PC works fine, no video signal or power to keyboard and mouse?
52 (0.02/day)
Sydney, New South Wales, Australia
Processor AMD Ryzen 7 3700X
Motherboard ASUS Strix X470-i
Cooling Alphacool Eisbaer LT240, 2x Corsair LL120, 1x Noctua 3k RPM fan
Memory G.Skill TridentZ 16GB DDR4
Video Card(s) GALAX RTX 2080
Storage Samsung 970 EVO 1TB NVMe boot, 2x 2TB Samsung 860 QVO in RAID 0
Display(s) Dell U2719D, AOC e2343F
Case Corsair 380T
Audio Device(s) Steinburg UR12, Beyerdynamics DT 990 Pro, ModMic 5
Power Supply SeaSonic Focus Plus 750W
Mouse Logitech MX Master, Razer Viper
Keyboard Ducky One 2
Hi, my PC has not been operational for about 2 weeks, and I'm not getting video signal and there is no power to my keyboard and mouse.
What I have tried to solve the problem:
  • Connected PC speaker
  • Disconnected hard drive
Please note that all of my components are working I think that this is a software/BIOS problem?
Specs:
  • Intel Core i5 6600
  • Asus B150M-AD3
  • 8gb DDR3 1333(1x)
  • Gigabyte GTX 780Ti
Thanks
EDIT: I have tried removing my CMOS battery, and the same thing happens. Was I meant to short the pins again? Did I do something wrong? Thanks
Edit 2: I removed the battery, discharged the capacitors and it STILL happens? Is my motherboard dead I really hope this isn't the case :(
FreedomEclipse
~Technological Technocrat~
24,780 (3.76/day)
(currently) Hong Kong
System Name WorkInProgress
Processor AMD 7800X3D
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
Power supply is fubar. Get a new one
:edit:
Oh and welcome to TPU
9,781 (2.14/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
Mouse Logitech G502 spectrum
what i would do if i were in your position is any of the following steps.... test the components 1 at a time, or....test the problem PC, by swapping in known working parts 1 at a time. Either way it will require a working PC to troubleshoot it, or a lucky guess. Another option would be to take the PC apart. Start like you were just building it today, mount the Motherboard, RAM then check to see that You can boot into Bios. Now add the CPU, again check to see if you can boot into bios , and carry on that way until the PC is either rebuilt, or You have run into the Problem component. Finally, Your Motherboard Should have a DrDebug built into it, pull out your manual, or go to the Asus website, and see what that reading means....it is there for the exact purpose of narrowing down issues like this.
welcome to TPU & good luck.
14,545 (3.79/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
PC works fine ..... :roll::roll::roll:
Sorry, couldn't resist that one.
Welcome to TPU. As mentioned above, look up the Qcodes and or check LED's on the Motherboard to check for faults.
52 (0.02/day)
Case Corsair 380T
There is no LEDs on my motherboard. and what is TPU? my pc is about a yr old.
There is no DrDebug on my motherboard. Only a PC speaker, which does not beep, so I think it is posting fine.
sneekypeet
not-so supermod
29,709 (4.27/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
Speaker should beep once with a fully functioning PC on post.
52 (0.02/day)
Case Corsair 380T
Speaker does not beep once when successful POST. Only fans ramp up a bit.
dorsetknob
9,106 (1.24/day)
and what is TPU?
TPU is the Site where your asking questions :)
do you have anyone near you that is fairly competent with PC Diagnostics /dissassembling/rebuilding that can help you with the advice your getting here ?
14,545 (3.79/day)
Sunshine Coast
Memory 32 GB DDR4
Mouse Lenovo
Looking at the Motherboard on the Asus site, it doesn't have a built in speaker.
Have you tried clearing the CMOS by removing the battery after unplugging the system?
52 (0.02/day)
Case Corsair 380T
I tried clearing CMOS by the jumper, maybe I should remove the battery?
