Passive/Copper NB coolers.
GLD
1,631 (0.23/day)
City 17, California, U.S.A.
Processor AMD Ryzen 7 5700X, AMD Wraith Prism.
Motherboard ASUS TUF X570-Plus (Wi-Fi).
Cooling Antec 120mm RGB case fans.
Memory 4x8gb, G.SKILL F4-3600C16D-16GVKC.
Video Card(s) Sapphire Pulse RX 6700.
Storage PNY XLR8 CS3040 2TB 4.0x4 NVMe ssd with Vantec ICEBERQ heat sink.
Display(s) ASUS VP278QG 27", 1080p, 75hz, FreeSync.
Case Antec GX202.
Audio Device(s) Onboard sound, Logitech Z625 THX 2.1's, Logitech G430 headphones.
Power Supply Seasonic Prime GX-750.
Mouse Logitech G203 Prodigy.
Keyboard Logitech G213.
Software Windows 11 Pro, @ Day 1.
hey
nice heat sinks an half desint clips to
i wouldent use them as is but with a fan i bet thed work great
copper holds heat more then aluminum
so copper isint as good at pasive cooling
thats y some of the old socket a heats sinks that had a thick copper bottem an nice aluminum fins worked so well evin better then some of my solid copper cpu heat sinks
Wow I would want this since I cant use my god damn fucking shit Zalman FHS Northbridge cooler. The hooks need to be mirrored dammit!
I like this one, I wouldn't mind getting this for myself, not sure if the mounting though will match my MB:
Enzotech = ac + zalman
ac for price, zalman for quality...
you should keep an eye (or two) on Enzotech, there first cooler is pretty damn nice both performance and noise.
check them out: http://www.enzotechnology.com/
Is't that a CPU cooler? I thought we were discussing NB coolers?
the initial poster was talking about Enzotech nb cooler, i just posted that Enzotech, being a new company and all, has much more to offer...
and yes that is a cpu cooler.
I have a Thermalright hr-05sli on my nforce4 and it keeps the temps 20c cooler than the stock heatsink. If you have the space that heatsink is one of the best, dual copper heatpipes and aluminum fins.
Right, okay. I was just thinking, if that was a NB cooler, it's a real overkill, but looks nice tho.
