NVIDIA to Implement GDDR7 Memory on Top-3 "Blackwell" GPUs
47,657 (7.43/day)
NVIDIA is confirmed to implement the GDDR7 memory standard with the top three GPU ASICs powering the next-generation "Blackwell" GeForce RTX 50-series, Tweaktown reports, citing XpeaGPU. By this, we mean the top three physical silicon types from which NVIDIA will carve out the majority of its SKUs. This would include the GB202, the GB203, and GB205; which will power successors to everything from the current RTX 4070 to the RTX 4090. NVIDIA is expected to build these chips on the TSMC 4N foundry node.
There will be certain GPU ASIC types in the "Blackwell" generation that will stick to older memory standards such as GDDR6 or even the GDDR6X. These would be successors to the current AD106 and AD107 ASICs, powering SKUs such as the RTX 4060 Ti, and below. NVIDIA co-developed the GDDR6X standard with Micron Technology, which is the chip's exclusive supplier to NVIDIA. GDDR6X scales up to 23 Gbps and 16 Gbit, which means NVIDIA can avail plenty of performance for the lower-end of its product stack using GDDR6X; especially considering that its GDDR7 implementation will only run at 28 Gbps, despite chips being available in the market for 32 Gbps, or even 36 Gbps. Even if NVIDIA chooses the regular GDDR6 standard for its entry-mainstream chips, the tech scales up to 20 Gbps.
wolf
Better Than Native
8,676 (1.32/day)
System Name MightyX
Processor Ryzen 9800X3D
Motherboard Gigabyte B650I AX
Cooling Scythe Fuma 2
Storage WD Black SN850X 2TB
Display(s) LG 42C2 4K OLED
Case Coolermaster NR200P
VR HMD Meta Quest 3
Hopefully it will curb power consumption, the GDDR6X on my 3080 is power hungry, not sure if that was improved with Ada.
3,621 (1.17/day)
Processor 9800X3D
Cooling DeepCool AK620
Storage 4TB Samsung 990 Pro
Display(s) 48" LG OLED C4
Case Corsair 5000D Air
Power Supply Corsair HX1200
Mouse Razor Death Adder v3
Software win11
GDDR6x on Ada is on a better node with much better power consumption and thermal
404 (0.33/day)
1) GPUs are not ASICs. There's nothing "application-specific" about them, especially since GPGPU exists.
2) The top Blackwell GPUs are going to use "4NP" according to Kopite7kimi, which is a different node than 4N.
1,287 (0.82/day)
507o is touted GB205 and therefore 8192 minus 2-4 disabled SMs and 12GB and PCIE 8x, just because PCIe 5.0.
the price points should remain the same with 20-25% gen on gen performance uplift, 5090 will shoot up to the stratosphere
For the most part RTX 50 is more like a refresh. using the N4P nodelet provides only a minor clock speed bump 5-10%.
more L1 cache is good but more shaders crammed in each GPC is a step back and means less ROPs.
Skip skip skip until the N1 node.
107 (0.19/day)
12 GB for 3 or 4 years more? RTX 5070 ~2025, RTX 6070 ~2027-2028?
Better buy RTX 5070 if it has 16-20 GB VRAM, and skip RTX 6000 series altogether.
Naaah. I'm not one of the people who are desperate to have everything maxed out all the time. This includes texture resolution. And I'm still on a 1080P monitor. Nvidia is deliberately serving everything but catastrophically overpriced top tier cards with less VRAM than they should have. To force people into buying new cards, if for no other reason then because of lack of VRAM. I'll rather skip to AMD if I do buy next gen of cards. They are more generous when it comes to video memory.
6,662 (1.58/day)
System Name The Little One
Processor i5-11320H @4.4GHZ
Motherboard AZW SEI
Video Card(s) Iris XE
Power Supply 65w brick
Mouse Logitech MX Master 2
VR HMD Whahdatiz ???
