Optimizing bioshock 2
3,993 (0.60/day)
Maryland
System Name HAL
Processor Core i9 14900ks @5.9-6.3
Motherboard Z790 Dark Hero
Cooling Bitspower Summit SE & (2) 360 Corsair XR7 Rads push/pull
Memory 2x 32GB (64GB) Gskill trident 6000 CL30
Video Card(s) RTX 4090 Gigagbyte gaming OC @ +200/1300
Storage (M2's) 2x Samsung 980 pro 2TB, 1xWD Black 2TB, 1x SK Hynix Platinum P41 2TB
Display(s) 65" LG OLED 120HZ
Case Lian Li dyanmic Evo11 with distro plate
Audio Device(s) Klipsh 7.1 through Sony DH790 EARC.
Power Supply Thermaltake 1350
Software Microsoft Windows 11 x64
Just a little fyi.
This is for people using onboard sound.
I didn't want this to get buried in the details thread, which is kind of unrelated.
I'm stuck using onboard atm.
Xfi FTL..
80 bucks and the thing never worked right.
I digress. XD
I found that setting the in game sound to mono and turning off hardware acceleration for XP users.
Will give a nice frame rate increase.
"It might make audio skip in cutscenes though, so this might not be advisable"
For some reason I was getting some laggy spikes which just seemed weird to me.
The game is really not that demanding at all it would appear.
It shouldn't be anyway, not with all those visible polygons.
I also went into the default config file. "careful in there, don't screw with anything you don't understand".
Changed these from their original.
Lowers the amount of maximum incoming sounds.
Makes it much easier for any audio processor.
Truth is some games just push audio to far.
Like Oblivion for example..lol
[ALAudio.ALAudioSubsystem]
Channels=20
[FMODAudio.FMODAudioSubsystem]
MaxChannels=32
I also raised the cache size from default "i think" 32 meg, to 128 meg.
Just wanted to see if it hurt anything.
Doubt it's even useful TBH.
I wouldn't recommend going over 128 likely even if it is.
Made no visible improvement or degradation, never the less.
If you have anything to add, please do feel free.
Blackjack49
138 (0.02/day)
Processor dual Intel(R) Core(TM)2 CPU 6300 @1.86GHz
Memory 300gb
Video Card(s) Nvidia Geforce 9800 GT 1gb
alright first of all what are the settings you are playing as and what can they be and what resolution are you playing on
3,993 (0.60/day)
Maryland
System Name HAL
It's all maxed out.
You realize I'm going to laugh if you say "there's your problem" right?
8800gtx @640 core 1400 shader.
3 gb ram ddr2 800 @ 4-4-4-12
E8400 conroe @ 4.0ghz.
Bioshock 2 is the Vengeance engine.
Bioshock 1 was Vengeance engine.
Ran that at max too.
Resolution is unfortunately 1808x1004. thanks be to nvidia for screwing the pooch on the G80 core and breaking hdmi compliance.
Leading me to these ridiculous custom resolutions.
I used to play all games at 1920x1080.
I see your a new fellah here.
Welcome to the forums.
5,968 (0.93/day)
New York
Processor AMD Ryzen 9 9950x / AMD Epyc 7773x
Motherboard Gigabyte B850 Gaming X/ ASROCK ROME
Cooling Be Quiet Dark Rock Pro 4(Custom) / Custom Air
Memory 64GB Crucial Pro 6400 / 384GB
Video Card(s) MSI RTX5070Ti(Temporary)/ 4X RTX3090
Storage Adata SX8200 1TB NVME/WD Black 1TB NVME
Display(s) Dell 27 Inch 165Hz
Case Lian Li A3 Mini
Audio Device(s) IFI Zen Dac/JDS Labs Atom+/SMSL Amp+Rivers Audio
Mouse Logitech G502 SE Hero
Keyboard Corsair K70 RGB Mk.2
VR HMD Samsung Odyssey Plus/ Quest 3
I haven't had the sound problem you speak of though, but did you buy the sound card only for bioshock.
lol you fixed it
3,993 (0.60/day)
Maryland
System Name HAL
lol..nah didn't buy it for bioshock, had it for a while.
Thing just never worked right.
