OneOdio Launches its Monitor 60 Professional Wired Headphones
47,912 (7.37/day)
OneOdio, designer and manufacturer of professional-grade audio equipment, today launches the latest edition to its audio range; the Monitor 60 professional wired headphones. The Monitor 60 headphones are designed to provide maximum comfort to users, so that they may be worn for long periods of time and are available on Amazon for $79.99 and Amazon UK for £67.99 using the coupon code.
Ideal for DJs and pros, the Monitor 60 headphones are suitable for use in recording studios, post-production, or within broadcasting situations and also perform well just plugged into the TV, phone or for other daily usage activities. With Industry-leading ultra-high resolution audio, and developed by OneOdio's professional tuning team who conducted thousands of sound adjustments and tried hundreds of earmuffs, the Monitor 60 reproduce rich details and achieve the ideal sound performance.
Thanks to the 50 mm drivers and 38 Ohm impedance, the headphones deliver beautiful, balanced and accurate sound over the entire frequency range with solid bass, clear midrange and high pitches and vocals, allowing the wearer to hear every detail of their music recording.The headphones feature an ergonomic design with a flexible headband and oval-shaped full-on leather like breathable earmuffs that closely follow the contours of the ears to provide excellent sound insulation even in noisy environments. The earmuffs can also be flipped 180°, making them ideal for one-ear monitoring whilst DJing for example. The Multi-angle folding make allows them to be stored and carried with ease.
The headphone arms and headband have also been rigorously ergonomically designed with a wider headband for smoother stretching and thicker and reinforced connections. The jewellery-grade stainless steel ensures sturdiness and durability and improves the appearance of the headset as well.
The option between the 2 m 3.5 mm to 6.35 mm coiled cable for monitoring and the 1.2 m 3.5 mm to 3.5 mm straight cable complete with a microphone,, make these headphones completely multi-functional whether it be for studio or general use.
The OneOdio Monitor 60 headphones are available on Amazon for $79.99 and Amazon UK for £67.99 using the coupon code.
Features:
  • Hi-Res Audio Verification
  • Ideal for DJs & Audiophiles
  • Made for Studio Audio Pros
  • Adapter-free Cables
  • Single Side Monitoring
  • High Protein Memory Earmuffs
  • 50 mm Dual Dynamic Drivers
  • Included in the box: Monitor 60 Wired Headphones, User manual, PU bag, and Aux Cable x3
Specifications:
  • Frequency Range: 20 Hz-40 KHz
  • Speaker: 50 mm neodymium driver
  • Impedance: 38 Ω
  • Sensitivity: 110+3 dB
