Pencil Modding and repair
Toby Ireland
20 (0.00/day)
Processor Intel Pentium 4 3.02GHZ
Motherboard damaged Asus P4S800MX
Cooling 4 Chassis mounted fans, CPU heatsink + Fan, PSU Fan
Memory 2 x 512MB DDR400 SDRAM
Video Card(s) ATI Radeon 9600 XT
Storage 80GB ST380011A, 6GB Fujitsu
Display(s) Samsung Syncmaster 793DS CRT + Acer
Case very colourful
Audio Device(s) Soundblaster Live 8400
Power Supply 450 W
Software Windows XP Pro
Hi all... i have another post on my damaged motherboard, where they suggested i pencil mod the brocken gold tracks on the underside of my motherboard... 6 broken tracks near my northbridge chipset... so does anyone know exactly what i should do to repair it..?(preferably pencil modding) thanks muchly...
you didnt have to make another thread....
you have two options;
a) pencil mod - when you take a conductive material and basically draw new leads...
b) soldier wires jumping between the broken leads.
thankyou greatly, but i couldn't solve it that way... however seem the motherboard lives on with no signs of damage, other than the appearance of the scratches... the ASUS LIVES ON!
how about taking some pictures and posting them up? maybe someone can tell you what those traces were supposed to do.
Thats a good idea, shame I didn't think of that before i re-assembled my computer for a second time, but it's probably worth knowing, so here i go for a third complete dissasembly...(taking out all cards, all IDE belts, all power leads and one poorly fitting hard drive...)
If you REALLY have a damaged mainboard with broken tracks, then I suggest you replace the mainboard. You cannot fix the tracks that are not visible (the PCB has 8 layers!). It just isnt worth the possible risks of untimely unpredictable failure, or other unknown problems, due to a faulty mainboard.
EVERYTHING hangs off the mainboard. If there#s only one things you need 100%, is the mainboard.
FOR VERY CHEAP MONEY you can get a much better mainboard that will take ALL your stuff, and will allow overclocking. http://www.asrock.com/product/P4i65G.htm
ASROCK is a discount offshoot of ASUS. This particular mainboard is the replacement for ASUS P4P800-VM which was the BIG BROTHER to the mainboard you are currently using. I've used both and can recommend them. I even have some spares.
