Polarman
- Jun 24, 2008
- 1,626 (0.26/day)
- Rimouski
System Name | Polar's Dragon |
Processor | AMD Phenom II 975BE |
Motherboard | MSI 890FXA-GD65 (Bios 18.7) |
Cooling | Zalman CNPS 9700 Led |
Memory | Gskill 8GB DDR3-1333 (8,8,8,21) |
Video Card(s) | MSI HD6870 Hawk |
Storage | WD Raptor 250 - WD RE4 500GB |
Display(s) | Samsung T240 (1920 X1200) |
Case | Silverstone Raven 2 |
Audio Device(s) | Realtek ALC892 |
Power Supply | PC Power&Cooling Silencer 750 (Red) |
Software | Windows 7 Home Premium 64Bit + SP1 |
PerfectDisk 10 as been updated to build 108. If you have this like me.
http://www.perfectdisk.com/pd10-product-updates
Release notes:
Release notes:
- Bug Fixes
- Add control over Welcome Wizard via config.ini and Group Policy.
- A schedule set via Group Policy has time with seconds always equal to minutes.
- Status is not updated when defragmentation was resumed.
- Space Reports graphs are 1 day off.
- Multiple PDAgentS1 processes.
- High CPU usage when selecting a drive with excluded folder.
- A few features are missing when user language is set to Japanese.
- Auto Update file download is not cancelled by Cancel button on Raxco Software Auto Update dialog.
- PerfectDisk for VMware does not provide exclusion list for a virtual machine.
- Duplicates - If Other files selected, doesn't require input of file extension.
- Recycler reports double number of files cleaned in Recycler Bin on Vista.
- List of temporary folders for Recycler once saved never updated.
- Recycler pane does not preserve drive selection and option selection.
- When Recycler run is stopped the results report 0 files cleaned.
- "Can not connect to Exchange.." message on system tray icon launch.
- Exchange pane: label "Storage Group" is missing and Next Run drop-down menu is disabled.
- Send Test Email reports success with all empty fields.
- PD/Settings/Exchange - tab order is not as expected.
- Windows Home Server Plugin uses old PD10 icon.
- Need to have column width persistent in the log viewer.
- Sort indicator does not conform to Windows specifications in a number of column header.
- What do dark blocks mean?
- Daily schedule does not display error "Invalid Maximum duration value".
- Calendar on weekly schedule wizard get truncated when error messages displayed.
- Space Explorer - During Analysis, strange graphics issue is displayed.
