NVIDIA Unveils RTX A6000 "Ampere" Professional Graphics Card and A40 vGPU
47,654 (7.44/day)
NVIDIA today unveiled its RTX A6000 professional graphics card, the first professional visualization-segment product based on its "Ampere" graphics architecture. With this, the company appears to be deviating from the Quadro brand for the graphics card, while several software-side features retain the brand. The card is based on the same 8 nm "GA102" silicon as the GeForce RTX 3080, but configured differently. For starters, it gets a mammoth 48 GB of GDDR6 memory across the chip's 384-bit wide memory interface, along with ECC support.
The company did not reveal the GPU's CUDA core count, but mentioned that the card's typical board power is 300 W. The card also gets NVLink support, letting you pair up to two A6000 cards for explicit multi-GPU. It also supports GPU virtualization, including NVIDIA GRID, NVIDIA Quadro Virtual Data Center Workstation, and NVIDIA Virtual Compute Server. The card features a conventional lateral blower-type cooling solution, and its most fascinating aspect is its power input configuration, with just the one 8-pin EPS power input. We will update this story with more information as it trickles out.
Update 13:37 UTC: The company also unveiled the A40, a headless professional-visualization graphics card dedicated for virtual-GPU/cloud-GPU applications (deployments at scale in data-centers). The card has similar specs to the RTX A6000.
Update 13:42 UTC: NVIDIA website says that both the A40 and RTX A6000 a 4+4 pin EPS connector (and not 8-pin PCIe) for power input. An 8-pin EPS connector is capable of delivering up to 336 W (4x 7 A @ 12 V).
435 (0.22/day)
NYC, NY
MARKETING is everything.
The 3090 is a workstation card that's been marketed as a gaming card. And that's why we rushed out to buy one. NO ONE rushes out to buy Quadro cards because there's far less demand for workstation cards than thereis for gaming.
My question is whether / when a card will get the RTX Titan 3000 badge.
771 (0.14/day)
Germany
System Name Acer Nitro 5 (AN515-45-R715)
Processor AMD Ryzen 9 5900HX
Motherboard AMD Promontory / Bixby FCH
Cooling Acer Nitro Sense
Memory 32 GB
Video Card(s) AMD Radeon Graphics (Cezanne) / NVIDIA RTX 3080 Laptop GPU
Storage WDC PC SN530 SDBPNPZ
Display(s) BOE CQ NE156QHM-NY3
Software Windows 11 beta channel
634 (0.12/day)
City 217
Processor AMD Phenom II X4 925
Motherboard Asus M4A78LT-M
Cooling Ice Hammer IH-4***
Memory 2x4GB DDR3 Corsair
Video Card(s) Asus HD7870 2GB
Storage 500GB SATAII Samsung | 500GB SATAII Seagate
Display(s) 23" LG 23EA63V-P
Case Thermaltake V3 Black Edition
Audio Device(s) VIA VT1708S
Power Supply Corsair TX650W
8 pin? What's the matter, didn't make enough of their proprietary 12 pin connectors?
9,800 (3.24/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
Yep, that's an 8 pin alright, doesn't add up.
261 (0.10/day)
Baguetteland
System Name 1080p 180hz
Motherboard Asus X670E crosshair hero
Memory G.skill flare X5 2*16 GB DDR5 6000 Mhz CL30
Video Card(s) Asus prime 5060 ti 16 GB
Storage Western digital SN850 1 TB NVME
Display(s) LG Ultragear 24GS65F-B
Case Phanteks P600S
Audio Device(s) Logitech pro X2 lightspeed
Power Supply EVGA 1200 P2
Mouse Logitech G PRO
Keyboard Logitech G710+
Software Windows 11 24H2
Nvidia retail and quadro cards have always shared the same GPU over the years. The difference are that quadro versions have more vRAM and dedicated drivers designed to perform best with 2D/3D rendering softwares used by professionals like autocad.
Retails cards have drivers optimized for gaming.
If you buy a Quadro cards for gaming, you'll have bad gaming performance since the drivers will not be designed for gaming. That's why no one rushes out to buy Quadro cards for gaming.