Can't even get my dam system to recognize it.
fyi going hardware acceleration off might make audio skip in cutscenes, so it may not be advisable.
Mussels
Freshwater Moderator
58,412 (7.78/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
i maxed it out (one GPU) at 1080p and had zero lag throughout the entire game.
I think you're onto something regarding the audio however, as mine was crap (no 5.1 sound, and various sounds would stop others playing - EG, when people talked over the 'intercom', gunfire would stop sometimes)
3,993 (0.60/day)
Maryland
System Name HAL
Already a patch out lol.. link posted.
4,926 (0.79/day)
Multidimensional
System Name Intel NUC 12 Extreme
Processor Intel Core i7 12700 (E Cores Disabled)
Motherboard Intel NUC Module Motherboard
Cooling NUC Blower Cooler + 3 x 92mm Fans
Memory 64GB Corsair 3200Mhz CL22
Video Card(s) PowerColor RX 9070 16GB Reaper
Storage Silicon 512GB Gen4 SSD + 256GB SD Card
Display(s) Sony 4K Bravia X85J 43Inch TV 120Hz
Case Intel NUC 12 Extreme Mini ITX Case
Audio Device(s) Realtek Audio + Dolby Atmos
Power Supply SFX FSP 650 Gold Rated PSU
Mouse Logitech G203 Lightsync Mouse
Keyboard Red Dragon K552W RGB White KB.
VR HMD ( ◔ ʖ̯ ◔ )
Software Windows 10 Home 64bit
Benchmark Scores None. I also own a Apple Macbook Air M2
Theres a patch, i did get an update a couple of days ago but wasnt sure if it was for games for windows!
3,993 (0.60/day)
Maryland
System Name HAL
AsRock
TPU addict
19,255 (2.95/day)
UK\USA
Cooling D15
Did you apply AA to it too and if so how much ?. Or did you leave it without AA by default.
Just getting a idea how to set the game up when i do get around in playing it as i have it sitting here doing nothing as i'm playing Dragon Age at the moment and the wife don't want me playing 1/2 dozen games at one time lol.
Either way in no rush in playing it as i'm waiting for their promised widescreen fix :).
Mussels
58,412 (7.78/day)
Oystralia
there were no AA/AF settings in game. Didnt need em, game looked fine.
3,993 (0.60/day)
Maryland
System Name HAL
Also you can't even force AA in this game unless u use nhancer.
Which I wouldn't recommend, because enhancer likes to write all kinds of entries into your registry .
Which can corrupt your game entirely.
I had to reinstall bioshock after trying enhancer, because it totally messed it up.
Every time I took a step, the entire game turned into huge polygons, tearing all over the place.
Yea after playing for a bit, you realize the game really doesn't even need AA.
It's just the polygon count that bugs me sometimes.
3,176 (0.52/day)
Brockport, NY
System Name Is rly gud
Processor Intel Core i5 11600kf
Motherboard Asus Prime Z590-V ATX
Memory (48GB total) 16GB (2x8GB) Crucial Ballistix Sport 3000MHZ and G. Skill Ripjaws 32GB 3200MHZ (2x16GB)
Video Card(s) GIGABYTE RTX 3060 12GB
Storage 1TB MSI Spatium M370 NVMe M.2 SSD
Display(s) 32" Viewsonic 4k, 34" Samsung 3440x1440, XP Pen Creative Pro 13.3
Power Supply EVGA 600 80+ Gold
VR HMD Meta Quest Pro, Tundra Trackers
Silly but necessary question. Have you disabled your onboard when using the card? Sneekypeet pointed out to me yesterday that windows may detect it and cause problems. Look in device manager for any yellow exclamation points.
3,993 (0.60/day)
Maryland
System Name HAL
cool thank you, i will look into that.
Much appreciated :)
Edit: No conflicts..
I'm starting to think thay maybe even changing anything in the config might lead to some securerom issue or something..
Idk why I get this issue that seems like a memory leak.
Also, I always turn off background programs, but duly noted.
Blackjack49
138 (0.02/day)
Memory 300gb
just a little idea....make sure you have shut down everything in the background that you don' t need while playing the game it helps a lot of my games out.
