Odd .sys error
Solaris17
Super Dainty Moderator
27,730 (3.84/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
Video Card(s) MSI SUPRIM Liquid 5090
Audio Device(s) Moondrop S8's on Schitt Gunnr
Keyboard Wooting 80 HE White, Gateron Jades
VR HMD Quest 3
I got the following error trying to open GPU-Z on server 2019.
It had worked previously but wouldn't today. So I uninstalled it and attempted to reinstall but it will not even launch far enough to ask me if it would like installation.
For shits and giggles I went into appdata\local\temp and created the 2 folder manually and it launched without issue. (it also would not launch or create the folder when I attempted to run as admin.)
That's one of those "You have permissions to look at this folder, but the program doesn't" errors.
I usually make a temp directory under the main C drive, and direct things to it; that solves a bunch of those errors.
If it's a "work machine", realize it lowers security. :(
Can you check what your temp directory is set to, and why it has a 2 in there?
Odd, when I use the sys variable %temp% it drops me into the /2/ folder.
However variables are not set to /2/
The only other software using the dir, appears to be nvidia.