294 (0.06/day)
Processor AMD Ryzen 5900X
Motherboard MSI MAG X570 Tomahawk
Cooling Dual custom loops
Memory 4x8GB G.SKILL Trident Z Neo 3200C14 B-Die
Video Card(s) AMD Radeon RX 6800XT Reference
Storage ADATA SX8200 480GB, Inland Premium 2TB, various HDDs
Display(s) MSI MAG341CQ
Case Meshify 2 XL
Audio Device(s) Schiit Fulla 3
Power Supply Super Flower Leadex Titanium SE 1000W
Mouse Glorious Model D
Keyboard Drop CTRL, lubed and filmed Halo Trues
EPS12V, not PCIe 8-pin. Four 12V conductors vs three, so it can handle more power.
200 (0.12/day)
System Name BUBSTER
Processor I7 13700K (6.1 GHZ XTU OC)
Motherboard Z690 Gigabyte Aorus Elite Pro
Cooling Arctic Freezer II 360 RGB
Memory 32GB G.Skill Trident Z RGB DDR4 4800MHz 2x16GB
Video Card(s) Asus GeForce RTX 3070 Super Dual OC
Storage Kingston KC 3000 PCIE4 1Tb + 2 Kingston KC 3000 1TB PCIE4 RAID 0 + 4 TB Crucial gen 4 +12 TB HDD
Display(s) Sony Bravia A85 j OLED
Case Corsair Carbide Air 540
Audio Device(s) Asus Xonar Essence STX II
Power Supply Corsair AX 850 Titanium
Mouse Corsair Gaming M65 Pro RGB + Razr Taipan
Keyboard Asus ROG Strix Flare Cherry MX Red + Corsair Gaming K65 lux RGB
Software Windows 11 Pro x64
In the case of Nvidia ... it is a disastrous Marketing, they really messed this up last month :(
91 (0.01/day)
Cheltenham, England, UK
System Name ASUS Vivobook Pro 15 / Zephyrus G16
Processor R9 7940HS / i7-13620H
Memory 16GB LPDDR5X 7500MT/s / 24GB DDR4 3200MT/s
Video Card(s) RTX4060 105W @0.850V / RTX4060 120W @0.850V
Storage WD Black SN850X 2TB NVMe / WD SN740 512GB NVMe
Display(s) 15.6" 1080p 144Hz IPS / 16" 1200p 165Hz IPS @180Hz
Power Supply 240W / 240W
Keyboard Backlit
Software Windows 11 Home 64-bit
If you check the pinout on the render, you can see it's EPS 12V connector, not the PCI-e 8-pin.
AsRock
TPU addict
19,250 (2.95/day)
UK\USA
Cooling D15
Not the design does not get any interference from the connector, were it's clear it would of with the 30 FE cards.
Dam that cooler looks pretty dam solid, Nv Might be getting more and more to move away from this plastic shroud crap.
47,654 (7.44/day)
Turns out, both the A6000 and A40 use 4+4 pin EPS as power source, not 8-pin PCIe.
TIL 8-pin EPS is capable of 336 W (7A * 12V * 4), and that any mainstream desktop motherboard with >1 EPS input is a scam.