Benchmark Scores PDQ
Well, of course they are, cause this will give them yet anutha excuse to jack up their prices even more for what will probably be yet anutha round of minuscule 5-8% performance increases :(
1,590 (0.62/day)
These aren't Intel CPUs. Previous two generations had about 50% performance uplift, even if you looked pure rasetisation numbers.
The problem is, price increase was even bigger, so some RTX 40x0 cards had worse price / performance than the previous generation - and I don't think we will get any better deal in next generation.
9,217 (4.08/day)
System Name Bragging Rights
Processor Atom Z3735F 1.33GHz
Memory 2GB DDR3L-1333
Case Veddha T2
Mouse MX Anywhere 2
Software W10 21H1, barely
Nvidia often seems to use faster VRAM as a way to skimp on bus width, so I'm much less excited about this than I would have been a decade ago.
We've lost bus width with several previous consumer GPU jumps to newer GDDR generations.
512-bit cards were abandoned by Nvidia in the switch from GDDR3 to GDDR5​
Consumer cards were relegated to 256-bits when GDDR5X came along, with 384-bit prosumer Titans being the only, eye-wateringly expensive way to get more than 256-bits for over a year.​
The pattern repeated with GDDR6/6X with the entry cost of 384-bit memory buses rising to $1500MSRP, and $2000 on the street, while mainstream cards losing bus-width at almost every tier, as well as PCIe lanes.​
Hopefully, we don't see GDDR7 used as a way to make 192-bit buses compete with the same tier of 256-bit GDDR6 card from this generation, but my cynicism is justified by plenty of historic data. It's what Nvidia do, all the damn time.
1,605 (0.63/day)
London, UK
What is the difference between TSMC N4P and N5?
"In October 2021, TSMC introduced a new member of its "5 nm" process family: N4P. Compared to N5, the node offered 11% higher performance (6% higher vs N4), 22% higher power efficiency, 6% higher transistor density and lower mask count. TSMC expected first tapeouts by the second half of 2022."
ARF
4,677 (2.44/day)
Marginal.
It is risky to stay for further 3-4 years asking the games not to release one that needs more than 12 GB of VRAM even at low-medium settings.
I don't share the optimistic view that 12 GB is good. Not, it is not.
Sooner or later you will see this message:
You should act proactively and counter-act Nvidia. Buy a card with more VRAM than wait for a new generation which no one knows when exactly will get a public release.
This is even better. I doubt that AMD is generous, they simply know better than Nvidia how much VRAM is needed today.
AMD works better with the game developers to determine the minimum system requirements, and releases its products accordingly.
578 (0.13/day)
Bulgaria
System Name Black Knight | White Queen
Processor Intel Core i9-10940X (28 cores) | Intel Core i7-5775C (8 cores)
Motherboard ASUS ROG Rampage VI Extreme Encore X299G | ASUS Sabertooth Z97 Mark S (White)
Cooling Noctua NH-D15 chromax.black | Xigmatek Dark Knight SD-1283 Night Hawk (White)
Memory G.SKILL Trident Z RGB 4x8GB DDR4 3600MHz CL16 | Corsair Vengeance LP 4x4GB DDR3L 1600MHz CL9 (White)
Video Card(s) ASUS ROG Strix GeForce RTX 4090 OC | KFA2/Galax GeForce GTX 1080 Ti Hall of Fame Edition
Storage Samsung 990 Pro 2TB, 980 Pro 1TB, 850 Pro 256GB, 840 Pro 256GB, WD 10TB+ (incl. VelociRaptors)
Display(s) Dell Alienware AW2721D 240Hz| LG OLED evo C4 48" 144Hz
Case Corsair 7000D AIRFLOW (Black) | NZXT ??? w/ ASUS DRW-24B1ST
Audio Device(s) ASUS Xonar Essence STX | Realtek ALC1150
Power Supply Enermax Revolution 1250W 85+ | Super Flower Leadex Gold 650W (White)
Mouse Razer Basilisk Ultimate, Razer Naga Trinity | Razer Mamba 16000
Keyboard Razer Blackwidow Chroma V2 (Orange switch) | Razer Ornata Chroma
Yeah, but N4 is not 4N right? :p Yeah, I know all those "nm" are just marketing thing now. On paper Ada is 4nm which is N4P. From what I'm aware the regular N4 is nowhere to be found on consumer market.
dgianstefani
TPU Proofreader
5,462 (2.04/day)
Swansea, Wales
Benchmark Scores Legendary
Makes sense to follow Apple's lead. "Pro" models on leading edge node, "non pro" on updated last gen APU. Even AMD is doing this already with the differences in node from 7600 to higher RDNA3 models.
