NVIDIA PhysX System Software 9.09.0203 Released
malware
5,422 (0.72/day)
Bulgaria
Processor Intel Core 2 Quad Q6600 G0 VID: 1.2125
Motherboard GIGABYTE GA-P35-DS3P rev.2.0
Cooling Thermalright Ultra-120 eXtreme + Noctua NF-S12 Fan
Memory 4x1 GB PQI DDR2 PC2-6400
Video Card(s) Colorful iGame Radeon HD 4890 1 GB GDDR5
Storage 2x 500 GB Seagate Barracuda 7200.11 32 MB RAID0
Display(s) BenQ G2400W 24-inch WideScreen LCD
Case Cooler Master COSMOS RC-1000 (sold), Cooler Master HAF-932 (delivered)
Audio Device(s) Creative X-Fi XtremeMusic + Logitech Z-5500 Digital THX
Power Supply Chieftec CFT-1000G-DF 1kW
Software Laptop: Lenovo 3000 N200 C2DT2310/3GB/120GB/GF7300/15.4"/Razer
NVIDIA has released new and updated PhysX driver that is compatible with AGEIA PhysX processors and CUDA ready GeForce GPUs. Version 9.09.0203 dated February 10, 2009 is almost 40MB and works with Windows XP and Windows Vista (32-bit and 64-bit versions). The application supports NVIDIA PhysX acceleration on all GeForce 8-series, 9-series and 200-series GPUs with a minimum of 256MB dedicated graphics memory. Here is what's new in this release:
  • Resolves PhysX SDK runtime issues with multi-GPU configurations in Hybrid environments.
  • Improves performance of some PhysX enabled games on GeForce GTX 285 and GTX 295 products.
  • Resolves occasional system crashes when PhysX is enabled on some systems when running on EA's Mirrors Edge.
  • Runtime upgrade ONLY for AGEIA PhysX processors users. (New installations should install older PhysX system software such as version 8.09.04 - prior to installing this update).
  • Includes the latest PhysX runtimes used in the latest game titles.
DOWNLOAD: NVIDIA PhysX System Software 9.09.0203
231 (0.04/day)
System Name Uh, my build?
Processor Intel Core i7 3770k 3.5GHz (3.9GHz turbo)
Motherboard Gigabyte Z77X-UD5H (F8 BIOS)
Cooling Coolermaster Hyper 212 Evo
Memory G.Skill 8GB DDR3 1600MHz CL9
Video Card(s) Gigabyte Radeon HD7970 3GB 1GHz Core/5.5GHz Memory
Storage SanDisk Extreme Pro 960GB & 2TB WD Black & 1TB WD Green
Display(s) 1x Samsung 23" Syncmaster P2350 1x LG 23"
Case Coolermaster HAF X
Audio Device(s) Onboard now since store didn't RMA properly
Power Supply Corsair HX 850W
Software Win 10 Pro 64bit
Benchmark Scores 3DMark 11 - P8456 - http://3dmark.com/3dm11/3372758
Quick question, when upgrading PhysX, do you guys uninstall the old one first or just install over the top? As in, is it like graphics drivers where you should uninstall first?
Also, when you install the latest nvidia drivers, do yo uninstall both or just the display because I've been uninstalling both.
3,318 (0.53/day)
Dallas, Tx
Processor Intel i5-3570K @ 3.4Ghz
Motherboard Asrock LGA1155 Z77 Extreme 4
Cooling Cooler Master Evo 212
Memory 16GB (4X4) G.Skill Ripjaw 2 DDR3-1600
Video Card(s) Nvidia gForce GTX 660ti
Storage 1x Samsung 840 EVO 256GB 6Gb/s, 1x WD 500GB 6Gb/s, 1x WD 80GB 3Gb/s
Display(s) ASUS VH242H Black + 2 HP 2311x 23" LED
Case Fractal Design R4
Audio Device(s) Realtek OnBoard Both
Power Supply Cooler Master 850w
Software Windows 7 Ultimate 64-bit SP1
I Install over for PhysX and unistall and then install for Display Drivers.
633 (0.10/day)
Australia
System Name _Speedforce_ (Successor to Strike-X, 4LI3NBR33D-H, Core-iH7 & Nemesis-H)
Processor Intel Core i9 7980XE (Lapped) @ 5.2Ghz With XSPC Raystorm (Lapped)
Motherboard Asus Rampage VI Extreme (XSPC Watercooled) - Custom Heatsinks (Lapped)
Cooling XSPC Custom Water Cooling + Custom Air Cooling (From Delta 220's TFB1212GHE to Spal 30101504&5)
Memory 8x 8Gb G.Skill Trident Z RGB 4266MHz @ 4667Mhz (2x F4-4266C17Q-32GTZR)
Video Card(s) 3x Asus GTX1080 Ti (Lapped) With Customised EK Waterblock (Lapped) + Custom heatsinks (Lapped)
Storage 1x Samsung 970 EVO 2TB - 2280 (Hyper M.2 x16 Card), 7x Samsung 860 Pro 4Tb
Display(s) 6x Asus ROG Swift PG348Q
Case Aerocool Strike X (Modified)
Audio Device(s) Creative Sound BlasterX AE-5 & Aurvana XFi Headphones
Power Supply 2x Corsair AX1500i With Custom Sheilding, Custom Switching Unit. Braided Cables.
Mouse Razer Copperhead + R.A.T 9
Keyboard Ideazon Zboard + Optimus Maximus. Logitech G13.
Software w10 Pro x64.
Benchmark Scores pppft, gotta see it to believe it. . .
I install ontop to try it out. For some reason if i happened to format (very very often), i always install v8.04.25 first and then i install the latest version if i had tried it out and approved.
v9.09.0203 + Realitymark FTW
