PC crash while gaming
169 (0.10/day)
PC crash while gamming
i have B650 auros elite ax + 7600X + 7900XTX
when I do bench for cpu everything work well
when I use pc for work or internet it work well
but when I play Games is crush or pc restart it happened only n gamming
what the problem my GPU? or something else?
temp for all items is low so it not about temperatures.
and it happened for all games after some minutes
GPU driver new version (23.4.3)
What PSU do you have?
Reading other threads with AMD "stuttering issues" and such, people say it may be the "cheaper" AMD motherboards...
discord running? disable ingame overlay
discord run without stream just idle.
I don't have cheap mother board it B650 auro elite ax.
psu 1000W gold
sometimes my pc down and restart and sometimes only basic game crash
PC crush while gamming
temp for all items is low so it not about tempertures.
Which version of the 7900XTX do you have?
Locate LiveKernelReports folder on your system drive and upload the most recent .dmp file for analysis.
Use event viewer and start googling error codes.
it some have a lot there
The ones you uploaded from 7th of March are all related to the GPU being the culprit for the crashes. Most likely GPU related issue.
have some from today?
that from today it same problem?
Don't have errors in some crash games and shut down pc with restart.
only in games
I mean brand Gigabyte, MSI?
Gigabyte motherboard yea
Yes, the newer ones are also GPU related.
I think you should return the card under warranty
it weird because all games I use enhance sync to get 100% usage GPU too strong.
but in game Steelrising my enhance sync off and GPU get 100% usage and in work now 10 minutes without crush
It weird now I paly again WZ2 and no crush enhance sync on.
What change why some hour ago pc stack every game and now it work and maybe tomorrow it crush again
You need to give complete detailed specs of all parts in your system
Could be a PSU issue.
