OCCT gpu scan with errors after overclocking
315 (0.14/day)
Italy
System Name The Worker/ Laptop
Processor Ryzen 5 3600/ i5 1035g1
Motherboard MSI b450 Tomahawk Max / Lenovo proprietary
Cooling Arctic Freezer 33 eSport One
Memory 16Gb DDR4 3200 Mhz Corsair vengeance LPX / 12gb ddr4 3200Mhz (4gb are soldered :( )
Video Card(s) Gigabyte gtx 1660 Ti OC @2030Mhz core and 7400Mhz memory / Intel G1 UHD
Storage 1 970Evo plus 500gb, 2x250Gb Samsung 850 Evo,3 TB HDD / 250gb WD SN530
Display(s) Asus mx259h / 15.6 FHD TN
Audio Device(s) Onboard / Onboard
Power Supply CoolerMaster G750M
Software W10 64bit
Hi, I have a gigabyte gtx 1660 ti and so far I overclocked It setting +150 MHz on the core and +1500 on the memory. This didn’t cause any crash and games were really fluid And no artefacts so far.
now I installed occt to test errors and with this Settings I get an average of 2000-3000 errors in a 2 minutes test.
any advice?
did ya look if ya get higher fps in game or lower? or in gpu-z 3d test
Higher FPS for sure, almost 15 more, Better scores with furmark bench
OCCT gpu test uses Furmark, not the most reliable and very stress intensive . I wouldn't use it
Yeah I know, buy the OC Is stabile so far, no problems at all. Onlus with occt test I had errors but not crashes
if i am ok in game i dont even test other software so its your call to pull your oc down till its ok in occt?
Tryed, to get no errors I have to set +90 core, +1500 memory
did ya try with lower memory and in same time push up core-sometimes mem-oc keeps core-oc down
and what about power limit? push that up too
could be that occt pulls your card in some kind of limit temp,power??
I'll try ti Power the memory to increase core. Pretty much Every test with furmark cause the you to touch power limit, even maxing it out in afterburner
I have the same problem, I have msi gtx 1660ti gaming X 6GB, and after oc in msi afterburner, I have errors in occt(higher OC=more errors), and also game freeze in loading screen. Temp is 78°C after OC. Anyone know where could be problem ?
My pc i5 8600k/ msi b360 gaming plus/ kingston 8GB ddr4 2666Mhz/Vero L2 bronze 500W.
at the end I just set everything to default and saved the Oc Profile for future when I will need more performance.
set everything to default and then tray to adjust only core frequency until it crashes and then step back a little to be sure it’s not gonna crash.
after this try the same with memory, and increase temp limit and power limit to max
Use occt for cpu stressing. Those errors cant be ignored. For gpu, dont use occt
+1500 on the memory is not stable on 99.9999% of all turing cards ever made.
it has Error correction that's why you don't have massive issues.
properly working and scaling the for the average cards is at around +500 to +750 (maybe 800)
but 3 Ghz extra is ridiculous and probably gives you lower FPS or 1% lows. because of the tons of memory errors that must be fixed on the fly.
