Nvidia Shadowplay not ready (GTX 960 2gb ssc)
Kevin vang
18 (0.01/day)
Hello all, The titles says it all,
NOTE: I bought the graphic card for a computer that me and my little brother played on for our games. But eventually I bought myself another computer and then took out the graphic card carefully and safely to the new computer I am currently on right now. I installed everything but then there are TWO problems I have here one relating the graphic card. So I installed the graphic card and GeForce Experience and everything else. But when I come across Shadowplay,Gamestream,Ledvisualizer. They don't work anymore. On the computer that I shared with my little brother, Everything worked fine until I switched it over to this computer and now nothing is working.I heard Shadowplay is Only GPU but it also says something about the cpu being I3 and up.
2ND PROBLEM: For some reason I been having a lot of freezes on google chrome and so far most apps. For example: I'll be playing Csgo and then I open up my google chrome and everything is fine, 2nd time i alt tab to google chrome,Google chrome freezes up and then i taskbar (endtask) google chrome. When I open it up again, Google asks me to restore but I can't click anywhere or type anything on google chrome but to just exit it and wait 5 min to be able to use chrome.
HERES MY SPEC:
Not enough spec detail. Try Speccy.
As for Shadowplay, just restart the program or reboot. Always worked for me.
I have redownloaded GeForce Experience Only But I will try rebooting, I also added the other problem, Can you see if you know the problem?
UPDATE: I just rebooted (hopefully meaning restart your computer) and went on Geforce Exp but it still does not work. You said you needed more specs? What would you like to know?
Errythang.
Also Chrome has a goofy thing with NVIDIA GPUs that an update seemes to fix. I can't link anything until I get home in ~30 minutes.
It should tell you what it thinks is wrong if you click on the ShadowPlay tab in My Rig. Have you previously disabled ShadowPlay for the slight performance increase?
Turn off google chrome hardware acceleration if you're having problems with it.
As for your Shadowplay issue, I am not sure. Never had an issue with it. I just turn it on, before I start playing and its recording in the background, with a little green dot down in the corner to let me know its working
In your profile there is a tab for system specs
