- Apr 11, 2020
- 2 (0.00/day)
Processor | Intel i7-9700k |
Motherboard | Asus Z390F Gaming Motherboard |
Cooling | Liquid Cooling kit NOX Hummer H-240AURA RGB |
Memory | 2x8GB Corsair DDR4 Vengeance @RGB PRO 3200M |
Video Card(s) | Zotac Gaming Geforce RTX 2080Ti 11GB |
Storage | 2xSSD Kingston A400 480GB / Seagate Barracuda 2TB Sata3 |
Display(s) | MSI 27inch curve 144hz 1440p Monitor |
Case | VersusPC gaming case (large and well ventilated) |
Power Supply | NOX Hummer GD850 80plus GOLD |
Mouse | Steelseries Rival 600 |
Keyboard | Roccat Vulcan 120 AIMO |
Software | Windows 10 |
Hello everyone! First time poster, would like some help dealing with a recent issue I've been having.
My tech knowledge is very basic. Hope this is the right place and format to post in.
Specs:
- Intel i7-9700K @ 3.6gHz
- Asus Z390F Gaming Motherboard
- 2x8GB Corsair DDR4 Vengeance @RGB PRO 3200M
- Zotac Gaming Geforce RTX 2080Ti 11GB
- 2xSSD Kingston A400 480GB (in RAID or whatever it's called)
- Seagate Barracuda 2TB Sata3
- NOX Hummer GD850 80plus GOLD
- Liquid Cooling kit NOX Hummer H-240AURA RGB
Problem:
For the last month or so, I've been noticing a strange behaviour of one of the GPU fans. Basically, it will start fanning at full speed (100%) for a few seconds, calm down, and then repeat it for a few seconds every 10 seconds or so. This symptom can be quite inconsistent. This happens when my GPU hits 80degrees temperature, which causes Fan 1 to max out until it goes back down to 77-79 degrees, until I goes back up to 80degrees a few seconds later, and it keeps going like this.
In general, I get around 100% GPU load on many games that aren't very demanding, and considering I'm running a 2080Ti... surely the load shouldn't be 100%?
After a bit of research, I've installed MSI Afterburner and put a custom fan curve (just slightly steeper than default, not much) and that way the temp stays around 77-78degrees max and I don't get the fanning issue. That being said I still think there must be an issue as it started doing it for no reason. I live close to the sea in a very very dusty environment, but I've given it a good cleaning and haven't noticed any difference.
I've been told I shouldn't trust my PSU with this gaming rig, but the person didn't actually explain why, simply stating it's "not great"and I was hoping for a slightly more scientific explanation before I start taking apart a machine that cost me 2 months salary.
So basically what I'd like to figure out is:
- Why did this fanning problem start?
- Is it because of the PSU? If so, should I change it, how and to what PSU?
- Why is the GPU getting so hot in general, and why now and not months ago when I started using it?
PS: please note that despite all this, the PC is still performing very well at 1440p 144hz on all games on Ultra (except Minecraft with shaders for which I get shitty performance for some reason...).
I hope I've explained it not to confusingly but please tell me if any info is missing! Here's a screenshot of that GPU-Z monitoring software that clearly shows the problem: look at Fan 1 Speed for the GPU and you can see all the pikes. This screenshot was taken in one of the worse moments of "overfanning". It was happening every 5 seconds. Also see PerfCap and TDP etc...
Specs:
Problem:
