I'm getting really weird temperature spikes on both ADT7574 and driver temp sensors while using GPU-Z 0.4.3. The problem occurs both with PCB and GPU temps, and occurs along the lines of this:
I boot Windows 7 Ult 64bit and start GPU-Z. I leave the PC alone with only the desktop showing (so that GPU loading should remain constant). Everything will look nice and stable and then out of the blue a GPU/PCB ADT7574/driver temp will spike (up to like 148C, or down to -2 billion C) for 1 second. The reading then returns back in line with the stable temp readings.
E.g.1:
Date , GPU Core Clock [MHz] , GPU Memory Clock [MHz] , GPU Shader Clock [MHz] , GPU Temperature [°C] , PCB Temperature [°C] , GPU Temperature [°C] , PCB Temperature [°C] , Fan Speed [%] , Fan Speed [RPM] , Memory Used [MB] , GPU Load [%] , Memory Controller Load [%] , Video Engine Load [%] , 12V [V] , VDDC [V] , VDDC Current [A] , VDDC Power [W] ,
2010-06-16 15:53:27 , 50.6 , 67.5 , 101.0 , 39.0 , 33.0 , 33.0 , 33.5 , 44 , 1663 , 135 , 2 , 9 , 0 , 12.19 , 0.955 , 12.0 , 11.3 ,
2010-06-16 15:53:29 , 50.6 , 67.5 , 101.0 , 39.0 , 33.0 , 33.0 , 33.5 , 44 , 1664 , 135 , 4 , 10 , 0 , 12.19 , 0.955 , 12.0 , 11.3 ,
2010-06-16 15:53:30 , 50.6 , 67.5 , 101.0 , 39.0 , 33.0 , 33.0 , 33.5 , 44 , 1663 , 135 , 0 , 9 , 0 , 12.17 , 0.955 , 12.0 , 10.8 ,
2010-06-16 15:53:31 , 50.6 , 67.5 , 101.0 , 39.0 , 33.0 , 33.0 , 33.5 , 44 , 1663 , 135 , 3 , 10 , 0 , 12.19 , 0.955 , 12.0 , 10.8 ,
2010-06-16 15:53:32 , 50.6 , 67.5 , 101.0 , 39.0 , 33.0 , 33.0 , 33.5 , 44 , 1664 , 135 , 6 , 11 , 0 , 12.19 , 0.955 , 12.0 , 11.3 ,
2010-06-16 15:53:33 , 50.6 , 67.5 , 101.0 , 39.0 , 33.0 , 33.0 , 33.5 , 44 , 1666 , 135 , 4 , 10 , 0 , 12.19 , 0.955 , 12.0 , 10.8 ,
2010-06-16 15:53:34 , 50.6 , 67.5 , 101.0 , 4294967285.0 , 4.0 , 33.0 , 33.5 , 44 , 1665 , 135 , 0 , 9 , 0 , 12.19 , 0.955 , 12.0 , 11.3 ,
2010-06-16 15:53:35 , 50.6 , 67.5 , 101.0 , 39.0 , 33.0 , 33.0 , 33.5 , 44 , 1663 , 135 , 1 , 9 , 0 , 12.19 , 0.955 , 12.0 , 11.3 ,
2010-06-16 15:53:36 , 50.6 , 67.5 , 101.0 , 39.0 , 33.0 , 33.0 , 33.5 , 44 , 1666 , 135 , 2 , 9 , 0 , 12.19 , 0.955 , 12.0 , 11.3 ,
2010-06-16 15:53:37 , 50.6 , 67.5 , 101.0 , 39.0 , 33.0 , 33.0 , 33.5 , 44 , 1664 , 135 , 2 , 9 , 0 , 12.19 , 0.955 , 12.0 , 10.8 ,
2010-06-16 15:53:38 , 50.6 , 67.5 , 101.0 , 39.0 , 33.0 , 33.0 , 33.5 , 44 , 1665 , 135 , 2 , 9 , 0 , 12.19 , 0.955 , 12.0 , 11.3 ,
E.g.2
2010-06-16 14:48:54 , 701.0 , 924.0 , 1401.0 , 70.0 , 53.0 , 64.3 , 53.8 , 44 , 1655 , 344 , 0 , 0 , 0 , 12.17 , 1.035 , 25.5 , 26.3 ,
2010-06-16 14:48:55 , 701.0 , 924.0 , 1401.0 , 70.0 , 53.0 , 64.3 , 53.8 , 44 , 1647 , 344 , 0 , 0 , 0 , 12.17 , 1.035 , 25.0 , 25.8 ,
2010-06-16 14:48:56 , 701.0 , 924.0 , 1401.0 , 70.0 , 53.0 , 64.3 , 53.8 , 44 , 1657 , 344 , 0 , 0 , 0 , 12.17 , 1.035 , 25.5 , 26.3 ,
2010-06-16 14:48:57 , 701.0 , 924.0 , 1401.0 , 70.0 , 53.0 , 64.3 , 53.8 , 44 , 1648 , 344 , 0 , 0 , 0 , 12.17 , 1.035 , 25.0 , 25.8 ,
2010-06-16 14:48:58 , 701.0 , 924.0 , 1401.0 , 70.0 , 127.0 , 64.3 , 53.8 , 44 , 1648 , 344 , 0 , 0 , 0 , 12.17 , 1.035 , 25.5 , 26.3 ,
2010-06-16 14:48:59 , 701.0 , 924.0 , 1401.0 , 70.0 , 53.0 , 64.3 , 53.8 , 44 , 1652 , 344 , 0 , 0 , 0 , 12.17 , 1.035 , 25.0 , 25.8 ,
2010-06-16 14:49:00 , 701.0 , 924.0 , 1401.0 , 70.0 , 53.0 , 64.3 , 53.8 , 44 , 1647 , 344 , 0 , 0 , 0 , 12.17 , 1.035 , 25.0 , 25.8 ,
2010-06-16 14:49:01 , 701.0 , 924.0 , 1401.0 , 70.0 , 53.0 , 64.3 , 53.8 , 44 , 1646 , 344 , 0 , 0 , 0 , 12.17 , 1.035 , 25.0 , 25.8 ,
2010-06-16 14:49:02 , 701.0 , 924.0 , 1401.0 , 70.0 , 53.0 , 64.3 , 53.8 , 44 , 1647 , 344 , 0 , 0 , 0 , 12.17 , 1.035 , 25.0 , 25.8 ,
This does not occur when using HWMonitor, or Nvidia's System Monitor *unless* they run concurrently with GPU-Z. GPU-Z does this whether or not any other monitoring software is running concurrently.
I'm assuming this is a bug with GPU-Z and not my hardware. Can anyone confirm this or should I RMA the gfxcard?
mobo: Asus Rampage III Extreme
CPU: Core i7 930 D0
gfxcard: Asus ENGTX480/2DI/1536MD5
gfx driver: nvidia 257.21 drivers
E.g.1:
E.g.2
CPU: Core i7 930 D0
