PC restarts under heavy load, faulty psu?
qung3
6 (0.01/day)
Spec:
Ryzen 3 2200G
Asrock b450m(bios updated)
Corsair lpx 2x8 3200
nvidia 1070 sc
evga 450BT (psu)
Been getting black screen / restarts for awhile when playing specific games, my suspicious is on the PSU because in the games where the system restarts are games that put a lot of load into the cpu, gpu and ram, for example I cant map in path of exile for more than 15 minutes without a crash, but I can play elden ring for hours and raid in wow without a single crash, I already ruled out the ram by trying with a different one with and without xmp.
So I ran some benchmarks while looking at hwinfo and noticed that while running heaven benchmark the gpu pcie +12V input voltage drop from 11.928V all the way to 11.450V, it may be within spec but its feel like on the very low end side and thats just running a gpu benchmark.
There is no bluescreens, minidumps, nothing on event viewer beside event 41, no artifacts.
Solved: Old psu was failing. had to replaced it.
13,956 (2.04/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
You don't show your CPU temps - a lead suspect.
11.450V is a bit low, but as you noted, still within allowed limits. The allowed variance is ±5%. So 12VDC ±5% = 11.4 to 12.6VDC.
I don't think that is your problem but it is always wise to verify you are providing good, clean, stable power. So I recommend swapping in a known good PSU and see if the problem persists.
3,107 (2.01/day)
Germany
Processor AMD Ryzen 9 9950X3D
Motherboard ASRock B850M PRO-A
Cooling Corsair Nautilus 360 RS
Memory 2x32GB Kingston Fury Beast 6000 CL30
Video Card(s) PowerColor Hellhound RX 9070 XT
Storage 1TB Samsung 990 Pro, 2TB Samsung 990 Pro, 4TB Samsung 990 Pro
Display(s) LG 27GS95QE-B, MSI G272QPF E2
Case Lian Li DAN Case A3 Black Wood Edition
Power Supply Corsair RM1000X ATX 3.1
Mouse Razer Deathadder V3
VR HMD Oculus Rift S
11.4V is really low and the PSU is basically a bottom of the barrel low end unit.
i'd say it's 99.9% the PSUs fault. replace it with whatever is a reliable brand and doesn't cost too much.
1,029 (0.29/day)
Nova Scotia, Canada
Cooling Cooler Master Hyper 212 Plus
Memory 32GB 4x8 G.SKILL Trident Z 3200 CL14 1.35V
Video Card(s) PCWINMAX RTX 3060 6GB Laptop GPU (80W)
Storage 1TB Kingston NV2
Case Fractal Design Arc XL
Audio Device(s) ATH-M20x
Mouse Evga Torq X3
Software Win 11 Pro 64-Bit
Wiggle the power connectors slightly and see if the voltage changes. A bad connection can cause voltage the to drop excessively under load.
Norton
Moderator - Returning from the Darkness
14,104 (2.89/day)
Northeast USA
System Name Main PC- Gamer- Main Cruncher/Folder and too many crunching/folding rigs
Processor Ryzen 5900X- Ryzen 5950X- Ryzen 3950X and etc...
Motherboard Asrock X570 Extreme4- MSI X570S Tomahawk MAX WiFi- MSI B450M Bazooka Max and etc...
Cooling Noctua NH-U14S (dual fan)- EK 360 AIO with push/pull fans- Corsair H115i RGB Pro XT and etc...
Memory 2x16GB GSkill FlareX 3200/c14- 4x8GB Corsair Vengeance 3600/c16- 2x16GB Team 3600/c18 and etc..
Video Card(s) MSI Gaming RX 6800- Asus RTX 3070 TUF OC- MSI Ventus GTX 1660Ti and etc...
Storage Main PC (1TB WD SN850- 2TB PNY CS 3040- 2TB Seagate Firecuda) and etc...
Display(s) Main PC (2x24" Dell UltraSharp U2414H)
Case Phanteks P600s- Seasonic Q704- Fractal Meshify C and etc...
