OpenCl not checked for HD 6520G
mokos
5 (0.00/day)
Hello Wizzard
I tried your tool. It is nice and useful. But I experienced that it fails to display that the device with this driver supports OpenCl. It would be nice if you could fix this.
I think the name of the device is wrong (for OpenCl) since clinfo states it is BeaverCreek.
Thanks in advance.
mokos
check if the attached build shows the correct opencl status.
and why do you guys use annoying ad-infested abload.de? lots of better alternatives out there, including techpowerup.org where you can upload using tpucapture, our own screenshot tool.
Thank you it works.
For abload I didn't know any alternative, since it is the most used one and the only one I remembered, I think next time I may use some better alternative.
HD6310 OpenCl check
Hello Wizzard
Same problem with HD 6310, seen with 0.6.2 and OLC driver installed.
The OpenCl GPU device name ist Loveland.
Thanks
mokos
EDIT: Woulden't it be relative simple to integrate to read out the Device Type GPU if there ist some positive return ist made, check opencl instead have all the dev names listed, in the tool? But I don't have Knowledge in OpenCl, so I was just wondering, why it is how ist is now.
Number of platforms: 1
Platform Profile: FULL_PROFILE
Platform Version: OpenCL 1.1 ATI-Stream-v2.3 (451)
Platform Name: ATI Stream
Platform Vendor: Advanced Micro Devices, Inc.
Platform Extensions: cl_khr_icd cl_amd_event_callback cl_amd_offline_devices cl_khr_d3d10_sharing
Number of devices: 2
Device Type: CL_DEVICE_TYPE_GPU
Device ID: 4098
Max compute units: 2
Max work items dimensions: 3
Max work items[0]: 256
Max work items[1]: 256
Max work items[2]: 256
Max work group size: 256
Preferred vector width char: 16
Preferred vector width short: 8
Preferred vector width int: 4
Preferred vector width long: 2
Preferred vector width float: 4
Preferred vector width double: 0
Native vector width char: 0
Native vector width short: 0
Native vector width int: 0
Native vector width long: 0
Native vector width float: 0
Native vector width double: 0
Max clock frequency: 492Mhz
Address bits: 32
Max memory allocation: 134217728
Image support: Yes
Max number of images read arguments: 128
Max number of images write arguments: 8
Max image 2D width: 8192
Max image 2D height: 8192
Max image 3D width: 2048
Max image 3D height: 2048
Max image 3D depth: 2048
Max samplers within kernel: 16
Max size of kernel argument: 1024
Alignment (bits) of base address: 32768
Minimum alignment (bytes) for any datatype: 128
Single precision floating point capability
Denorms: No
Quiet NaNs: Yes
Round to nearest even: Yes
Round to zero: Yes
Round to +ve and infinity: Yes
IEEE754-2008 fused multiply-add: Yes
Cache type: None
Cache line size: 0
Cache size: 0
Global memory size: 134217728
Constant buffer size: 65536
Max number of constant args: 8
Local memory type: Scratchpad
Local memory size: 32768
Kernel Preferred work group size multiple: 32
Error correction support: 0
Unified memory for Host and Device: 0
Profiling timer resolution: 1
Device endianess: Little
Available: Yes
Compiler available: Yes
Execution capabilities:
Execute OpenCL kernels: Yes
Execute native function: No
Queue properties:
Out-of-Order: No
Profiling : Yes
Platform ID: 0108A40C
Driver version: CAL 1.4.1016
Extensions: cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_3d_image_writes cl_khr_byte_addressable_store cl_khr_gl_sharing cl_amd_device_attribute_query cl_amd_printf cl_amd_media_ops cl_amd_popcnt cl_khr_d3d10_sharing
Device Type: CL_DEVICE_TYPE_CPU
Device ID: 4098
Max work items[0]: 1024
Max work items[1]: 1024
Max work items[2]: 1024
Max work group size: 1024
Native vector width char: 16
Native vector width short: 8
Native vector width int: 4
Native vector width long: 2
Native vector width float: 4
Max clock frequency: 1600Mhz
Address bits: 32
Max memory allocation: 536870912
Image support: No
Max size of kernel argument: 4096
Alignment (bits) of base address: 1024
Denorms: Yes
Quiet NaNs: Yes
Round to zero: Yes
IEEE754-2008 fused multiply-add: No
Cache type: Read/Write
Cache line size: 64
Cache size: 32768
Global memory size: 1073741824
Local memory type: Global
Kernel Preferred work group size multiple: 1
Unified memory for Host and Device: 1
Profiling timer resolution: 639
Available: Yes
Execute native function: Yes
Queue properties:
Out-of-Order: No
Profiling : Yes
Name: AMD E-350 Processor
Vendor: AuthenticAMD
Driver version: 2.0
Extensions: cl_amd_fp64 cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_byte_addressable_store cl_khr_gl_sharing cl_ext_device_fission cl_amd_device_attribute_query cl_amd_media_ops cl_amd_popcnt cl_amd_printf cl_khr_d3d10_sharing
what if multiple cards are installed? and integrated graphics, not all cards support opencl even if the opencl driver is installed
Ok, then it seems reasonable to do it this way, even if I never heared/have seen of such weird combinations (with AMD GPU, on Nv side I 'm not shure), I was just curious why you make this expenditure.
edit: and have overseen all the old Intel Igpu thing.
can you post a gpuz screenshot for that loveland gpu ?
