- Sep 18, 2016
- 470 (0.15/day)
- Scotland
I keep getting "standard" replies to questions to EVGA when trying to determine the answer to this question.
I know this question has been answered before to an extent but I still don't believe the answer "fully" explains the position.
To see what I mean this is the latest email I've sent off:
If I receive a worthwhile reply I'll post it -- or if anyone can shed any further light on the nitty gritty/detail I believe it would still be worth a read and maybe of interest to some people....
To: supportEU@evga.com
I understand what you mean about the Silicon Lottery - sorry I am trying to explain what I mean my question a little better...
... I mean are the Nvidia GPU's that you place on your classified board tested for higher stability than for example the EVGA Founders Edition?
I will try to explain what I mean better by offering two schools of thought and asking which is true:
First School of Thought/Theory
A Founders Edition has a boost clock of 1700+.... so these cards may only be tested to ensure they reach 1700+ and may not even overclock to 1860 (Classified is factory overclocked to 1860)... so there must be at least "some" test to ensure they can perform stable at this factory overclock as they "are" clocked higher than a Founders Edition.
This "test" although does not guarantee any "even higher" overclocks would still 'in effect' give you at least a little extra luck at getting a more overclockable GPU. This would still be worth knowing!!
Second School of Thought/Theory
The second school of thought or theory is that in fact while all cards will overclock differently (silicon lottery as you say) and some may never reach 1900+, it is still generally accepted by EVGA that ALL NVIDIA Pascal GPU's will "AT LEAST" overclock to your factory overclock of 1860 therefore "no extra" testing is needed of GPU's before they are picked for use on a Classified board.
Which school of thought/theory is actually true of EVGA? (This is what I am trying to find out -- if there is potentially but not necessarily better quality GPU's used in the Classified due to the GPU's having to pass stability test at higher clock. The Silicon Lottery aside do I have any "extra" chance of getting a better GPU due to buying a Classified instead of a lower spec card at all? Even in the smallest degree?
Do you see what I mean now? If there is even a "slight" chance that purchasing a Classified will give me an extra 1% chance of having a better binned GPU this is still worth knowing about!
Or are ALL GPU's equally placed. Are they only tested once then no other tests are carried out before GPU's are allocated to a board?
. Is there "exactly" the same chance "statistically" of getting a more overclockable GPU whether you have a Founders Edition (low end) or Classified (High End).?
Thanks...
Nick Peyton
Thanks...
Nick Peyton