Audio Device(s) Logitech Z625 THX 2.1 speakers
Power Supply EVGA 750 G3- SeaSonic DGC 750- EVGA P2 850 and etc...
Mouse G300s
Keyboard Corsair K65
VR HMD N/A
Software Windows 10 Pro or Ubuntu
Benchmark Scores Why sit on the Bench when you can get in the game and Crunch!!!
Running a GTX 1070 at load with a 450W psu may be triggering one of the protection circuits in the psu. I had a 500W psu that used to do that at full load due to it being a little too small for the config I was running at the time- are you hearing a click when it shuts down?
I would try a known good psu as @Bill_Bright suggested- note that most 1070's recommend a 500W psu
310 (0.06/day)
System Name Uzuki Toune
Processor AMD RYZEN 7 7700X (ASUS PBO 90C Mode)
Motherboard Asus ROG Strix X670E-E Gaming WIFI
Cooling Thermalright Frostspirit 140 White V3 ARGB
Memory 32GB DDR6000 CL36 Kingston (EXPO)(16GBx2)
Video Card(s) Zotac GTX 1050TI
Storage 2TB Kingston KC3000 + 1TB Crucial P2 + 480GB Samsung Evo 850 + 480GB Kingston A400
Display(s) Dell U2723QE + Philips 221V8 (Portrait)
Case NZXT H510
Audio Device(s) Auzen X-FI Forte + Onboard Realtek 4080 -> Creative Gigaworks T40II
Power Supply EVGA G+ 650W
Mouse Logitech MX Master 3 (Work) & G103 (Play)
Keyboard iRocks K71M
the many expert wannabies above me don't seem to realize that the pcie +12V input voltage refers to the power supplied by the PCIE slot. Not the GPU 8 pin, which is the one below it.
Please don't wiggle your 24 pin motherboard connector, which is where the PCIE slot power comes from. One wrong move will bring down entire PC, not just the GPU.
The PCIE GPU 8 pin is fine, as noted by the values BELOW what the one OP is talking about
I'd argue that while the PSU is a cheap budget model. It isn't by all means a bottom of the barrel terrible choice to pick for a budget build, as verified and tested and praised by TPU's own PSU Tester (albeit for a rival website):
Its more likely that your PSU is underpowered in general and therefore not distributing its load properly between the motherboard and the GPU, so therefore under full load it just restarts to protect itself and your components.
One very less likely issue is a faulty motherboard power regulation. Like you said, the voltage drop is suspiciously low, although still within spec. If you try a new more powerful PSU and still see the same issue, the most likely culprit is the motherboard. Again I repeat, OP is talking about the power supplied by the PCIE SLOT.
Dear ppl of TPU, is it so hard for you to read something properly and slowly and thoroughly? If you can't be bothered to read, don't try help and post. Posting the wrong information cost people hard earned income and maybe even their lives in the process.
2,351 (0.43/day)
Processor Intel i7 970 // Intel i7 2600K
Motherboard Asus Rampage III Formula // Asus P8P67 Deluxe
Cooling Zalman CNPS9900MaxB // Zalman CNPS11X
Memory GSkill 2133 12GB // Corsair V 2400 32GB
Video Card(s) ASUS GTX1080 // MSI GTX1070
Storage Samsung 870EVO // Samsung 840P
Display(s) HP w2207h
Case CoolerMaster Stacker 830se // Lian Li PC-9F
Power Supply Seasonic X 850w Gold // EVGA 850w G2
Mouse Logitech G502SE HERO, G9
Keyboard Dell
Software W10 Pro 22H2
The 12V is low. 11.9V is about as low as it should go on a dip. Beyond that and you are under-powered.
But if the 5V and 3.3V dip extra low the PC will Black screen.
Please post the value of the 2 extra ranges.
