[WTB] (ON HOLD)
265 (0.05/day)
Heatware
25 0 0
System Name Intranetusa PC
Processor i7 2600K @ 4GHz
Motherboard Asrock P67 Extreme4
Cooling Cooler Master N520
Memory 16GB DDR3 1600MHz RAM
Video Card(s) GTX1060
Storage Samsung SSD, Samsung 1TB Spinpoint, Hitachi 2TB
Case Cooler Master Elite
Power Supply Zalman 750watt PSU
Software Windows 7
CURRENTLY ON HOLD
Want to buy 2.5 laptop and 3.5 desktop harddrives.
Looking for at least 250gb for 2.5 inch and at least 500GB for 3.5 inch (Ill consider super cheap 320gbs)
MD-USA
Are you looking for normal HDs or SSD.
Normal harddrives. May consider cheap older ssds
New or used?
It will be hard to find a new HDD under 500 GB. If new, check "Toshiba MQ01ABF050" 500GB 5400 RPM 2.5" HDD or "Toshiba DT01ACA050" 500 GB 7200 RPM 3.5" HDD. They aren't expensive.
When do you need them by, I have lots of 250gb to 500gb HDs but they are at home. I wont be back for 2-3 weeks.
New or used?
Either new or used is fine. Im just looking for cheap ones because I'm looking for 4-7 3.5s and 4-5 2.5s.
4TB capacity for 3.5. 4x 1TBs or 8x 500GBs, etc
And maybe 4-5 2.5 inch
I'm not in a rush. Several weeks.
if still looking pm me i may be able to help you out with the 2.5 inch hdds
You didn't put where you live.
I have a bunch of 3Tb 3.5 drives
Thanks all. I'm currently putting this on hold. I have received a few offers and will reach out to folks when I figure out if I need anymore.
