PCI express bus speed only running at x8 v3.0 instead of x16 v3.0
GabrielOvejero
5 (0.01/day)
My cpu is Ryzen 5 3400g, Mother a320m-s2h
3x0
1,014 (1.09/day)
Processor AMD Ryzen 7 5800X3D
Motherboard MSI MPG B550I Gaming Edge Wi-Fi ITX
Cooling Scythe Fuma 2 rev. B Noctua NF-A12x25 Edition
Memory 2x16GiB G.Skill TridentZ DDR4 3200Mb/s CL14 F4-3200C14D-32GTZKW
Video Card(s) PowerColor Radeon RX7800 XT Hellhound 16GiB Noctua NF-A12x25 Edition
Storage Western Digital Black SN850 WDS100T1X0E-00AFY0 1TiB, Western Digital Blue 3D WDS200T2B0A 2TiB
Display(s) Dell G2724D 27" IPS 1440P 165Hz, ASUS VG259QM 25” IPS 1080P 240Hz
Case Cooler Master NR200P ITX
Audio Device(s) Altec Lansing 220, HyperX Cloud II
Power Supply Corsair SF750 Platinum 750W SFX
Mouse Endgame Gear OP1 8K
Keyboard HyperX Alloy Origins Aqua
Make sure there is no dust in the PCIe slot. Does it show x8 when running a 3D load?
3,105 (2.01/day)
Germany
Processor AMD Ryzen 9 9950X3D
Motherboard ASRock B850M PRO-A
Cooling Corsair Nautilus 360 RS
Memory 2x32GB Kingston Fury Beast 6000 CL30
Video Card(s) PowerColor Hellhound RX 9070 XT
Storage 1TB Samsung 990 Pro, 2TB Samsung 990 Pro, 4TB Samsung 990 Pro
Display(s) LG 27GS95QE-B, MSI G272QPF E2
Case Lian Li DAN Case A3 Black Wood Edition
Power Supply Corsair RM1000X ATX 3.1
Mouse Razer Deathadder V3
VR HMD Oculus Rift S
normal at idle.
3,105 (2.01/day)
Germany
This is why. APUs budget X8 for their PCIe external interface
"The 3400G includes 20 PCIe lanes - 16 for a discrete graphics processor and 4 for storage (NVMe or 2 ports SATA Express)."
792 (0.17/day)
Denmark
System Name Waterfall | xe
Processor Core i3-12100F | i5-1240P
Motherboard Gigabyte B660M-DS3H | HP laptop
Cooling Custom Watercooling | Stock laptop
Memory 2*16GB | 16GB DDR4
Video Card(s) RX 5700 with WC blocks | Iris Xe
Storage Intel 660 1TB + Crucial BX100 500GB | 1TB SSD
Display(s) U24E850R+U2515H | Internal 16"
Case Be Quiet! Dark Base 900 | Laptop
Audio Device(s) Audio 2 DJ + Xenyx Q802USB | Realtek
Power Supply Seasonic Focus Plus Gold 750W | 65W USB-C Power brick
Mouse Logitech M330
Keyboard Logitech G610 Orion Brown | Laptop
Software Gentoo + Windows 10 Pro | Gentoo
Ryzen 2000 and 3000 series APU's only have 8 lanes for GPU.
5,517 (1.03/day)
idk what this quotes, but it is definitely not AMD's own source. Any APUs for AM4 have 8 lanes internally fused to the iGPU, and that takes the real estate of the main PCIe X16 dGPU connectivity.
You can even browse motherboard spec lists to see this mentioned
To the question if you can disable the iGPU, no. The 8 lanes are physically fused to the iGPU. They are lost to that even when the iGPU is disabled
GabrielOvejero
5 (0.01/day)
would a processor without integrated graphics solve the problem? Sorry for my english, I thought that disabling the IGPU from the bios would fix it, but apparently not.
5,517 (1.03/day)
Having only 8 lanes for a GPU is not a serious problem. I don't see much point in solving it. The only problem might be CPU bottlenecks in some scenarios, but besides that, all GPUs can live off 8 lanes quite normally
9,828 (3.41/day)
System Name Best AMD Computer
Processor AMD 7900X3D
Cooling In Win SR36
Display(s) GIGABYTE FV43U
Case Corsair 7000D Airflow
Power Supply Deepcool 1000M
Keyboard Logitech G510
yes
3,105 (2.01/day)
Germany
5,517 (1.03/day)
it's from wikichip.
Than it might cause misinformation. It is correct that at the very core these APUs contain 16 lanes for graphics, but what they don't mention is the fact that half of it is fused for the Radeon iGPU unit.
This has been AMD's method for PCIe lane budgeting throughout the entire AM4 platform, regardless if 2200G, 3400G, 4650G or 5600G.
792 (0.17/day)
Denmark
Mouse Logitech M330
That is NOT correct. 4000G and 5000G series chips have 16 lanes of PCIe for GPU. AMD just skimped on lanes for 2000G and 3000G chips.
5,517 (1.03/day)
oh yeah, my bad. forgot that part. I stand corrected. I even own a 5600G somewhere and forgot.
The only sin there is due to architechture it uses PCIe Gen3
44,274 (6.80/day)
Yes
Go with the 5000g line if there is a bios update for the motherboard
