Overclocking Help - Computer Won't POST
473 (0.08/day)
South Africa
Processor Intel Core i7 4770K @ 4.4Ghz
Motherboard Asus Z87 Deluxe
Cooling Corsair H100i CPU Cooler, 4x 200mm, 1x 140mm, 1x 120mm
Memory 16GB Corsair Dominator Platinum DDR-3 1600
Video Card(s) GALAX GTX 980Ti HOF 6GB
Storage Corsair Neutron GTX 240GB -- Samsung 850 EVO -- WD Black 2TB
Display(s) DELL U2713HM Ultrasharp 2560x1440P & Samsung 27" P2770 1920x1080P
Case Thermaltake Chaser MK-I
Audio Device(s) Asus Xonar STX to Klipsch SB-3 & Sennheiser HD650 Headphones
Power Supply Antec Signature Series 850W PSU
Mouse Razer Naga Epic
Keyboard Corsair K70 RGB
Software Windows 7 Professional 64 bit
Hi Guys,
I'm having some problems overlocking my pc:
If I raise the BCLK above 145(145*20) the pc doesn't post anymore.
I have tried the following settings aswell:
CPU Voltage: 1.40v
PLL Voltage: 1.88v
QPI/DRAM Core voltage: 1.35v
DRAM Bus Voltage: 1.64v
I also tried messing with the RAM timings (Changed from auto to 8/8/8/24)
Am i missing anything?
You don't need 1.88v Pll for those clocks, drop them to 1.6-17v, I would also lower your QPi volts a little, then lower your memory multiplier down low to eradicte memory as a deciding factor and leave on auto timings for the moment..... just give that a go and report back.
Edit: When i said lower, I meant from what you have tried, not the screenies, I would set QPI volts at say 1.35v to start with, and 1.35v for the CPU should be more than enuff for a 150 BClk
What's your uncore multi?
Thanks man, it appears my uncore multiplier was set too high....
Anyway, i managed to get my system to a stable 4Ghz Using the following settings:
Vcore: 1.2375v
QPI/DRAM: 1.2375v
CPU PLL: 1.84
The temperature is reaching a max of 68c on PRIME95. Not bad with an ambient temperature of about 30c
I was about to say to raise the CPU multi up to 21x and do a 190 BCLK. i leave my PLL multi on auto :)
looking good there, and not a bad guess on the Uncore multi!