Here's a comparison:
Norton
14,104 (2.89/day)
Northeast USA
Mouse G300s
VR HMD N/A
If you have some information or want to provide guidance to the OP then go ahead and do so- the additional replies are far from necessary.
phill
17,535 (3.45/day)
Somerset, UK
Power Supply EVGA 1600W T2
Mouse Corsair thingy
VR HMD No headset yet
Might not really help massively but have you a power meter that you could attach to your PSU power cable and see what the unit is actually pulling? If it's close to the 450w on the 12v line (which I'd very much doubt) then it would give reason to the issues. I have a 1070 and a 8086k running together and that pulls about 220w or so. In fairness the PSU is I think an 850w but I'd definitely like to presume that the PSU is the cause of the instability.
Another option would be, if possible, switching out a few things to see if the same issues carry on or not. Another CPU or GPU be great but if not, then maybe see if a 650w unit can be had? Suggest something Gold rated and a decent make, Seasonic, Super Flower, etc. I've been personally put off by some cheaper EVGA models (G+ 650w and 850w) as they seem to like quitting on me without much load on them....
9,340 (4.92/day)
Louisiana
Keyboard G710+x3
Yeah contact evga they should give more diagnostics to run
I'd also first check the wall plug and see just how many other rooms/ plugs/ lights run off it as well.
Default cpu/ gpu turbo clocks and just running xmp profile on the memory should still be fine on 450w if it's working
Recommended psu spec's allow quite a bit of overclocking room.
One of these comes in handy to see what's being pulled from the wall
3,994 (0.60/day)
Maryland
System Name HAL
Processor Core i9 14900ks @5.9-6.3
Motherboard Z790 Dark Hero
Cooling Bitspower Summit SE & (2) 360 Corsair XR7 Rads push/pull
Memory 2x 32GB (64GB) Gskill trident 6000 CL30
Video Card(s) RTX 4090 Gigagbyte gaming OC @ +200/1300
Storage (M2's) 2x Samsung 980 pro 2TB, 1xWD Black 2TB, 1x SK Hynix Platinum P41 2TB
Display(s) 65" LG OLED 120HZ
Case Lian Li dyanmic Evo11 with distro plate
Audio Device(s) Klipsh 7.1 through Sony DH790 EARC.
Power Supply Thermaltake 1350
Software Microsoft Windows 11 x64
Ok, I’ll say it. No need to be a smug jerk to people.
Yes, that’s what you just came across as and it’s completely unnecessary.
My first step would be to revert the system to defaults in bios, then test it. It could just be an unstable overclock. Bad memory and CPU overclocks can cause a PC to shut down. If you reset bios defaults and it keeps happening, it’s most likely the PSU in my humble opinion.
qung3
6 (0.01/day)
Already checked with xmp disabled and with another ram, tm5 all pass without errors
This is what driving me nuts, because the low voltage is on the pcie slot which is powered through the 12v in the 24pin connector, my mobo has 2 pcie slot so im going to move down the gpu and see if its make any difference.
Forgot to upload them
13,956 (2.04/day)
Nebraska, USA
Mouse Logitech M190
As I noted above, the 11.45V is a "bit" low, but still within required standards. Your PSU may be the problem but it is NOT because the 12V is running at 11.45V
And while 450W is not big, it "should" be big enough because that Ryzen 3 and your graphics solutions are not power hogs.
So "IF" the issue is the PSU, it is because that specific PSU is not meeting its own published specs. So again, until you swap in a known good PSU, all you are doing is treading water, and getting tired.
As far as the card makers recommending 500w, it is important to remember two things. (1) They have no clue what the other hardware in the computer is and (2) no way do they want to recommend an underpowered PSU.
So they base their recommendations on mid to upper power hogs. Likely a decent i5 or even i7. The OP has an i3.
Even PSU calculators pad their results. They don't want to recommend a PSU that is underpowered either, so they all pad the results, some more than others. The eXtreme OuterVision PSU Calculator is and can be the most conservative for 2 main reasons. (1) They have a team of researchers on staff constantly researching components for us to keep their extensive databases accurate and current. And (2), it is the most flexible and has the most extensive databases of available options you can enter. This allows it to factor in all possible components to accurately calculate our needs rather than guess.