717 (0.26/day)
France
Processor RYZEN 7 5800X3D
Motherboard Aorus B-550I Pro AX
Cooling HEATKILLER IV PRO , EKWB Vector FTW3 3080/3090 , Barrow res + Xylem DDC 4.2, SE 240 + Dabel 20b 240
Memory Viper Steel 4000 PVS416G400C6K
Video Card(s) EVGA 3080Ti FTW3
Storage XPG SX8200 Pro 512 GB NVMe + Samsung 980 1TB
Display(s) ROG Strix OLED XG27AQDMG
Case NR 200
Power Supply CORSAIR SF750
Keyboard Meletrix Zoom 75 GT Silver
Software Windows 11 22H2
In the case of Nvidia ... its disastrous Marketing, they really messed this up last month :(
Yeah their GPUs being sold out everywhere really shows how disastrous their marketing is ............ :kookoo: :laugh:
41 (0.01/day)
System Name Chroma
Processor AMD Ryzen 7 5800X3D
Motherboard ASUS TUF GAMING B550-PLUS
Cooling Arctic Liquid Freezer II 360 ARGB
Memory G.Skill Ripjaws V 32 GB
Video Card(s) PNY GeForce RTX 4070 Ti 12GB XLR8 Gaming VERTO EPIC-X
Storage Samsung 980 1TB, MX500 1TB, Micron 1300 1TB, PNY 2TB Gen4 XLR8 CS3140 Heatsink
Display(s) Gigabyte M28U, LG 27GL850-B
Case KRUX Thea (KRX0090)
Audio Device(s) Creative Sound Blaster Z SE + On-Board Realtek
Power Supply Seasonic FOCUS PX-650 80Plus Platinum 650W
Mouse Logitech G305 LIGHTSPEED
Keyboard XPG Summoner RGB Cherry MX Red
No, the 3090 is a gaming card that can also do some(not all) workstation type tasks. This card and it's big brothers are the workstation render/compute cards.
Exactly, RTX3090 in CAD/FEM is crap, Quadro/Titan RTX is much better there. Like NV said - RTX 3090 is for gaming and creativity applications like Blender ect. not CAD/professional.
282 (0.06/day)
They can begin by delivering the card released, why release cards with very low NO STOCK anyways.
Still waiting for 3080 i ordered 20 days ago, nvidia said production in full swing and there would be waves of cards every week but i haven't seen any waves coming in.
They said there was good stock at release BUT won't say how much, what an obvious lie, the stock where non existent.
In Sweden it was calculated among all big retailers that there where about 700-800 cards available at release date in the entire country while demand was at least 20x more.
55 (0.01/day)
Processor AMD R5 3600
Motherboard Asus x570 Strix-E
Cooling custom water (360+280 rads) EK cpu and gpu blocks
Memory Corsair Vengeance pro 3600
Video Card(s) rx vega 64
Storage XPG SX8200 pro NVME Gen3 500g, Samsung 860 evo 500g,
Display(s) Benq Zowie XL 2730
Case Phanteks Eclipse p600s
Audio Device(s) Razor Leviathan
Power Supply SEASONIC Platinum 850w CORSAIR HX1000,
Mouse Zowie EC1-b, Glorias model-O
Keyboard Corsair K70 Lux
Software WINDOWS 10, 64BIT
Nvidia don't want to be making many FE cards! Lousey margin on those. They want to hand over card supply to AIB's as quickly as possible as that's where the real money is made. The FE card scam is not new for them and they only use it to look like they're not ripping you off too much when in fact the consumer never gets the FE price. Didn't they release the 2080ti FE for $1000? how many people got a 2080TI for that?
7,762 (2.66/day)
Back in Norway
System Name Hotbox
Storage 2TB Adata SX8200 Pro
Case SSUPD Meshlicious
Mouse Logitech G603
Enterprise GPUs typically use 8-pin EPS power connectors, which are rated for higher power draws than the PCIe 8-pin connector (likely due to having 4 wire pairs rather than 3 + two extra grounds. So unless these GPUs exceed... what is it, something like 400W including the PCIe slot? They should be fine.
Edit: @btarunr beat me to it above. Thx for providing the power rating btw, my two seconds of googling didn't provide it, so I gave up :p
1,798 (0.44/day)
2080ti FE was OC card with msrp of $1199. While "reference" card was said to be $999. Though I'm not sure were there really any with that price and with the reference spec.
