Hey guys! I'm here to answer any questions
THRASHZONE: Interesting thoughts
Though I believe your results are definitely atypical. In all our tests across many CPUs, the Sig definitely has the advantage.
I also really, really think your testing can benefit with even tighter temp controls. A 2C ambient difference will throw off your results like crazy. That's why we go nuts with our testing methods internally. Otherwise, what might seem like a small temp change will compound with liquid temps, etc.
For the o-rings, you'll see the shape of the jet platform in the cold plate itself and that it makes contact everywhere. In actuality, the o-ring gives very little performance one way or another, regardless of position. The metals forming the bows are vastly stronger.
And we've tested o-rings and placements and all that and it really has nearly zero impact on performance. You can try taking out the center o-ring, performance will change slightly depending on certain factors, but again this is really into the weeds stuff.
What you're chasing here is the idea of contact. Which is one part cold plate, one part IHS. We can't account for the IHS. And your testing definitely is into the stages of tweaking the block to match your unique IHS perfectly, which is awesome though won't work for everyone.
Which brings me to...
OVERALL PERFORMANCE: VSG's test shows a good difference between the blocks with a very light overclock. When builders start going for bigger overclocks and with CPUs that run even hotter -- like HEDTs CPUs and AMD's models -- the benefits of our high surface area fin design become more pronounced.
SIGNATURE PERFORMANCE: When pushing the hot chips at high overclocks, the Signature can perform around a 2C improvement (again, results will vary).