Plugging the OP components in and you will see 450W is plenty - assuming it is working properly and to specs.
2,351 (0.43/day)
Keyboard Dell
SEE post #14 above.
The new info for post # 13 looks good for all rails, 12V @11.933, 5V, 3.3V.
The 12V does seem to dip lower than it should. 11.563V on dip and it's not holding at the 11.9V.
So either under-powered, aging poorly, or some other cause in your environment.
qung3
6 (0.01/day)
SEE post #14 above.
The picture is a bit missleading because I took the screenshot after heaven benchmark finished his run, thats why the 12v looks normal, under test the 12v in the mobo stay between 11.500v ~ 11.600v, the gpu 12v input voltage stay around 11.4Xv - 11.5Xv, the psu is near 5 years old.
I ordered a multimeter to confirm these readout in hwinfo, also with it I can check the psu while playing PoE (since is the only game that currently crash my system) with my phone camera pointing at the multimeter to see what was the last readout before shutting off, Im also downloading 3d mark demo to run some test tomorrow.
AsRock
TPU addict
19,255 (2.95/day)
UK\USA
Cooling D15
Yeah company's like Seasonic would have you sending that in.
3,107 (2.01/day)
Germany
i know that. i never said something else.
11.4v is really low AND the PSU is basically a bottom of the barrel low end unit.
this can still be a faulty PSU since this voltage comes the 24 Pin and should be 12V even under full load.
there is no VRM on the board generating power/voltage for the PCIe Slot...
13,956 (2.04/day)
Nebraska, USA
Mouse Logitech M190
There's a lot of misunderstanding going on here.
First, and again, the sensor on the PCIe slot should NEVER be considered an accurate voltage measuring device. At best, it tells us voltage is present.
As @jsfitz54 correctly noted, if you look at the figures in post #13, we can see the +12V is well within the allowable tolerance, with an average at a very acceptable 11.683VDC.
Even if you insist on using the PCIe sensor, look at the 12V input in post #1. It is averaging again, a very acceptable 11.619VDC.
It is NORMAL for voltages to vary a small amount as the load varies and in this case, we are talking a few 10ths of a volt - as determined by a very imprecise sensor.
:( The PSU's 12VDC output is NOT 11.4V. It is nearly 11.7V. And while that PSU may be near entry level for EVGA, but it is far from being "a bottom of the barrel low end unit".
Let's remember, it is powering a little i3 and a graphics card that could hardly be called a power hog.
Again, I am NOT saying that PSU is good. I am saying the fact its 12VDC output is slightly low is not the cause of the OP's problems.
Remember, the reason why the ATX Form Factor standard allows the +12VDC voltage to be as low as 11.40VDC is because the connected components are required to tolerate and, if necessary, compensate for those voltages.
That's fine but IN NO WAY will a multimeter tell you anything conclusive!
To properly and conclusively test a power supply unit, it must be tested under a variety of "realistic" loads then analyzed for excessive ripple and other anomalies that affect computer stability. This is done by a qualified technician using an oscilloscope or a dedicated power supply “analyzer” - sophisticated (and expensive!) electronic test equipment requiring special training to operate, and a basic knowledge of electronics theory to understand the results.
Most multimeters cannot measure anomalous AC components riding DC current, even if the user knew how to perform such tests, and understand the results. Therefore, conclusively testing a power supply is done in properly equipped electronics repair facilities, by qualified technicians.
