OK...this Crucial 4x4GB DDR4 kit will NOT run in quad channel...thoughts?
57 (0.01/day)
Atlanta, GA
Processor Intel i7 5820K
Motherboard Asrock X99M Killer
Cooling Corsair H70 with 2xNidec Beta V's
Memory Crucial Sport 2x4GB DDR4-2400
Video Card(s) XFX R9 295X2 with 2xNidec Beta V's
Storage OCZ Vertex 4 128GB, WD Blue 1TB, 2xHitachi 500GB in RAID 0
Display(s) Asus PB287Q on Dell MSA14 Flex-Arm
Case Cooler Master N200
Power Supply OCZ ZX 1000w
Mouse Logitech G700s
Keyboard Razer Blackwidow Chroma
Software Windows 7 Pro 64-bit
This stuff exactly:
http://www.crucial.com/csrusa/en/bls4k4g4d240fsa
Two sticks in Dual Channel? No problem. XMP works fine.
Triple sticks in Triple Channel? No problem. XMP works fine.
Quad channel? Ain't happening. Even at 2133Mhz and 1.3v (rated for 2400 @ 1.2v). System will either hang on post, system reboots during Windows startup, or system will crash when in Windows. CPU overclocked or not, doesn't matter.
This has been in two different systems...FIVE different motherboards...three different CPU...TWO different kits...same problem. Get a EVGA 4x4GB DDR4-2800 kit? No issues...booted right up and been working for a couple days now intensively.
So what gives? Even with motherboards that are certified for the RAM (Asrock X99 Extreme-4 and Arock X99M Killer) same issues. RAM been Memtested...all of it. No physical issues with the RAM. No errors.
Yeah...it's something to do with this model, these kits, and quad channel. Makes no sense to me!
Thoughts?
Mine works fine, just luck of the draw imho.
I have three other Crucial kits, too, no problems with any of them. 32GB 2133 MHz, 2 16 GB 2400 MHz, 16 GB 2666 MHz (which I'm testing for review right as I type this).
Wondering if the cooling might paly a role in this myself, to be honest.
Well wtf? Got a 16GB DDR4 kit you'd trade me then?
I tend to keep my gear until useless or out-dated. Nearly everything I have is review samples.
But that's just how it works sometimes. I got a Corsair DDR3 kit that only works in one board, too. Any other board... no boot.
Sell me something for a good price then? :-) I'm interested in knowing if this kit will work for you for some odd reason.
Sell me something for a good price then? :) I'm interested in knowing if this kit will work for you for some odd reason.
That sounds risky. LoL. Mine work already, so... heh.
I can post a pic of your kit, too, it's running in my memory testing station right now.
What I can say is that this kit will boot up with 2400 MHz right off the bat,so if your CPU's memory controller sucks, then I could understand why it might be a problem...or maybe it's a BIOS timing thing...or... or....
added it:
I had problems with the first set that I received of those ram.
Dualchannel was working just fine, but even tri og quad just didnt work at all.
It turned out 2 sticks was failling, so I got another set from another batch, ever since Ive had no problems, everything works just like its supposed to.
All I can say is that Im NEVER ever going to save a few bucks on ram again, so in the future Im going with G.Skill no matter the price.
YES! I think you are completely correct. I've found since my OP that triple channel doesn't work perfectly either. It would boot into Windows randomly but not all the time. Took out the third stick and boom...booted just fine even after a few restarts and what not. No issues.
So yeah, bad batch or something but only dual channel works with this RAM. I don't for a second believe it to be anything else other than the RAM. Not memory controller, motherboard, or anything like that. Just shit RAM.
I think its because Crucial have their own ram production, and everyone else making DDR4 is using Hynix modules from Samsung.
That would make sense. Regardless, they're jacked and I'll just be getting new RAM. Problem solved!
Yeah, Im thinking the same thing, then I can use these problem ram to my wifes Skylake platform later this year:peace::clap::nutkick:
Crucial is Microns consumer division.
They aren't jacked. You will always get a bad sample from any manufacturer of any product. Crucial is owned by Micron, the huge and highly respected memory chip manufacturer.
They'll RMA any RAM that's not working properly. The RAM carries a lifetime warranty, right?
That depends on were u live some has limit warranty can be 5-10-15-25 years and other places lifetime.
I see,...it's lifetime for RAM here.
(or I don't buy it)
I had my first ever RMA for RAM last year. It was Patriot and they sent me back much better RAM than I had.
Service was fast and easy.
So I took my chance and bourght 4x4GB G.Skill DDR 4 ram today, just for the sake of it.
If it turns out thats my Crucial dosent work properly, I will shoot them with my shotgun in my garden
Buy local or order online? Let me know what happens as soon as you can! :-)
bourght it online, so going to get it in 3-4 days time, since their are not in stock
I will make a shot video if 24 GB DDR4 being shot away with a shotgun:peace::lovetpu:
Ahhh OK...just noticed you're in Denmark. I was like, everywhere has them! :-p
