manager and yellow triangle. i tried to disable and enable it again the yellow triangle removed but still the gpu not showing in task manager performance tab and it shows 0mb in gpu-z.
-I tried to reset bios by CMOS method
-I reinstalled windows 10 with different versions.
-I uninstalled driver using DDU and installed it again.
-I reinstalled drivers multiple versions.
-Updated BIOS.
-Did a dell diagnostic and shows PASS for everything.
how can I fix this is there any VBIOS to flash for my mx230 ?
NOTE: this is happened for no reason I don't play games or use something depend a lot on this GPU and I was using Linux as my main system.
It's dead, if it's not BGA then it should be a MXM style replaceable card.
If you only need integrated graphics, ignore it.