There's such limited capacity left once Apple has placed its order anyway, so from a technical perspective I understand this strategy.
Intel with its own fabs hopefully coming out swinging with 15th gen Core and Battlemage.
2,881 (1.13/day)
Blackwell uses a newer architecture than Ada, for cores, so definitely not just a refresh with GDDR7 and some extra L2 cache
7,011 (1.41/day)
Case NZXT PHANTOM410-BK
Power Supply Corsair 850W
Mouse Logitech Hero G502 SE
Bro, stop spreading miss information.
I had an GTX 1080 with 8GB of VRAM, and never, ever received that message or even had any issues on any game.
I now run an RTX 3080 with 10GB of VRAM and is the same thing. I play all games maximized and with 4K or Ultra Res textures and my VRAM is always around 8GB at tops.
I'm very curious what games do you think require more than 12GB of VRAM?? The ones that have engines caching all VRAM do not count ;)
Deleted member 229121
Only the top 3? So the 5070 isn't going to get it...#%^&ing pricks.
EDIT: Never mind, I need more coffee.
dgianstefani
TPU Proofreader
5,462 (2.04/day)
Swansea, Wales
Top three dies, not top three SKUs.
5070 will be GB203/GB205.
23,863 (6.16/day)
Marginal.
Dude. Im one of the people saying 12GB isnt enough at its given price point but youre taking this way out of context. Stop spreading BS.
  • Haha
Reactions: ARF
827 (0.18/day)
Poland
System Name THU
Processor Intel Core i5-13600KF
Motherboard ASUS PRIME Z790-P D4
Cooling SilentiumPC Fortis 3 v2 + Arctic Cooling MX-2
Memory Crucial Ballistix 2x16 GB DDR4-3600 CL16 (dual rank)
Video Card(s) MSI GeForce RTX 4070 Ventus 3X OC 12 GB GDDR6X (2610/21000 @ 0.91 V)
Storage Lexar NM790 2 TB + Corsair MP510 960 GB + PNY XLR8 CS3030 500 GB + Toshiba E300 3 TB
Display(s) LG OLED C8 55" + ASUS VP229Q
Case Fractal Design Define R6
Audio Device(s) Yamaha RX-V4A + Monitor Audio Bronze 6 + Bronze FX | FiiO E10K-TC + Koss Porta Pro
Power Supply Corsair RM650
Mouse Logitech M705 Marathon
Keyboard Corsair K55 RGB PRO
Software Windows 10 Home
Benchmark Scores Benchmarks in 2025?
The initial line-up of the 50 series is not looking great at the moment. Same node, slow low-capacity GDDR7 modules which are supposed to be coupled with narrow buses.
I honestly don't even know what to expect anymore. A slightly more efficient 5070 with 12 GB? It seems surreal.
1,287 (0.82/day)
supposedly 50 series is adding 33% more shaders per GPC and 33% faster GDDR7. I don't believe the shaders are any different just more of them and $L1 to mitigate that
Nvidia has no reason to make 5070 any faster than a 4070 SUper. and with GB205 that's what we get. a minor refresh and early adopters get 12GB as opposed to the anticipated 18GB much later.
5080 is barely as fast as 4090 in raster, 25% faster than 4080 that is, even the bandwidth shaders point to 22.5 ->28GBps, 9728 -> 12160 likely 25%
Nvidia renamed 5070 to 5080 and for 1199 very likely. and even bigger gap between 80/90 that leaves room for the 5080 Ti. yeah.
