OCCT's "Power" test CPU errors found
3,942 (0.60/day)
System Name Widow
Processor Ryzen 7600x
Motherboard AsRock B650 HDVM.2
Cooling CPU : Corsair Hydro XC7 }{ GPU: EK FC 1080 via Magicool 360 III PRO > Photon 170 (D5)
Memory 32GB Gskill Flare X5
Video Card(s) GTX 1080 TI
Storage Samsung 9series NVM 2TB and Rust
Display(s) Predator X34P/Tempest X270OC @ 120hz / LG W3000h
Case Fractal Define S [Antec Skeleton hanging in hall of fame]
Audio Device(s) Asus Xonar Xense with AKG K612 cans on Monacor SA-100
Power Supply Seasonic X-850
Mouse Razer Naga 2014
Benchmark Scores FFXIV ARR Benchmark 12,883 on i7 2600k 15,098 on AM5 7600x
A quickie hopefully
I have struggled to find any posts that are centered around the Power test or the above errors
Was working through new build
Did power test with OCCT with everything stock
Am I to understand that the Power test on OCCT incorporates CPU and GPU
As a result then should the issue be CPU (voltage for example) then I'd find core errors simultaneously under the CPU test?
Currently (at least when stock) I do not get any core errors in the CPU test
This might indicate the issue is related to the GPU
With that in mind I went to testing Blender, Valley/Heaven and some real games for a while - no errors crashes etc.
3x0
1,016 (1.09/day)
Processor AMD Ryzen 7 5800X3D
Motherboard MSI MPG B550I Gaming Edge Wi-Fi ITX
Cooling Scythe Fuma 2 rev. B Noctua NF-A12x25 Edition
Memory 2x16GiB G.Skill TridentZ DDR4 3200Mb/s CL14 F4-3200C14D-32GTZKW
Video Card(s) PowerColor Radeon RX7800 XT Hellhound 16GiB Noctua NF-A12x25 Edition
Storage Western Digital Black SN850 WDS100T1X0E-00AFY0 1TiB, Western Digital Blue 3D WDS200T2B0A 2TiB
Display(s) Dell G2724D 27" IPS 1440P 165Hz, ASUS VG259QM 25” IPS 1080P 240Hz
Case Cooler Master NR200P ITX
Audio Device(s) Altec Lansing 220, HyperX Cloud II
Power Supply Corsair SF750 Platinum 750W SFX
Mouse Endgame Gear OP1 8K
Keyboard HyperX Alloy Origins Aqua
210 (0.15/day)
Maybe running up against the limits of your power supply when maxing both your cpu and gpu? Didn't see the full parts list anywhere when skimming your linked thread.
3,942 (0.60/day)
System Name Widow
System spec if that helps (think I updated it before posting this thread)
I suppose that's part of the question. I can see clearly that it is raising CPU and GPU wattage during the test, though is that specifically what the power is aiming for, or is there more to it.
Last attempt CPU was 112w and GPU 240w
Not exactly burning the house down
CPU test with SSE enabled?
Ya had some runs with SSE and AVX2
210 (0.15/day)
I see now. Yeah your PSU is fine.
hat
Enthusiast
21,754 (3.23/day)
Ohio
Cooling Cryorig M9 :: Stock
Benchmark Scores >9000
Maybe the power test uses a different CPU test than you do when you test the CPU alone? The power test probably uses Linpack, which would be more intensive than a standard CPU test. Could be a case of AVX options being different across the two as well.
3,942 (0.60/day)
System Name Widow
Maybe, though I have done Linpack testing without errors as well
Also the main concern is why it's showing the error on stock settings
tabascosauz
8,305 (2.31/day)
Western Canada
System Name ab┃ob
Processor 7800X3D┃5800X3D
Storage 8TB of SSDs┃1TB SN550
Case Caselabs S3┃Lazer3D HT5
Core "stability" is hard to nail down on Ryzen because of how it works. Bottom line, cores should never be erroring out at stock.
You can use some of the common curve optimizer testing tools to double check. The corecycler script, Y-cruncher stress test function, etc. I've never really been a fan of OCCT because it's not particularly transparent as to what it actually tests.
3,942 (0.60/day)
System Name Widow
Thanks
Reading through the CoreCycler instructions, trying to find the actual settings/section to modify in the config.default, would like to change the time per core and some other things
tabascosauz
8,305 (2.31/day)
Western Canada
System Name ab┃ob
Thanks
You don't have to change the config. The default config is good enough for a quick test, just to make sure only OCCT has lost its mind. Changing the config is more for long-term curve optimizer testing where being on the edge of instability can be very unpredictable and elusive. At stock you should be well within stability.
Ycruncher is quite nice because the stress testing suite by default gives you a variety of tests that cover a wide range of loads ranging from core-heavy to uncore-heavy (Fabric and UMC).
3,942 (0.60/day)
System Name Widow
I do mean to have a curve optimizer arrangement, though hopefully the default for CoreCycler is sufficient
Will do the Ycruncher all component test as well
Pushed my curve settings pretty low - more so than OCCT will dare tolerate, and Corecycler has been pretty tame though I did have one system crash and reset(meaning it reset on it's own)
Looking at the log for CoreCycler itself, there's no listed errors - rather the logging seems to have stopped right as it was moving onto a new core
Same holds true for the PRime95 log - last thing listed was the previously passed test
This coming after about an hour of testing without issue
In a real world day to day way only 'crashing' I am getting is when in Warcraft where the condition is, the game has been idling some time and I have Edge browser open. The system will freeze up
Event viewer has no entries of note, sans this one
Autopilot.dll WIL error was reported.
HRESULT: 0x80070491
File: onecoreuap\admin\moderndeployment\autopilot\dll\dllmain.cpp, line 128
Message: NULL
When you look up what that .dll is, doesn't seem clearly related though there are reports that failed overclocking (e.g. bad configuration, voltage shortage) can cause it
Of course that could be wrong in my case but I don't know how to fix it (or what the intended fix is in normal circumstances) to be able to 'fix' it then see whether it keeps happening
So with all the above said, makes me wonder if it is purely down to too much of a negative Curve causing low CPU voltage specifically and core crashing, or the system overall is affected by it.
