PC not starting after Applying thermal paste
62 (0.02/day)
System Name Supreme Jugaad
Processor i7 2600
Motherboard P8Z77-V LX2
Cooling 2x Corsair 120mm
Memory 2x 4gb Corsair
Video Card(s) GTX 680
Storage SAMSUNG EVO 850 500GB
Display(s) 60Hz 1080p
Case Zebronics desire
Audio Device(s) Audio technica M40X
Power Supply Corsair 700w
Mouse G600
Keyboard G213
i7 2600
2x 4gb ram
Intel DH61WW
Gtx680 2 gb
Samsung Evo 512gb
Corsair GS 700
2x 1 tb drives
1x 2 tb drive
Logitech g600 & 213
So my 2600 was overheating at 98c while playing bf3 so I decided to change the thermal paste, best I could get was coolermaster mastergel and while applying the paste some of it spilled on to mobo and gpu , knowing conductivity of the paste I cleaned up entirety of the paste on board and on gpu and reapplyed the paste and carefully connected the stock cooler and started the PC
The monitor does not get any signal , the mouse led and kb led does not show up but psu and mobo led show up I am not sure what went wrong with it can anyone help me find the problem, I checked the trouble shooting flow chart but having a hard time understanding as English isn't my first language , i will try to upload some pics of the cleanup I did
What did you clean the motherboard with alcohol and toothbrush?
yeah you're still short circuited somewhere... the good news is that your board is most likely fine (ive done this with liquid metal pastes quite a bit when i first started using them).
The bad news is you now have to find that one resistor covered in paste.
Edit... just saw the pic...
I would dip a terry towel in alcohol and clean that whole thing.
Thx now I need alcohol hopefully my family won't misinterpret this....
Any other methods of troubleshooting the issue the kb doesn't have led on so is it possible a mobo issue ?
Should clarify Rubbing Alcohol not whiskey
You're after Isopropyl alcohol the stuff you'd get at the pharmacy to clean wounds. I would be concerned too if that was misinterpreted.
I brought the isopropyl alcohol and cleaned the card but the system does not boot up even without the card the mobo seems fine I cleaned up some capacitor the might have been exposed to thermal paste any suggestions ?
Update : I removed every single part and eleaned it as well as used blower before removing any thing I tried again with and without gpu and nothing worked
I then isolated motherboard from case nount and other non essential psu cables and it did not work either , I put everything back together double check everything and removed bios battery for 5 mins cleaned it and started every thing again and nothing worked, I will try to post mobo pics to see if any of you guys have clue
@Edwards 446
Just to clarify when you hit the power button nothing it all happens? If that's the case I would make sure you have the switch on the power supply in the on position and make sure that you didn't unplug any of the front header cords that plug into the motherboard for the reset switch the power switch in the hard drive activity LED.
I don't mean any offense by it but often the most simplest things tend to be overlooked and in the situation those are very easy things to check and if they do happen to be the cause of the issue it's a hell of a lot better than tearing everything apart the second or third time
Update here are gpu and mobo pcb pics
https://imgur.com/a/EqIKC
Okay so everything on case side works the psu led mobo led and all fans as well as drives as I checked but problem is the mobo has just no output nothing shows in monitor or the kb led lights up nor mouse led lights up
have you tried plugging your monitors display cable directly into both the GPU and the motherboard?(not at the same time obv) My point is to verify that either the IGpu or the DGPu are both not displaying ,because that will narrow it down to possibly the display output of the motherboard being the culprit, or the cable. Also you could try switching what type of cable you're using.
The above post is based on my understanding that everything looks like it's running but there's no display
did you bend a pin or take the cpu out of the socket?
I did take CPU out of socket after the porblem surfaced but I only cleaned it up on the top side and was aware ofdelacacy of pins so am certain of CPU and socket
I will try to get a dvi as this is what my mobo and monitor can support however am not worried about monitor or cable as if that was culprit the kb and mouse lights would still work
alcohol in the socket will cause problems. Let it dry
Took PC to a repair shop the technician said it will take couple of days to diagnose but intially the motherboard seems dead, guess I somehow killed bord, thanks everyone for help anyone know of a good board to replace :)
You might want to consider going with non-conductive thermal compounds in the future. I personally really like Gelid Solutions GC Extreme, which keeps my temps low and has a reasonable price ($9.99MSRP for 3.5g)
Also, I need to ask... exactly how did you spill the paste on the GPU?
Where is the information coming from that states Cooler Master MasterGel is electrically conductive?
I put the cooler back on and the plastic locks were not quite right so I pulled the lock a bit and the cooler came in my hand spilled the paste
And you freaked out about the electrical conductivity of the paste why? You knew about that how? What I'm getting at is, of course, there's no evidence to support your claim that the paste is electrically conductive. Unless you have some. I know it would be hard to admit you were wrong about that. And that you might have killed your hardware for no good reason. But if that's what happened you should probably acknowledge it. Ignoring facts doesn't help anybody.
I assumed that because of this line in the original poste:
Honestly, I didn't actually check. I should have. By the assumption based on that line, I figured I'd recommend non-conductive paste.
If paste gets inside the socket the main issue is that even with non-conductive paste the pins would no longer make proper contact.
MasterGel is non-conductive, so simply spilling TIM all over the motherboard won't damage anything.
Coolermaster said:
The non-curing and non-electrical conductive traits help avoid any short circuiting
I think you've accidentally shorted something out during re-assembly, and from personal experience I can only suggest checking the CPU socket. Even a small speck of dust, single slightly bent pin, or overtightened heatsink may cause the system to stop booting. Also, same thing applies to RAM slots. It happens very rarely, but last month I've got two H81 boards with the same problem - broken pin on DDR termination pin.
It doesn't matter now, he killed the machine by not taking caution cleaning it. Hard lesson learned I hope
Hey guys thanks for your support I should have checked if it was conductive I just got reply from the shop apparently some ic on board and a ram slot is broken, I don't even remember touching any ram slots lol, thank God it's not big damage else it would have been a awful job finding a new board for 2600
