NZXT CAM - Monitoring Software
519 (0.13/day)
UK
System Name Daedalus
Processor AMD FX 6300
Motherboard ASUS M5A97 EVO R2.0
Cooling Coolermaster Hyper 212 EVO
Memory 8GB Kingston HyperX Genesis (2x4GB)
Video Card(s) MSI R9 270X Gaming 2GB
Storage 1TB Seagate Barracuda
Display(s) LG Flatron E2442 (main - 24in 1080p)
Case NZXT Phantom 410 (Gunmetal Edition)
Power Supply XFX Pro 650W
Mouse Steelseries Siberia [RAW]
Hello all,
So I decided to take the recently released NZXT CAM software for a spin. Here are some of my initial thoughts.
  • It can be a resource hog sometimes. General navigation of the application would result in ~10% CPU usage, which is pretty high for a program designed to be used in the background. But then it is monitoring quite a lot of data and then outputting it into graphs.
  • There are some problems with the sensors. Immediately upon opening the application I was issued a warning that my motherboard had exceed 128 degrees C. I would know if my motherboard had that high temperatures, so either bad software reading or a dodgy sensor.
  • I also think the software is reading my CPU socket temperature rather than the actual CPU temperature sensor for the CPU reading. I might be wrong, but I was under the impression that my AMD FX would be much hotter under load, not ~25 degrees C.
  • One thing I do like though about the software is the realtime graphs. They're probably why the software is such a resource hog, but what looks amazing is that the monitoring data from your system is recorded and kept for a number of years. Could be useful for diagnosing problems. But then there's the issue that your data is recorded, and could be accessed by other people.
These are just some of my initial thoughts of V1.0.0, and I'm sure NZXT will improve upon the software in the future. What have other people's experiences been with the software?
Layton