Even many smaller shops with able technicians don't have the resources ($$$) to buy the necessary test equipment. This is why swapping in a known good power supply, a tried-and-true troubleshooting method used by amateurs and professionals alike for decades, is typically the best and easiest, conclusive alternative.
qung3
6 (0.01/day)
I borrowed a multimeter and checked the psu while shorting the power on + ground pins, everything seem to be "fine" the only oddity is that the -12v pin was at -11v, when I turn on the pc this readout go all over the place from -11.1 to -11.8, is not stable at all, the 12v is at 11.9 idle then during a benchmark it drop to 11.7, if the -12v is not used nowadays, why is that voltage not stable? I checked another PSU I have and that one reads solid stable -11.7, I cant run the pc with that unit because its an old one that doesnt even have a pcie connector and I would have to use a bunch of splitters.
I dont have the tools or the knowledge to fully disassemble the psu to check the capacitors, I still have my old mobo but I would have to buy some thermal paste to move the cpu over.
411 (0.24/day)
When my first PC went BANG! one day, I've been overkill on PSUs. I know they are not cheap like a lot of stuff lately. I gotta waste my pension check on something. You can't take it with you.
:toast:
5,487 (3.65/day)
Colorado, U.S.A.
Software Windows 11 Home
Some supplies need a load to be stable, but I thought those days are over.
3,994 (0.60/day)
Maryland
System Name HAL
Bro. Are you overclocking anything? I said revert ALL overclocks and load failsafe defaults in bios on everything... And you respond with "I set the ram to default"
Reset factory defaults on the ENTIRE system in bios if you have changed anything at all. Load failsafe defaults. Test..
johnspack
Here For Good!
6,071 (0.95/day)
Nelson B.C. Canada
System Name System2 Blacknet , System1 Blacknet2
Processor System2 Threadripper 1920x, System1 2699 v3
Motherboard System2 Asrock Fatality x399 Professional Gaming, System1 Asus X99-A
Cooling System2 Noctua NH-U14 TR4-SP3 Dual 140mm fans, System1 AIO
Memory System2 64GBS DDR4 3000, System1 32gbs DDR4 2400
Video Card(s) System2 GTX 980Ti System1 GTX 970
Storage System2 4x SSDs + NVme= 2.250TB 2xStorage Drives=8TB System1 3x SSDs=2TB
Display(s) 1x27" 1440 display 1x 24" 1080 display
Case System2 Some Nzxt case with soundproofing...
Audio Device(s) Asus Xonar U7 MKII
Power Supply System2 EVGA 750 Watt, System1 XFX XTR 750 Watt
Mouse Logitech G900 Chaos Spectrum
Keyboard Ducky
Software Archlinux, Manjaro, Win11 Ent 24h2
Benchmark Scores It's linux baby!
11.4v should not happen, period. My 12v never goes below 12v, and I have a power hog of a gpu and cpu. Please try a new psu, or borrow one from a friend.
Deleted member 185158
The PSU is junk. Crap. Garbage. A POS.
By no means should it dip below 12v if it had quality components inside.
Also, 450w (or any advertised wattage) is a peak output. The PSU is far from able to sustain this.
It's a whopping 35a 12v rail, actually only rated 420w peak.
That's only 5 amps more than the +5v rail of the PSU I'm using.... for a silly comparison.
8,315 (5.24/day)
São Paulo, Brazil
Cooling Pichau Lunara ARGB 360 + Honeywell PTM7950
Memory 32 GB G.Skill Trident Z5 RGB @ 7600 MT/s
Video Card(s) Palit GameRock GeForce RTX 5090 32 GB
Storage 500 GB WD Black SN750 + 4x 300 GB WD VelociRaptor WD3000HLFS HDDs
Display(s) 55-inch LG G3 OLED
Case Cooler Master MasterFrame 700 benchtable
Mouse Microsoft Classic IntelliMouse
Software Windows 10 Pro 22H2
My friend you are using (an old, but still) high-performance segment GPU on an $25 power supply, that is all you needed to say.... your PSU was simply not designed for this type of workload, it was fine when you were running the 2200G's integrated graphics but that's where it stops. Theoreticals really don't matter, you need to purchase a decent power supply, IMO, in the 700-watt range to acommodate for aging and a CPU upgrade in the future (that CPU is REALLY bad, to the point it will bottleneck even your old 1070).