612 (0.29/day)
System Name Fractal
Processor Intel Core i5 13600K
Motherboard Asus ProArt Z790 Creator WiFi
Cooling Arctic Cooling Liquid Freezer II 360
Memory 16GBx2 G.SKILL Ripjaws S5 DDR5 6000 CL30-40-40-96 (F5-6000J3040F16GX2-RS5K)
Video Card(s) PNY RTX A2000 6GB
Storage SK Hynix Platinum P41 2TB
Display(s) LG 34GK950F-B (34"/IPS/1440p/21:9/144Hz/FreeSync)
Case Fractal Design R6 Gunmetal Blackout w/ USB-C
Audio Device(s) Steelseries Arctis 7 Wireless/Klipsch Pro-Media 2.1BT
Power Supply Seasonic Prime 850w 80+ Titanium
Mouse Logitech G700S
Keyboard Corsair K68
Dang. Mid-December?! So we'll be waiting probably well into Februrary for the ~$1000 A4000 version to arrive. Guess I'll stick w/ the M4000 for a while longer.
3,632 (1.13/day)
Cooling Noctua NH-D15 Chromax
Memory 32GB DDR5 6000 CL30
Case Thermaltake Core X9
Mouse PMM P-305
Keyboard Wooting HE60
VR HMD Valve Index
Software Win 10
This argument has been used a million times.
Without actual stock numbers, being "sold out" means nothing.
What is a fact is that Nvidia announced there won't be wide availability of their cards until sometime in 2021. Launching a product and then being out of stock for months on end is bad business. People stop caring after a point.
551 (0.16/day)
Texas
System Name O-Clock
Processor Intel Core i9-9900K @ 52x/49x 8c8t
Motherboard ASUS Maximus XI Gene
Cooling EK Quantum Velocity C+A, EK Quantum Vector C+A, CE 280, Monsta 280, GTS 280 all w/ A14 IP67
Memory 2x16GB G.Skill TridentZ @3900 MHz CL16
Video Card(s) EVGA RTX 2080 Ti XC Black
Storage Samsung 983 ZET 960GB, 2x WD SN850X 4TB
Display(s) Asus VG259QM
Case Corsair 900D
Audio Device(s) beyerdynamic DT 990 600Ω, Asus SupremeFX Hi-Fi 5.25", Elgato Wave 3
Power Supply EVGA 1600 T2 w/ A14 IP67
Mouse Logitech G403 Wireless (PMW3366)
Keyboard Monsgeek M5W w/ Cherry MX Silent Black RGBs
Benchmark Scores https://hwbot.org/search/submissions/permalink?userId=92615&cpuId=5773
Wait a minute, so you are telling me this whole damn time NVIDIA could have just used the freaking 8 pin EPS connector for the RTX 30 series cards.......
I mean, those 10 core CPUs can hit 300W... It might be necessary for the 10 core CPUs and highly overclocked 8 core CPUs, not entirely a scam, but usually not needed for most people as you need really good cooling for that kind of power [on a smaller chip w/ smaller IHS like LGA115x/LGA1200].
7,762 (2.66/day)
Back in Norway
System Name Hotbox
Mouse Logitech G603
Given that a huge number of PSUs have just one EPS cable included, that would have been just as problematic.
717 (0.26/day)
France
Case NR 200
Because this argument makes sense unlike yours :rolleyes:
Dude you are confused this is not what Huang said , what Huang said is that since the demand has been unprecedented he is not expecting cards to be in stock anytime soon . The part that gets you confused is that lack of stock isn't indicative of GPUs not selling well ( or not selling at all ) but quite the opposite !
You don't need GPUs to be physically in stock in order to move them , all resellers have implemented preordering/queuing systems so as soon as they actually receive some physical stock it disapears since this stock is being used to fulfill those preorders . In other words GPUs move so fast that retailers don't even have time to add them to their inventory ( commonly called stock ) .... now i don't know how good your sense of business is but thats the definition of 3rd world problems !
If anything else Huang also declared in the same statement that Nvidia is expecting a very big Q4 season which when translated means , business couldn't be any better for them ........
551 (0.16/day)
Texas
System Name O-Clock
Case Corsair 900D
On that note, I am genuinely confused why NVIDIA is using EPS connectors instead of PCIe for the professional cards. I mean yeah it has more power, but there is usually not a leftover EPS cable on normal PSUs. We are lucky to be able to have 2 EPS connectors in our PSUs. btw yes I am aware this kind of contradicts my original statement, as I did not think about the actual number of EPS connectors on typical PSUs.
